Old 5th August 2011, 13:03   #646
sushrutha's Avatar
Thanked: 325 Times
Default re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by Desmosedici View Post
Wiper doesnt go back to it original position and stays slightly up.
Shouldn't be a problem at all in readjusting the wiper.
Remove the wiper blades (You need a spanner ), then adjust/align the wipers as per your need.
sushrutha is offline   (1) Thanks Reply With Quote
Old 5th August 2011, 14:45   #647
Thanked: 84 Times
Originally Posted by ankitahuja View Post
Don't even talk about the Golf Course ext road, I live there and I know the HORROR of commuting to and fro on this nightmare stretch!
Got an extensive tune up and maintenance work done last month. Problems faced:
  • Thud suspension (literally goed 'THUD' on every bump).
  • Rear shockers leak (OE after 13 years)
  • Shot rear tyres due to bad shockers
  • Speedometer cable broken
  • Check Engile Light on due to reason above
  • A heavy steering
  • RPM kill - always under 500 or about to die - Old issue
  • Engine Misfire / Jerks till 2000-2400 RPM - Old issue
  • Rear tyre noise - Bearings kaput!
  • A bit of this, a bit of that!
List of things done:
  • Front Shocker replacement
  • Lower arm bush replacement
  • Tie-Rod Ends replaced
  • Front Suspension Bush Kit replaced
  • Rear Shockers replaced
  • Rear Wheel Bearings + Hubs replaced with OE
  • Engine Flushed
  • Engile Oil renewed with Castrol GTX Magnatec
  • Oil Filter replaced
  • Fuel Filter replaced
  • Spark Plugs replaced (all 4 - NGK OE Spec)
  • Speedometer Cable replaced
  • Steering Column Bushes replaced
  • Clutch Cable replaced
  • Brake cleaning
  • Throttle Body cleaned with spray
  • Injectors Cleaned
  • Radiator chemically cleaned
  • Replaced coolant and water
  • Two rear tyres replaced
  • Installed Hella Twin Tone horn
A tremendous change in the behavior of the car, except that the jerking/misfire will not go away. Reason - One cylinder has lost compression and there is no remedy for it! :-(
Otherwise the car was silent and the niggles all went away. A month down after off roading on Gurgaon roads, there are suspension noises cropping up slightly.
Hey Ankit
That is a real big maintenance job done on a car such old.
Seems u still dnt wana get apart.
How long are you seriosly plannig to keep it?
Do share where did you get your all jobs done and the cost break up please?
Thanks bro.
Honda Monk is offline   Reply With Quote
Old 7th August 2011, 00:25   #648
OHCVtec's Avatar
Thanked: 12 Times
Guys, I am facing this issue with my left disk breaks getting stuck. It happens when I use the car after a nights gap,the wheels get hot. The disks get freed after 3-5 kms of running. I have recently changed the break oil. Any suggestions,what can be done.
OHCVtec is online now   Reply With Quote
Old 7th August 2011, 12:59   #649
toiingg's Avatar
Thanked: 74 Times
OHCVtec : the pads are rubbing with the discs, get that opened and checked.
Guys, anybody knows the part number of the thermostat for the OHC ?
toiingg is offline   Reply With Quote
Old 9th August 2011, 13:56   #650
infotech58's Avatar
Thanked: 217 Times
Guys,
i am thinking of getting my OHC Vtec repainted (stripped off and then repainted); could you recommend any good places in Mumbai/Thane? My budget is approx. 40k (including body work and new rubber beadings). please PM me (or share the details on forum) the contact information of garages you might have tried out for body work/painting.
infotech58 is offline   Reply With Quote
Old 9th August 2011, 14:37   #651
Desmosedici's Avatar
Thanked: 409 Times
Originally Posted by infotech58 View Post
Guys,
Try contacting Allen (V12 on TBHP). His dad runs a workshop at versova. He can assist you with further details.
Desmosedici is offline   Reply With Quote
Old 21st August 2011, 19:29   #652
Thanked: 409 Times
Hi Gurus,
Got Philips Rally 100/90 with Hella Relay and got some LEDs fixed inside. Till then everything was fine. Now when i drove back, i could see the RPM fluctuating. Yest only i had set it at around 900 and now its going up and coming down between 1000 and 300 - 400 mark. Jerking is there at slow speed and pickup is down from what it used to be. Moreover after parking i let the car idle and alongwith the RPM fluctuations, i could also sense a mild 'dhug dhug' sound with mild vibrations.
Somehow after servicing and getting the suspension work etc done, i am not happy. Can someone help please. Could this be an IACV issue (i dont know). I am going crazy with these small issues. Plus can someone help with a 2003 ECU as the jerking at lower speeds is irritating now. I want to keep the car as its great fun to drive but at the same time, these niggling issues get to your nerves.
Old 22nd August 2011, 23:30   #653
Thanked: 409 Times
Can someone help me with the above issues. Its eating my brain out.
Old 23rd August 2011, 14:19   #654
sushrutha's Avatar
Thanked: 325 Times
Some issues all I can think off are
1. Please check the spark plug wires(spark plugs to delco). Either it might have gotten loose or one of the wire has gone for a toss.
2. Also check spark plugs , Throttle body, Airfilter
3. Try resetting the ECU - (remove the battery terminals overnight and plug it in morning, this should usually reset the ECU).
4. Bad fuel.. or water in fuel.
5. Check the vaccum pipe, is it connected properly or not.
6. Lastly.... Fuel pump... Lets hope this is not the case.
Old 23rd August 2011, 15:00   #655
pranavt's Avatar
Thanked: 274 Times
Get the IACV cleaned properly. Check for vacuum leaks if IACV cleaning doesn't solve the problem.
pranavt is offline   (1) Thanks Reply With Quote
Old 23rd August 2011, 18:27   #656
Thanked: 409 Times
Thanks Sushrutha and Pranav.
Throttle Body, Air Filter and Fuel Injectors were cleaned while getting the car serviced. I was also thinking of resetting the ECU by removing the battery terminals. If still issue persists, i will check the spark plug wires, vacuum pipes and IACV.
Thanks a lot guys. Its so good to know that there are so many like you guys to help us non technical people.
CHeers.
Old 23rd August 2011, 18:45   #657
dhanushs's Avatar
Thanked: 4,472 Times
Hi Pranav, doesn't an issue with IACV mean erratic high idling? Will the idle rpm drop? Please advise.
What is the condition of the fuel pump?. I have heard many fuel pump issues in OHC's. Check the fuel pressure and confirm.
Old 23rd August 2011, 18:47   #658
pranavt's Avatar
Thanked: 274 Times
A clogged IACV would block airflow, resulting in a low idle.
Old 24th August 2011, 23:05   #659
Thanked: 409 Times
After fitting higher wattage 100/90 headlights with relay, without having a cutout have any effect as a relay is only to save the electrical component from any damage and not to distribute the battery power effectively and a cutout actually does the job of distributing the battery power.
Just a thought. Can this be a reason for the fluctuating idling. and where can i check for the vacumm pipe.
I also disconnected the battery terminal for about 3 hours but not much of a help.
Old 26th August 2011, 10:38   #660
Thanked: 9 Times
What I heard from this thread earlier when i had an RPM fluctuating issue is that , due to faulty earthing also this can happen.
My issue resolved by itself. Suspecting bad fuel in my case .
vinu_pm is offline   (1) Thanks Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
