Old 20th December 2011, 15:04   #736
infotech58's Avatar
Thanked: 217 Times
Default re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by Honda Monk View Post
Hey Ryan
I am also in the process of revamping my OHC.
Giving you the prices I inquired in Delhi from a reliable supplier.
Head Lamps both Stanley - 3800 ; Depo - 2700
Front Grill (Taiwan) - 1500
Brake Pads (Nissin) - 850
What I couldn't get and still looking for are the Monograms and Door Beads.
Lots of aftermarket available but none similar to OE.
I have tried few shops in Kashmiri gate too.
Can anyone please let me know where can I get these in Delhi, any specific shop please refer.
Thanks!
Are the given headlight prices for a pair or per piece?
infotech58 is online now   Reply With Quote
Old 20th December 2011, 20:27   #737
Thanked: 84 Times
Prices quoted are for pair.
Honda Monk is offline   Reply With Quote
Old 22nd December 2011, 13:19   #738
KSM-Vtec's Avatar
Thanked: 439 Times
I just started to restore my OHC Vtec and right now it is being painted at Bhavani Auto Care in Powai.
Thanks to infotech58 i went to Bhavani yesterday and got some work done!
1. Clutch & pressure plate changed
2. Clutch cable changed
3. Clutch bearing changed
4. injectors cleaned on a great automatic machine - pre 27ml per 30secs post 35ml per 30 secs (all this per injector) so its like i have an additional injector now
5. Tappet packing changed
6. Checked the timing belt..no change required.
Thanks again Sumeet!
I could have done this anywhere but the fact that he had got all this work done on his OHC Vtec and is happy really made it an easy choice
KSM-Vtec is offline   Reply With Quote
Old 23rd December 2011, 11:26   #739
Desmosedici's Avatar
Thanked: 408 Times
Just to get an idea, how much was spent on all of the above. Can you give an approx number. Tks Kaushik.
Desmosedici is offline   Reply With Quote
Old 23rd December 2011, 11:47   #740
infotech58's Avatar
Thanked: 217 Times
you are very welcome ksm-vtec and it was really nice meeting you.
did you get a chance to have a look and understand the working of injector cleaning machine he has? if yes, please post some details. i never got to see that in action.
Old 23rd December 2011, 12:19   #741
KSM-Vtec's Avatar
Thanked: 439 Times
Same here!!
Well i dint see it in action, but from what i understand he has the completely automatic/computerised machine..the one which has those test tubes for each injector.
The machine also gives the pre and post cleaning fuel flow report.
Sure, here you go..
Exedy Clutch & pressure plate - 3,500
Clutch bearing - 700
Clutch cable - 450
GB Mount - 750
Tappet packing - 600
Axle boots - 400
Injector Cleaning - 800
Labour - 1,700
Total - 8,900
Stuff that i bought but dint need (returned)
Timing belt - 600
Timing tentioner - 950
Crank & Cam oil seal - 800
1 GB mount - 750
KSM-Vtec is offline   (2) Thanks Reply With Quote
Old 25th December 2011, 12:37   #742
pranavt's Avatar
Thanked: 273 Times
Kaushik, can you post the report if you have it?
I'm interested in seeing what machine they use. Last I heard, the only ASNU injector cleaning around us was in Pune.
Old 26th December 2011, 12:28   #743
KSM-Vtec's Avatar
Thanked: 439 Times
Unfortunately i dint go into lot of detail on that.
Will ask him more about the machine when i am there the next time.
I remember him saying that the machine is good for cars up to BS7 (dont know if that matters)
Old 29th December 2011, 14:56   #744
moralfibre's Avatar
Thanked: 6,216 Times
And who in Pune has that injector cleaning machine?
Old 29th December 2011, 15:11   #745
pranavt's Avatar
Thanked: 273 Times
Tapia. Google Tapia ASNU Pune.
pranavt is offline   (1) Thanks Reply With Quote
Old 29th December 2011, 15:13   #746
amitoj's Avatar
Thanked: 1,592 Times
Guys, whats the fuel tank capacity of OHC?
amitoj is offline   Reply With Quote
Old 30th December 2011, 12:16   #747
Thanked: 408 Times
Today morning after driving for around 5 Kms i noticed some smoke / steam coming from the left side of the bonnet. Checked and saw the Coolant pipe had got disconnected and there was hardly any coolant inside and the smoke / steam was coming from the tube which had got disconnected. I got a botte of Bisleri and put it in the Coolant bottle but before that a Truck Driver nearby told me to wait for sometime as the water was chilled and should not be poured and the car should not be started immediately. After 10 mins i poured the water in the coolant bottle and started the car. Noticed a mild RPM fluctuation and the Temp Needle was below 50% mark as always. However i noticed some sound similar to water boiling and kept the car at my friends place which was just 100 mts from where this happened.
Question is, if such a thing happens, what should be the normal procedure. Should i fill in the Coolant mixed with Water in the Coolant Bottle and should i also fill in Coolant mixed with water into the Radiator as i guess a lot might have got evaporated when the tube got disconnected. I have got a 500ml bottle of BPCL MAK Lubricants coolant. Please help on what i should do.
Old 30th December 2011, 21:35   #748
_raviShankar_'s Avatar
Thanked: 65 Times
I believe it is 45 ltrs.
_raviShankar_ is offline   (1) Thanks Reply With Quote
Old 31st December 2011, 02:23   #749
pranavt's Avatar
Thanked: 273 Times
40 liters.
@Desmo: Top up the coolant. Drive around for a bit. See if car overheats. If it does, you've probably blown the head gasket which will require replacing. Also when checking, open up the radiator cap and check the color/texture of the coolant. If you can see any oil in there, then you've blown the head gasket.
If it's not overheating or mixing coolant and oil, nothing to worry.
pranavt is offline   (2) Thanks Reply With Quote
Old 31st December 2011, 18:29   #750
Thanked: 84 Times
What can be the maximum profile for stock OHC Rims?
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
