Old 17th September 2012, 11:08   #1186
Thanked: 42 Times
Originally Posted by seedyk View Post
If possible, can you please post a picture of the part where the leakage was and also a pic of the welding done, will help me to a great extent.
Well, my rear window isnt leaking, sure about that. Im going to try and seal the rubber gasket which surrounds the boot with 3 bond tube.
If this doesnt help, will have to go your way !
I will post the pics up tonight.But i would be able to take pics of the finished job only.Also can you remove your rubber beading and post a pic of the area.
I had a small problem in the front of the car just under the passenger sun visor. On a heavy rainfall day i could see a damp spot at the corner. On the outside i put araldite and the seepage stopped completely.I suspect in areas like these the silicon sealant thats factory fitted develops cracks over the years.
Araldite helps in so many ways. Its always good to keep a pack or two.
raycers_honda is offline   Reply With Quote
Old 17th September 2012, 12:17   #1187
Thanked: 84 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by KSM-Vtec View Post
Guys just wanted to know how the CNG OHCs are performing, anyone here with an CNG kit installed?
How much is the power loss in city driving conditions?
What is the impact of the extra weight in the boot?
Any check light or other mechanical issues?
Whats the efficiency like?
Any other feedback?
Hello
With CNG car performs fine enough for daily commute to work. Dont expect the joyous ride of petrol from CNG.
Cant tell precisely about power loss, but its easily felt i.e. while A/c is on, while ascending a flyover, the acceleration and pick up drop is quite apparent.
The engine sensor light turns on as soon as they touch the wiring.
No such mechanical issue.
Efficiency is near 20Km per Kg in city.
I think the cylinder in boot definitely makes the rear lowered but can be managed using a half inch spacer.
The very first issue with the CNG is that there is hard to find an honest vendor who will provide you with genuine components.
Second is the lack of their knowledge about a particular car. They assume system of Honda city just like santro or esteem. or accord to that of accent. One solution for all cars.
Further to add on the apathy the stupid (F) CNG mechanics who think of themselves as automobile experts, all they do is jugaad.
To me it seems a gamble unless you find a real experienced and more important honest hand.
If you want to get you car CNG'd wait few more months for Honda to launch dealer fitted cars (Its a truly reliable news). Honda city will be first followed by Jazz. Otherwise I suggest to go for diesels. Try to avoid screwing your old Gem.
Cheers!
Honda Monk is offline   Reply With Quote
Old 17th September 2012, 12:27   #1188
KSM-Vtec's Avatar
Thanked: 440 Times
Originally Posted by Honda Monk View Post
Hello
With CNG car performs fine enough for daily commute to work. Dont expect the joyous ride of petrol from CNG....... Try to avoid screwing your old Gem.
Cheers!
Thanks Bro!
Honestly i have no budget to buy a new car. Am planning to run CNG on my vtec for a daily 100% commute to office. The good thing is i do not have to take any flyovers but yes the traffic is bad.
Also i am hoping that i will be able to run the car like it was when i select petrol and want to have some fun.
I have identified a really good CNG installation guy and am hopeful that he knows his job well.
Are your efficiency figures with 100% AC in traffic? If yes thats great!
Looking for more feedback.
KSM-Vtec is offline   Reply With Quote
Old 17th September 2012, 12:42   #1189
Thanked: 84 Times
Thanks Bro!
Yes you can enjoy the drive on petrol.
Do go through the whole thread on CNG conversion, better learn before hand about what you are putting your money into.
It was 80% AC in Delhi traffic.
Also I would say do a realistic financial cost benefit analysis of how much are you spending and in how much time will you get break-even point. That way you will also get to know how long you should keep your car.
Do share your experience!
Honda Monk is offline   (1) Thanks Reply With Quote
Old 18th September 2012, 23:42   #1190
Thanked: 42 Times
Here are the pics,
That's the area where the metal was completely rusted. That entire chunk almost up to the glass leaving about 2.5 inches from the corner.
raycers_honda is offline   (1) Thanks Reply With Quote
Old 19th September 2012, 16:14   #1191
cityvic's Avatar
Thanked: 2,583 Times
Guys whats the stock size of the Honda City 1.5exi Wipers?
Planning to get Bosch Aero Twin Blades.
cityvic is offline   Reply With Quote
Old 20th September 2012, 02:12   #1192
Thanked: 26 Times
Originally Posted by raycers_honda View Post
Here are the pics,
Attachment 988063
Attachment 988064
Attachment 988065
WHOA ! This looks like it has gone through a really rough time !
Mine's nowhere close to this, there's no sign of rust from the outside, but its from within, just a tiny place, will click the pics tomorrow morning as ill be removing the rubber gasket and re pasting it with 3bond.
Now im sceptic if water is entering from there, or from the read windsheild
seedyk is offline   Reply With Quote
Old 21st September 2012, 22:15   #1193
Thanked: 42 Times
Removing the rubber gasket and re pasting it might have little or no effect. There is a particular area underneath the area marked in the image I have attached. Check this area thoroughly as there are factory welded joints here that are prone to rusting. I had a leakage from here too. Little Mseal and it worked.
Old 25th September 2012, 00:25   #1194
Thanked: 42 Times
The Suspension of my city is due for repairs. But before I go ahead would like to research thoroughly on what set up is the best in terms of make and their respective durability. Also what would be the cost of the front as well as the rear for complete replacements. And which places do you'll suggest I take her to. Somewhere in andheri,santacruz,bandra,juhu,khar etc.
I the last garage I checked at told me they would put some make called munjal Showa or something like that.
Thanks in advance for helping me out.
Old 25th September 2012, 03:40   #1195
pranavt's Avatar
Thanked: 274 Times
Munjal Showa is OEM Honda. If you can verify that the parts are original and brand new, they are good for a stock Honda being used as a daily driver.
pranavt is offline   (1) Thanks Reply With Quote
Old 26th September 2012, 14:52   #1196
bad_azz's Avatar
Smile Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
hi guys,just got the suspension on my ohc vtec overhauled.Used TRW struts this time and the car feels a lot more planted and tighter.Bought 4 pieces for 7400rs. Also the lower arms, ball joints, tie rod ends were replaced.
The steering rack was leaking so got it overhauled and the oil seals changed.Got the steering rack removed from the car and myself took it to a place in palika bhawan,opposite hyatt hotel.They worked on it for about 2 hours and then tested it and it worked pefectly.And the best part was that they charged only 2500rs for this job and provided a 6 months warranty.Normally,garages charge no less than 6-7k for a similar job.I paid 7500 for the same job last time at a private garage and it leaked again in a few months.So getting it done for 2500rs was a very good deal.
bad_azz is offline   (1) Thanks Reply With Quote
Old 27th September 2012, 18:05   #1197
Thanked: 9 Times
Good to hear that you got a nice deal.
Me too want to replace the lower arm , What is the cost of it and which brand ?
By the way any idea about the cost for Munjal Showa struts
vinu_pm is offline   Reply With Quote
Old 27th September 2012, 23:32   #1198
Thanked: 84 Times
Could you share where did you get the overhaul work done?
Thanks!
Old 29th September 2012, 17:33   #1199
Thanked: 84 Times
Fellas
I have posted it earlier but to no reply from fellow Bhpians, so have to put it again.
How can one check if the cat-con is choked? I mean symptoms and signs.
Also what difference does it make if I remove it altogether rather replacing it.
Waiting for your response.
Thanks!
Old 1st October 2012, 00:41   #1200
Thanked: 42 Times
Has anyone put any ancillary lights in the cabin. The standard I have are the roof light and the reading lamp at the back.
In my Ohc I have put under dash lighting. I'm looking for something to replace the roof lamp. Maybe change the bulb or change the fitting etc. I'm not looking for some cheap stuff like in the taxi's. I want something which would look neat and of good quality.
If any of you'll have any ideas or done anything similar do post some pics up here.
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
