Old 5th September 2012, 04:43   #1171
infotech58's Avatar
Thanked: 217 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by raycers_honda View Post
Attachment 980932
Danlalan and ksmvtec had shown me one guy who I might possibly go to after the monsoons.
I plan on keeping her for at least two more years.
It is a very common problem with OHC. A simple repaint might not address this, and may require detailed tinkering. Also open the door panel and look at the frame there, it may require attention too.
infotech58 is offline   Reply With Quote
Old 5th September 2012, 16:03   #1172
Thanked: 9 Times
There is some leak in by ohc's boot , The carpet is wet and the cardboard that covers the spare wheel also is wet on both the inner corners near the suspension, there is no visible crack on the boot beading and since it is on the other end leak from tail lamp is is ruled out , any other possible source ? There was some water in the spare wheel well .
vinu_pm is offline   Reply With Quote
Old 5th September 2012, 19:53   #1173
pranavt's Avatar
Thanked: 274 Times
Was your car ever hit on the bum?
Old 6th September 2012, 12:42   #1174
Thanked: 42 Times
Hey I am facing the exact problem. I have not yet solved the problem. I am waiting for the monsoons to get over and then I will get that particular area welded.
In my case I removed the entire rubber beading. On removing it I realise some part was rusted. The other side was looking fine but I could see droplets of water seeping through. Now to put a temporary solution to this I applied loads of araldite and also in the other areas along the boot beading. This has partially stopped the water from entering. The second thing that I did to stop the water from collecting in the wheel well was load the boot with newspaper so water gets absorbed by the newspaper. Trust me it does help but only as a temporary solution. The third thing that I did is put a shallow bucket in the area where the leakage happens. All the water collects there. This ensures nothing goes down to the spare wheel well.
Also just in case you were wondering from where u could acquire the cardboard that covers the spare wheel, you could get it from chadda automobile spares at opera house for 450 rupees. I will try and post some picture later on.
raycers_honda is offline   (2) Thanks Reply With Quote
Old 6th September 2012, 14:43   #1175
Desmosedici's Avatar
Thanked: 410 Times
I didnt go hunting for the cardboard since i assumed that i would never get it, so i cut a light plywood and placed it over the sparewheel. i feel that its better that the cardboard.
Desmosedici is offline   Reply With Quote
Old 6th September 2012, 16:50   #1176
Thanked: 42 Times
Yeah it's happened to me many times. The first time it happened I got it fixed and took 8 hours to do so. Fixing the Ohc bumper is quite tricky. I sometimes wish they never made it three parts as its very cumbersome to put them back aligned properly. I have put up some images on this thread do check them out.
I have been hit after that repair but it's not been that bad that I have to repair it but the alignment has gone a bit off.
raycers_honda is offline   Reply With Quote
Old 8th September 2012, 09:46   #1177
Thanked: 9 Times
Spend some time to find the leak in the OHC Boot. It is again proved that OHC bumper is a pain, In fact it from the clip which fix the bumper on both left and right side.Identifying it was quite difficult . There was no clue from outside inspection. So removed the full mat inside the boot and i get inside the boot and asked my wify to close it and pour water from outside using a bucket and mug. She was more than happy to lock me inside the boot .
Look at the images
Any possible suggestion to fix it. In fact this side of bumper is new replaced very recently.
Regarding the OHC Oxygen sensor
If the below is the O2 Sensor, In my 1.3 Dx the denso part number is 2340 2180 . yes it is a four wire one .I bought the car 3 yrs back with 50 K on the odo . Hope it was not replaced by previous owner.As some one mentioned earlier in this thread http://www.densoproducts.com/more_info.asp?pid=2014 will this be a suitable substitute for this part ?
Old 12th September 2012, 09:03   #1178
Thanked: 9 Times
Regarding the O2 Sensor I got a mail from Denso Customer Care saying [FONT=Arial]DENSO OE # of 234000-2180 o[/FONT]n the OHC 1.3 dx is equvalnt to234-4099
Attached below is the mail .
Dear Vinu,
I checked with a Denso technician and he replied:
As for your customer's request, very confused. First of all, 234-2180 would not be an OE part number, since that's our aftermarket part number. Secondly, we've never introduced a 234-2180, so don't know where to go. I'm wondering if your customer has been researching via the internet, and is trying to help. There is a DENSO OE # of 234000-2180, registered to Honda, which equals a 234-4099. Can you please ask your customer, First, 'How many wires are on your sensor?'. If the answer is four, next ask, 'Is OE number on your sensor actual 234000-2180, and you excluded the 000?' If the answer is yes, then the 234-4099 is your answer. If no, have your customer drop back 15 yards and punt, because I have no idea how I can further assist them, since, nothing adds up.
Please advise.
Yvonne Priaulx
Customer Service Manager
888-800-9629
951-672-8501
951-672-0759 fax
Old 12th September 2012, 17:51   #1179
KSM-Vtec's Avatar
Thanked: 440 Times
Guys just wanted to know how the CNG OHCs are performing, anyone here with an CNG kit installed?
How much is the power loss in city driving conditions?
What is the impact of the extra weight in the boot?
Any check light or other mechanical issues?
Whats the efficiency like?
Any other feedback?
KSM-Vtec is offline   Reply With Quote
Old 12th September 2012, 20:19   #1180
funkyp's Avatar
Thanked: 97 Times
Originally Posted by infotech58
yep. OHC is a gem and this thread proves it; sadly, i've to put it up for sale due to relocation out of India.
Hey did you manage to sell the car? What price? I have transported my car to bangalore and will be putting it up for sale. Wanted to get an idea of the price to expect
funkyp is offline   Reply With Quote
Old 13th September 2012, 06:31   #1181
infotech58's Avatar
Thanked: 217 Times
I posted and AD with asking price of 3 lac and the best offer I got was in the vicinity of 2.65 lac but keep in mind that my car was in very good condition. I eventually ended up not selling OHC and sold my Lancer for a petty sum (I had to sell at least one of these two cars) and my OHC is now with a friend of mine in Mumbai who'll use it occasionally to keep it alive.
Old 13th September 2012, 15:51   #1182
Thanked: 410 Times
I think you get a Silicone based Sealant Spray which is transparent and provides a thin layer of coating that prevents water from seeping in. I have not used it but plan to check with 3M. They should be having it. Have read in some thread that these provide the necessary water proofing although temporary in nature.
Desmosedici is offline   (1) Thanks Reply With Quote
Old 16th September 2012, 15:55   #1183
Thanked: 26 Times
Im facing a similar issue.
The boot is leaking beyond imagination. Just removed my rear seat today, and it was soaked in water.
The leakage is in the same place, ie the rubber beading for the boot as it has caught rust.
Tried mseal, but it is still leaking from around it, may be the silicon thing might help.
Please post as and when you find a solution.
Dear Vinu,
Please advise.
Yvonne Priaulx
888-800-9629
951-672-8501
951-672-0759 fax
The OE denso on my ohc 1.3 dx (2003 model) is 234000-2180. Have a picture too, if you need it.
seedyk is offline   Reply With Quote
Old 16th September 2012, 22:46   #1184
Thanked: 42 Times
My car was leaking where the rubber beading area is. But not anymore.I removed the rubber and got the rusted parts removed and re-welded a another metal plate onto it. It was a job that got done in less than two hours with a coat of paint to match and costed less than 600 bucks.
Now the leakage has stopped completely.
You can try that. If that does not work then I guess you have to replace your rear window lining.
Old 17th September 2012, 01:53   #1185
Thanked: 26 Times
If possible, can you please post a picture of the part where the leakage was and also a pic of the welding done, will help me to a great extent.
Well, my rear window isnt leaking, sure about that. Im going to try and seal the rubber gasket which surrounds the boot with 3 bond tube.
If this doesnt help, will have to go your way !
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
