Old 9th April 2012, 23:14   #826
KSM-Vtec's Avatar
Thanked: 439 Times
Default re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
The IAC valve setting can be the cause for the problem. If that is the case then some amount of trial and error can fix your problem.
But the more difficult to identify and handle reason is the gap due to the ware and tear in the TB cylinder and butterfly causing the air to escape even when the butterfly is supposed to be in closed position.
2 possible solutions -
1. Enlarged tb and butter fly - better performance but lower FE - i would suggest this if u have a conical filter and good plugs.
2. New TB
Originally Posted by ankitahuja View Post
Like I said, there can be many different reasons. The TB is the most common culprit and getting it cleaned solves this problem in most cases.
One can get the IAC cleaned, open the sensors and have them air blown, get the injectors cleaned and try to change the spark plugs. Also check for loose wires and hoses that may be leaking.
I'm not in GC Ext anymore but very close by let me know once you're here and we can meet up!
Originally Posted by Honda Monk View Post
Hey Ankit.
I have got my throttle body cleaned and adjusted "N" no. of times. There ain't any engine sensor light so don't think any sensor (i.e. RPM actuator) is at fault.
How did you get it rectified?
Well I am going to Pandit for service tomorrow, lets see what happens.
Will give a call next time I am in Gurgaon (Still go to meet friends at GC Ext.). Stay in touch.
KSM-Vtec is offline   Reply With Quote
Old 10th April 2012, 15:42   #827
di1in's Avatar
Thanked: 73 Times
Default Re: Old Honda City Overhaul
Does anyone know what all is done in a Major Service (1,00,000 kms)at Honda?
Things I know:
o Timing Belt Changed
o Engine Mounting redone or something
o Diesel Cleaning
o Air filter and whole box/piping changed
di1in is offline   Reply With Quote
Old 17th April 2012, 12:10   #828
Desmosedici's Avatar
Thanked: 408 Times
Originally Posted by KSM-Vtec View Post
Dan knows of some place for fogs at opera house. Lets get them from there.
Call me when you are at pioneer if thats ok.
Hi Kaushik,
Sorry, forgot to call you. i got my Brake pads from Pioneer for 1200 bucks. It was not Nissin but had Honda Label on it.
He said he had Fog Lamps costing around 1000 bucks (is it that cheap) but we will have to order for it. He doesnt stock it.
Desmosedici is offline   (1) Thanks Reply With Quote
Old 17th April 2012, 14:42   #829
OHCVtec's Avatar
Thanked: 12 Times
I have been experiencing the following issues with my car lately:
1. I can smell petrol from the rear end once the car is started.
2. The Fuel Gauge reading is faulty, even if the tank is full it does not indicate 100%. It is around 3/4 'th at full tank.
I have been experiencing these issues after the tank was removed and re-installed to troubleshoot the abrupt stopping of my car earlier.
OHCVtec is offline   Reply With Quote
Old 17th April 2012, 14:50   #830
KSM-Vtec's Avatar
Thanked: 439 Times
Issue 1 can have various reasons. Please check all the fuel lines for leaks.
Issue 2 is due to the fuel gauge floater in the fuel tank has not been installed correctly. There is a link rod which would have got bent. Need to correct the angle of that rod holding the floater.
KSM-Vtec is offline   (1) Thanks Reply With Quote
Old 17th April 2012, 14:57   #831
OHCVtec's Avatar
Thanked: 12 Times
Thanks for your prompt reply KSM-Vtec. My car is due for service this week, will get these checked.
OHCVtec is offline   (1) Thanks Reply With Quote
Old 18th April 2012, 19:06   #832
This is a little off topic but i desperately need help! I recently got my OHC's steering rack and shaft replaced. now at slow speeds i can feel the front wheels wobble.It feels as if the car shakes as slow speeds. The steering is still stiff and wouldn't return. I got the alignment and wheel balancing done but no issues found. The rims and tires are in a good shape as well. Please advice!
LovemyOHC is offline   Reply With Quote
Old 19th April 2012, 16:35   #833
Thanked: 84 Times
Got my car serviced at Pandits. Didn't find him expensive at all. Mr. Pradeep is a real gentle business man, very nice to deal with.
All fluids flushed, lines cleaned and fresh oil filled.
After service the car was still giving problem with pick-up and rpm was fluctuating. On my complaint Mr. Predeep very courteously took back the car and told me that the TB needs to be opened and cleaned, so I dropped the car for one day.
He worked on the car get the TB cleaned, along side replaced my O2 sensor too. (without any extra cost and my old denso O2 sensor was returned to me).
He told me that my TB needs to be replaced and CAT also choked a bit.
Now the car is running fine with a little whistle sound as I floor the throttle and RPM drops when I switch on A/C.
Can anybody tell How to confirm the CAT is choked? and this RPM drop with A/C on.
Honda Monk is offline   Reply With Quote
Old 20th April 2012, 09:45   #834
Thanked: 408 Times
Hi Kaushik,
Again checked with Pioneer Motors regd the Fog Lamps. He checked with a few places but couldnt source it. He said the only option left was Opera House.
Old 24th April 2012, 13:44   #835
ryan_wheelz's Avatar
Thanked: 38 Times
Hey Desmo,
They are available with Sainath (Khar) - expensive !!!!!
4k for a set , last i saw they were only 2 sets left.
My Wiper motor conked off , a mechanic in juhu said a denso motor will cost around 2500 while another motor (second hand ) for 1700 with 6 months guarantee.
Is this what they cost generally ?
Ryan
ryan_wheelz is offline   (1) Thanks Reply With Quote
Old 24th April 2012, 14:26   #836
KSM-Vtec's Avatar
Thanked: 439 Times
Originally Posted by ryan_wheelz View Post
Hey Desmo,
Ryan
1700 is a lot for the motor. what is exactly wrong with the existing motor?
Is it the magnets or the coil?
Old 24th April 2012, 14:46   #837
Thanked: 408 Times
Thanks Ryan, 4k is expensive for the fogs i guess. KSM could comment on it.
I am also looking for the driver side power window motor. Getting used ones for 1500 and that too without the auto up / down function. I am looking to sell the car but wanted to get everything fixed before i do. I shall pass on Pioneer's number, you can call and check there as well. They also stock most of the parts.
Desmosedici is offline   Reply With Quote
Old 24th April 2012, 17:32   #838
Thanked: 38 Times
Hey Kaushik,
I cant really figure what is at fault , i don't know how to , it has completely stopped working and if i try to activate it it makes a sound , this would happen if i press the horn aggressively, for now i got it disconnected at a recent service at solitare honda ,
PS : I was impressed at how the car felt after the service - more on the experience later.
Hey Desmo -
The Power window motor cost 900 bucks got it replaced a couple of months back but without the auto up option, i had even put one costing 1500 for the driver side window without auto up.
PS : just got a KNN intake installed 3500 (conical) + 2000 (plumbing)
the car feels superb now
Old 24th April 2012, 18:13   #839
infotech58's Avatar
Thanked: 217 Times
where did you buy that power window motor from? driver side power window motor of my car winds up slower than others and may stop working some day.
infotech58 is offline   Reply With Quote
Old 24th April 2012, 18:21   #840
Thanked: 38 Times
From Juhu , a know mechanic of mine got and fixed it for me . but no auto -up .
Rs900 for parts , i will ask him and let you know on friday.
ryan_wheelz is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
