Old 12th February 2011, 23:38   #526
LNK
Default re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by ryan_wheelz View Post
Can someone tell me at idle, what reading should the RPM show
mine shows just one stick above the minimum ,its a a stick in BOLD,
so it should be around 200rpm . is this right ?
My mechanic sad this is how it should be.
Appreciate any help guys.
Planning to sell the car now,more problems than fun.
It's usually around 600 in mine I guess. 200 seems to be far too low.
It isn't tough to sell a OHC, but very very difficult to get a decent one if you ever change your mind in the future.
LNK is offline   Reply With Quote
Old 13th February 2011, 09:41   #527
_raviShankar_'s Avatar
Thanked: 67 Times
The bold stick marks 500 rpm and each small ones after that 100 each.
_raviShankar_ is offline   Reply With Quote
Old 13th February 2011, 11:04   #528
pranavt's Avatar
Thanked: 274 Times
Normal idling should be at ~800 rpm.
Old 13th February 2011, 12:18   #529
jatinpatel's Avatar
Thanked: 191 Times
Normal Idling range with and without ac is given below
850rpm NON AC
950rpm with AC
jatinpatel is offline   Reply With Quote
Old 13th February 2011, 16:26   #530
LNK
How deep do you push the clutch? Unless i push it all the way to the floor, I dont get smooth shifts. Is it an issue if its touching the floor? Sometimes i hear a slight metallic sound when it does that, is it an issue?
Old 13th February 2011, 18:52   #531
Desmosedici's Avatar
Thanked: 409 Times
I guess that depends on the kind of clutch setting you have in your car. Some people keep it at full / half clutch release as per their convenience but a clutch should always be fully depressed while shifting gears. Metallic sound indicates that you might need to get your clutch plates checked and serviced.
Desmosedici is offline   Reply With Quote
Old 13th February 2011, 21:53   #532
LNK
I just noticed it, right below the clutch pedal (when it is full pushed down) there's a small metallic plate sort of a thing. When the clutch pedal hits that, I get the noise. What is that plate(?), small squarish thingy with a hole in it? Is it a provision for a rubber bush that I'm missing?
And regarding the RPM , does it change when the AC is used? Sometimes i feel a loss of power with the AC on. I've a 1.5 exi. Is it normal given the age of the car?
If the car has been driven extensively over years primarily within the 2.5-3k rpm range, will it be too harsh on the engine if revved higher now? (For any car)
Old 19th February 2011, 14:07   #533
Thanked: 84 Times
Hey desmo...
How about your problems?
I checked in a after long time, hope you got them resolved.
I fear my dropping RPM could be a faulty throttle body, dunno how deep is this gonna cut my pockets...ouch!! it pinched! heh!
Petroheads....
I still haven't got proper reply to my dropping RPM query??
Seniors, experts please put some light or I should be on some workshops apathy....
@ Desmo
please let me know reasons for all the faults especially RPM one and did you get low rpm jerks corrected by any mean? please share
Have anybody experienced performance of Gabriel dampers in OHC?
How are they? Does Monroe make dampers for OHC too?
Which one is better?
Honda Monk is offline   Reply With Quote
Old 20th February 2011, 05:23   #534
vinayvtec's Avatar
Thanked: 9 Times
@OHC Vtec,
1> It might be an issue with front arms.
2> You need to do some research here, park the car turn it on and switch on the AC open the hood and check if the compressor is working or not. If it’s not working then it might be an issue with switch or wiring.
3> That’s a clear lie, do you think Honda would leave a car with defected armrest
I would suggest you to take it to Honda Service Center and get the complete check up done, so that it will help you in figuring out which parts needs to be replaced in next service.
vinayvtec is offline   Reply With Quote
Old 21st February 2011, 20:16   #535
Thanked: 409 Times
Originally Posted by Honda Monk View Post
Hey desmo...
Petroheads....
@ Desmo
Nothing done yet, i am waiting to sell my Gypsy and get those funds routed to the Vtec but again in 2 minds on parting with the Gypsy, so no updates till now and waiting for some funds to come in.
Old 6th March 2011, 12:43   #536
Thanked: 409 Times
Yesterday, i braked hard to save a biker and after that i notcied that my brake light was always on. I disconnected the -ve battery terminal yesterday night so that the battery doesnt drain out. Can anyone help me to locate the brake light switch and how to adjust it back.
Old 7th March 2011, 10:19   #537
KSM-Vtec's Avatar
Thanked: 440 Times
Its above the brake pedal...it has a rubber packing on top which would have become hard(over time) and hence broken when you braked hard. You can just replace that rubber with a normal screw.
For all you guys facing a power loss problem/ drop in rp, these are the first few aspects you should look into -
1. Ensure that your fuel filter is new (not cleaned) (this is very imp)
2. Your fuel pump is working fine and consistently
3. Injectors are not blocked
4. Fuel tank is clean
5. Plugs and wires are in good condition
If all these check dont solve your problem then you can look at -
1. IAC valve
2. TB sensor
3. O2 sensor
KSM-Vtec is offline   Reply With Quote
Old 7th March 2011, 11:49   #538
Thanked: 409 Times
Hey Kaushik, How are you doing mate?
Thanks for the tip, I did try reaching in to look at the brake pedal but couldnt 'fit in' properly to take a proper dekko. I shall take it to a mech, these guys will do it easily.
Old 7th March 2011, 12:34   #539
KSM-Vtec's Avatar
Thanked: 440 Times
Hey Desmo...i am doing fine! hope things are great at you end.
Take it to a electrician they can fix this easily. (1 min job)
Old 13th March 2011, 21:31   #540
di1in's Avatar
Thanked: 92 Times
Hey guys, anyone know where I could source a pair of OEM style fog lamps for the ohc?
I have that problem as well, must be a misalligned/worn carpet after all these years of stomping on it during traffic jams.
Have you tried shifting your grey carpet over it?
The AC needs lots of power to lower the temp and that's the power decrease you felt. Switch on the AC at idle and you'll see the idle RPM shifting higher by 100 odd.
So yes it's normal for the car.
High rpms as in 4k or 5k might not be that bad if you regularly change your oil but redlining frequently is obviously bad. But it's still loads of funn!
di1in is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
