Old 16th October 2012, 20:50   #1231
di1in's Avatar
Thanked: 92 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
I have been having frequent issues with:
1. Front lower arm
2. Bushes
and recently 3. front wheel Bearings
The mech says that my wheels are too big for the car.
Car: 1.5exi OHC 2002
Wheels: 195/55/R15
Could someone please let me know if I should down-size wheels, or is there some other way to get rid of this problem.. stiffer suspension (just a wild guess) ?
di1in is offline   Reply With Quote
Old 17th October 2012, 17:59   #1232
Thanked: 84 Times
1. Front lower arm
2. Bushes
I believe stiff suspension can partly be blamed for that.
What make you used for lower arms? I can say that the replacement must not have been an OE one and the after market lower arms are kind of unreliable. I have changed mine twice.
Bad roads could also be the culprits.
Honda Monk is offline   (1) Thanks Reply With Quote
Old 17th October 2012, 19:09   #1233
ankitahuja's Avatar
Thanked: 46 Times
1. Front lower arm
2. Bushes
Wheels: 195/55/R15
Bad suspension frequenting is mainly due to:
1. Bad roads
2. Low profile tyres – 55 is not too good, but not as bad as 50 profile. 60 profile is ideal.
3. Lots of dust for the bushes to tear. Irregular cleaning of the car (my opinion).
4. Bogus suspension parts
5. Driving style
Front wheel bearings are only wear due to time. Did you have these replaced ever/recently?
ankitahuja is offline   (1) Thanks Reply With Quote
Old 18th October 2012, 13:32   #1234
di1in's Avatar
Thanked: 92 Times
1. Bad roads
5. Driving style
Car is throughly cleaned weekly, and exteriors are wiped once a week.
The tire profile do worry me, but I can't increase the profile without downsizing.
I have never changed the bearings on the car, it's run just short of 2 lakh kms now.
I am not sure what make the arm was, but it was done at a local garage so don't think it's OEM. I guess that explains it.
Old 18th October 2012, 22:28   #1235
Thanked: 42 Times
Now that the "no tints" rule is firmer than it was before. I have to head this weekend to the garage or car accessories guy to remove my dark tints. Trust me they are really dark. Though from an angle it becomes slightly translucent. But the best part is the ac cools brilliantly.
My question , is if any one has put those window curtains in their Ohc. The ones similar to the German cars. This company called amritas has them. But they are Delhi based. Let me know if anyone has suggestions.
raycers_honda is offline   Reply With Quote
Old 19th October 2012, 00:12   #1236
Desmosedici's Avatar
Thanked: 409 Times
Some other brand known as PA is also available but not for all models. If I get time I shall check over the weekend and inform.
Desmosedici is offline   (1) Thanks Reply With Quote
Old 19th October 2012, 18:25   #1237
johnda's Avatar
Thanked: 11 Times
I have been having frequent issues...
I had a similar issue, I went from 15" back to 13"(stock)now it feels like driving on a pillow.. too good. I replaced the tie rod and conditioned the suspension. some boot changes etc. Now its a breeze. I think you must downsize for ride comfort.
johnda is offline   (1) Thanks Reply With Quote
Old 20th October 2012, 10:29   #1238
di1in's Avatar
Thanked: 92 Times
I know, but the wheels look good better when they're bigger -- kind of caught between looks and comfort. If there weren't these mechanical issues I would definitely have stayed with 15"..
Old 20th October 2012, 13:24   #1239
frequentflyer's Avatar
Thanked: 33 Times
Originally Posted by Screwdriva View Post
I bought a pair of fog lights for my Vtec today. I was so impressed with its OEM like fit into the stock bumper that I felt compelled to post here. I would say it is a 99% OEM accessory and it looks factory installed. I found it at Sainath Motors, Khar, Mumbai. Even the on/off switch looks exactly like the OEM rear defogger switch. The projection, fit n finish and quality is outstanding. If you want one, speak to Rishi the owner and he'll get you one for Rs. 4500/-. Tell him Aviv sent you.
The Honda dealer in Pune says if you add an accessory like fog lamps, the warranty will be void. Have you had the same experience in Mumbai too?
frequentflyer is offline   Reply With Quote
Old 20th October 2012, 19:36   #1240
ankitahuja's Avatar
Thanked: 46 Times
Then what's wrong with 14"?
15 inch with 50 profile is a suspension killer (I changed thrice).
I recently shifted to 195/55/15 for the front wheels only and it makes a considerable difference from the 50 profile. I can see the suspension holding up much better.
The only downside is the speedo error which is outside the recommended limit. Gives no issues whatsoever otherwise. Do this!
Old 20th October 2012, 21:17   #1241
Screwdriva's Avatar
Thanked: 370 Times
195/55/15 would be my choice too. I dont think warranty is a problem given my car is 10 years old
Screwdriva is offline   Reply With Quote
Old 21st October 2012, 23:04   #1242
Thanked: 42 Times
Finally found the window curtain thingy I had mentioned earlier. It's available at reliance mall in santacruz,Mumbai.
It's grey in color with perforations. Seems to be of a decent quality. Cost 450 for a pair. Only downside is has to be fitted with those suction clips.
raycers_honda is offline   (1) Thanks Reply With Quote
Old 21st October 2012, 23:36   #1243
Thanked: 84 Times
Hey ankit what's the update on your car?
You found new workshop on Sohna road? Share the details of the garage.
Honda Monk is offline   Reply With Quote
Old 22nd October 2012, 12:12   #1244
Thanked: 9 Times
This info helped me to take the decision of not going for a 15" steel Rim from ANHC as some one was selling it for cheap. I thought it will improve the GC but my already week suspension I dont want to give it more strain . By the way how much the tie end rod cost and the split up cost, from where did you re conditioned the suspension . Am at cochin, do you know some reasonable one at cochin doing it.
vinu_pm is offline   Reply With Quote
Old 22nd October 2012, 12:25   #1245
johnda's Avatar
Thanked: 11 Times
Vinu, good to put ride above looks in this area.
I got my work done at coimbatore, if you are driving that way, please contact me i'll PM you the location and garage details. It cost about 1.5k for the tie rod end. Kumar did the job. How long are you going to be at cochin?
johnda is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
