Old 22nd June 2012, 19:58   #1006
narayan's Avatar
Thanked: 1,324 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by dhiman View Post
Guys, need some help here. I am sure many of you would have had to replace a panel like the bonnet. So any pointers of how to identify a new vs an old one will be great. Thanks!
i dont think the bonnet is one of those panels a lot of us would have replaced !! but without a doubt your mechanic has picked up a used bonnet from some total loss vehicle, repaired it and giving it to you
narayan is offline   Reply With Quote
Old 23rd June 2012, 11:25   #1007
Thanked: 42 Times
Just redid my handbrake setting this morning.Now lets see for how much time it holds up.Problem is if this setting ain't done right the handbrake keeps getting loose.There is a lock system for the handrake is the rear brake system.If that little lever ends up facing towards the outside the handbrake keeps getting loose.Now lets see for how long todays setting last.The mechanic gave a promise that it will not loosen.
Now another thing is i experience loud thuds when going over a rough patch.I suspect my suspension needs overhauling or replacement.When inquired about the Munjal showa shocks the Garage owner said not to go in for those because most have them sold now are refurbished and sealed and resold.He told me to go in for some twa make.Something like that.Can any one confirm this.
raycers_honda is offline   Reply With Quote
Old 23rd June 2012, 13:40   #1008
jatinpatel's Avatar
Thanked: 191 Times
@raycers
Yes the Munjal Showas you dont brand new all the ones which come in sealed packing are recondionted ones and they dont last at all, have wasted 12k on munjal showas only to later find out that the shocks were refurb ones.
Better to Go for Gabriel or TRW both are excellent.
jatinpatel is offline   (2) Thanks Reply With Quote
Old 23rd June 2012, 20:10   #1009
Thanked: 42 Times
Finally did the exhaust in my OHC. But just the muffler.Costed me 2000+300 labour.It comes with a 6 month warranty.Local make.But seems like good quality and is galvanized.Dont know how much it would help from mild steel.The old one was badly rusted in multiple parts.
Old 23rd June 2012, 23:28   #1010
Thanked: 26 Times
Originally Posted by infotech58 View Post
are you sure it is rubber channel that may be the problem? motor/winding mechanism may turn out to be an issue too.
The motors are not a problem, whereas the whole mechanism has been serviced. The rubber channel is indeed the issue as whenever i spray wd40, its as good as new for some days.
Originally Posted by raycers_honda View Post
I live in santacruz.But normally parts like these i purchase from opera house too !!.
Try chadda auto parts.I dont know the exact address but its on the main road on the right hand side if your facing towards the north.They normally have stuff you dont find anywhere else.Do let me know how much you purchase the window rubber linings for.
I know of chadda. Have tried for the window rubber channels at city motors. They dont stock it. Will try chadda as im going to buy a headlight and the head gasket from opera house next week. So i shall post if i get one.
If you find any shops in the suburbs who have the window linings, please let me know .
Btw, many owners have replaced their suspension setup and have indeed purchase genuine ones. As far as i know, the manufaturing date is printed on them. Search for some suspension overhaul threads.
seedyk is offline   Reply With Quote
Old 24th June 2012, 09:41   #1011
prateek_ch's Avatar
Originally Posted by fuel_addict View Post
Yes, you can have the belts checked before you go for an ignition coil change. You will hear a distinct noise if the timing belts have slackened or going bad. How many kms has your car done? If you are experiencing this sluggishness in the lower gears (1/2/3), it might be more of an ignition coil issue as your spark plugs were recently changed.
Hey I got the belts and the ignition coil checked. The ignition coil came up fine and was supplying a healthy voltage. The timing belt was worn out and the tensioner bearing/pulley too. Got both of those replaced. The has been an improvement in the cars pickup. I have also changed the fuel this time around from HP to Shell. Car feels smoother. Don't know if this is my mind playing games. The car is going to touch 40k. Ya just 40k.
prateek_ch is offline   Reply With Quote
Old 25th June 2012, 15:44   #1012
Thanked: 56 Times
For the rubber channels just go to Girgaum church, take the right just after the church n 50 m on the left is a shop called "Naunidh Motors". Speak to Jagjit Singh. He will give you what you need. I got my window channels replaced from him. They work superbly now. Costs 900 per window channel.
Mob: 9821364944 9323853944
Vandit is offline   (3) Thanks Reply With Quote
Old 25th June 2012, 22:20   #1013
Thanked: 26 Times
Whoa man ! thanks a lot ! Going there tomorrow itself to get these !
You sure that these are the type 2 ohc ones right ?
Old 25th June 2012, 22:41   #1014
Thanked: 56 Times
Affirmative. Got mine for my 2000 type II OHC. No problems at all. Had the same issue as you with the front channels. The rubber was old n worn. So got it replaced from him before the rains. No worries. He's reliable.
Vandit is offline   (1) Thanks Reply With Quote
Old 27th June 2012, 00:21   #1015
Thanked: 42 Times
Saw This OHC yesterday, with a custom job done for fog/Ancillary lights.
It was put on a bracket with the wiring neatly done.The stock fog lamp cover/panel was intact.From far it looked like a neat job.Even from close too until you see the exposed wiring.Now maybe that is waterproof and well covered with electrical tape.
Only disadvantage i see is it sticks out a bit which in turn might get damaged easily.
(sorry for the bad quality of pics.I clicked them from my phone)
Old 27th June 2012, 01:05   #1016
Thanked: 26 Times
Update: after analysing the car today, only the tappet cover had hardened and hence the oil was leaking out.Whereas the CEL was due to the iac valve I suppose (the rpms were uneven for the past few days). Anyway had a doubt whether the head gasket had blown as it didn't shows any symptoms and it indeed hadn't !
Got the following from chadda motors at opera house:
Tappet cover : 550
Three bond tube (to seal the gasket) : 100
Window channel (rubber linings- yes they have it in stock for the type 2 city): 850 for each front window
Head gasket ( didn't buy it though) : 1400
Depo headlight (didn't buy) : 1800per piece ( this was 1350 six months back :o )
Further enquired about munjal showa shocks but they said they aren't available, a fellow member pointed out the same. Instead they asked me to buy the equivalent known as 'excel power' for 2.3 a pair ! Same was said for lower arms. Some chinese make ! What's with the original stuff vanishing ?
Old 27th June 2012, 08:26   #1017
Thanked: 56 Times
Reminds me,i need to get my headlights replaced too.
Also it appears I'm going to need replenishing the steering oil every two weeks cos of the leak. The trouble is,i don't know if us the entire steering rake that needs to be overhauled like my mechanic says... For really 7k our is it just a case of a simple oil seal replacement which would be no more than 800 bucks.
Does anyone know how to tell?? Or is the mechanic just trying a rip off?
Vandit is offline   Reply With Quote
Old 27th June 2012, 10:50   #1018
Thanked: 42 Times
Just get your underbody washed thoroughly.Then check from where its leaking.Incase its a crack in the frame then that would be sad sad news.Otherwise its just the problem of the oil seal.
Only way to find out is by going ahead and replacing the oil seal first.And then if there is a leakage you'll know.
Old 27th June 2012, 11:24   #1019
Thanked: 26 Times
Please let us know where you getting the headlights from. It would be helpful if the price for each left and right would be shared. Thanks.
Old 27th June 2012, 11:49   #1020
toiingg's Avatar
Thanked: 74 Times
Get Monroe shocks, easily available and good stuff.
toiingg is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
