Old 14th April 2009, 18:21   #76
ssjr0498's Avatar
Thanked: 118 Times
Give Magnum a try, they are good!!
I gave my car over there, the experience was good!
Shrey
ssjr0498 is offline   Reply With Quote
Old 14th April 2009, 19:34   #77
Shan2nu's Avatar
Thanked: 81 Times
By the way, when would the clicking/scraping sound come?
It comes only when the A/C compressor clutch is engaged. So even if you switch on the A/C, the sound will come initially but when the clutch auto-disengages, it goes away.
And if you run with the A/C off, it shouldn't come at all.
Shan2nu
Old 14th April 2009, 23:20   #78
SS-Traveller's Avatar
Thanked: 10,438 Times
Originally Posted by Tejas@perioimpl View Post
Can the compressor oil be put by myself or i need to take it to the AC guy?
Yes, the OHC has a Denso compressor and my AC guy said the same thing as you and quoted half the price at 18,000. I just don't feel like spending 18K on a car which i plan to sell of within a year or so.
The compressor oil can be put in by the AC guy himself. It's a very thin oil, like our airotor lubricant. Let him put in the oil and see if things improve.
I know - shelling out 18k hurts. But that's better than 35k. Try to get a hold of a refurbished Subros or Sanden compressor from a second-hand market - should be for 4-5k, and good for a year at least.
How much did you pay for the idler pulley? How to test that it has been spoilt?
By how much percentage would you say your vibrations have gone down?
Checking the pulley and clutch is another option, but a faulty pulley usually damages the belt too, and the vibrations increase, not disappear, when revs go up.
BTW, is there any loss in cooling efficiency in your AC yet?
Old 14th April 2009, 23:50   #79
Originally Posted by amitoj View Post
...right side, under the hood
I vaguely recall that it was diagnosed related to the weak ac compressor. Somehow i've learnt to live with it most of the times. But at times it gets a bit annoying.
Have you checked for power steering pump noise? Feel with your fingertip the pressure hose leading away from the pump, and the scratching/rattling will translate into a vibration in the hose.
Old 15th April 2009, 11:31   #80
Tejas@perioimpl's Avatar
Thanked: 4,721 Times
Will try that.
Then i guess this is not the problem since the vibrations disappear as the the revs cross 1200 rpm.
Nope, no loss at all in cooling efficiency at all.
Tejas@perioimpl is offline   Reply With Quote
Old 15th April 2009, 18:39   #81
Thanked: 78,546 Times
Guys, the Vtec's power steering rack is known to develop a leak after 6 - 7 years of use. You could either repair or replace it. More details on repair options here (REPORT with PICS: Refurbishing my OHC Vtec. And some mild performance mods!).
BTW, my original O2 sensor is still working alright.
Old 16th April 2009, 10:26   #82
I own 1.5 Exi AT 1998 model (Honda City). It has done 100,000 Km. One problem i faced was that my car is very slow in overtaking can this be improved? can i gain more power without disturbing the engine?
Is it advisable to enlarge trottle body on AT.
My current setup
FFE from Automech
K&N Stock Replacement Filter
Tri Phase
Spit fire wire
Iradium Spark Plugs
Strut braces
Future Mods
CAI
Porting Polishing
dhananjay is offline   Reply With Quote
Old 16th April 2009, 14:30   #83
ankitahuja's Avatar
Thanked: 46 Times
I got an extensive service of my OHC done about 3-4 months back. The throttle body was also cleaned with injectors + the works.
I noticed that whenever I press the accelerator harder than normal, the engine has started knocking. It's fine if I drive with a light/normal foot but as soon as it's depressed a wee bit extra, the knocking starts. No loss in power though.
I think it's to do with the throttle body cleaned and the BIG UGLY HPMS WIREMESH filter sucking in a lot of air. Can that be possible? What else can I check for?
Old 18th April 2009, 20:32   #84
Seems odd - how do you have an engine knock without loss of power?
Sucking in a lot of air will never make an engine knock.
Can you try to explain in little more detail the knocking that happens? Do you still have that knocking if you downshift? Are you lugging your engine?
Old 19th April 2009, 12:39   #85
Rehaan's Avatar
Thanked: 21,786 Times
...I think it's to do with the throttle body cleaned and the BIG UGLY HPMS WIREMESH filter sucking in a lot of air. Can that be possible?...
Hey Ankitahuja,
I suggest you try this procedure and see if it solves your problem : http://www.team-bhp.com/forum/techni...resetting.html (Basic ECM Resetting)
cya
R
Old 20th April 2009, 00:06   #86
ankitahuja's Avatar
Thanked: 46 Times
I know it's a bit odd. The engine would just give out a lot of cluttering sound, referred to as engine knocking. Believe it or not, I feel absolutely no loss in power output.
It does not matter if I downshift, the knocking is heard when the gas pedal is depressed a bit more than normal (moderate to heavy foot). This remains on all gears except the 1st.
Sorry, but what does "lugging the engine" refer to?
Hey Ankitahuja,
cya
R
The ECU under went a hard reset (with the help of an OBC scanner). So I'm not sure if resetting it again can resolve this issue. I did reset it again by disconnecting the -ve terminal of the battery, but this issue remains.
Old 20th April 2009, 08:22   #87
ImmortalZ's Avatar
Thanked: 137 Times
Lugging the engine is basically driving the car in a gear at an RPM that is too low for that gear. You get this vibrating feeling from the engine and all round "Please shift down, for the love of all things automotive!" noise from the car.
Old 20th April 2009, 10:20   #88
amitoj's Avatar
Thanked: 1,573 Times
Could it be a loose joint or clamp in the exhaust somewhere?
amitoj is offline   Reply With Quote
Old 20th April 2009, 11:34   #89
His Highness's Avatar
Originally Posted by vishnuvijay View Post
Hi, I just bought a 2003 Honda City VTEC Type II after selling off my 2001 Honda City 1.3 EXI. I want to more about the car. So I put up a small set of questions which I hope type II VTEC owners would answer.
1.Max speed you have achieved.
2.Fuel efficiency - city, highway, overall.
3.Problem prone areas of the car.
Ok, Silly question here guys. How do I know if my 2001 March OHC ( Type-II) 4AT has a VTEC engine or not?
His Highness is offline   Reply With Quote
Old 20th April 2009, 11:45   #90
Akshay1234's Avatar
Thanked: 6,057 Times
it dosent. its a normal 1.5.
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 41 5th October 2015 21:18
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
