Old 24th October 2012, 12:06   #1261
Thanked: 84 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by bad_azz View Post
Last time i paid almost 28-30k at a VERY reputed and popular garage in gurgaon for the same job.they overcharged me for the spares and i paid almost 12-14k as labour.
very well said azz... quality spare is what makes a job right with a decent workmanship off course. It kind of loot 12-14 K for labor
One more query, does that palika bhawan do a complete steering job including dismantling-repairing-refixing work. As its a little hassle to get it removed at one place and repaired at another.
I have heard about a good steering work guy in nehru-nagar (near lajpat nagar), any idea about it?
For the top speed on the old beast, I have recenty done 135, 120 and like, I must say at 135 I started losing confidence whether the car will be able to handle anymore. Nonetheless it is still a lot of fun to push it.
I sometimes wish had it been a RWD, it would be nascar everyday!
Honda Monk is offline   (1) Thanks Reply With Quote
Old 24th October 2012, 13:51   #1262
OHCVtec's Avatar
Thanked: 12 Times
Originally Posted by raycers_honda View Post
I was curious to know the top speeds you'll have reached in the Ohc.
Top Speed 160 on the Mumbai Pune Expressway. I do not recommend going to those speed on the OHC.
OHCVtec is offline   (1) Thanks Reply With Quote
Old 24th October 2012, 18:04   #1263
pranavt's Avatar
Thanked: 274 Times
Heading out for the weekend. Considering the Ohc that most have have is almost 10 years old. I was curious to know the top speeds you'll have reached in the Ohc.
I'm not here to beat those top speeds,I normally drive on the expressway at around 100 max. Never really pushed her above those speed. But was just wondering what the capabilities are.
Also what's the average tyre pressure required for the expressway. I ride in 195-60-14.
175kph, but with upgraded suspension. 195mm tyres on stock rims.
pranavt is offline   (1) Thanks Reply With Quote
Old 24th October 2012, 18:55   #1264
di1in's Avatar
Thanked: 92 Times
While the recommended tire pressure is 30psi for the highway, Shan2nu has mentioned that he has got amazing fuel efficiency with 34psi on 195/60 tires and a refined driving style.
Read here: http://www.team-bhp.com/forum/techni...ml#post1398980 (OHC Fuel Economy Issues)
Hope this helps.
di1in is offline   Reply With Quote
Old 25th October 2012, 13:32   #1265
ryan_wheelz's Avatar
Thanked: 38 Times
Back in 2010 , when i just got the car, (stock condition) 86k on odo, serviced the car and took her on the expressway at night , achieved 185kmph in the tunnel , I have never tried doing that again !
Now after some mods KNN & FFE i find it difficult to cross 150Kmph,
Cheers!
ryan_wheelz is offline   Reply With Quote
Old 25th October 2012, 13:36   #1266
Thanked: 38 Times
Hey Guys,
Can you please help figure this for me ..
So this red light which turns on when the hand brake is pulled , is always on even when i put the handbrake down ,
any idea what may be the problem.
Old 25th October 2012, 14:56   #1267
Thanked: 84 Times
Not a serious issue ryan, as it appears. Just an adjustment of the signal transmitter.
Get it checked at any decent workshop and its a 15-15 mins job.
How is your OHC keeping up? Any other issues?
Honda Monk is offline   Reply With Quote
Old 25th October 2012, 20:00   #1268
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by Honda Monk View Post
Brands for shocks and other spares?? I had put TRW last year, found them quite hard for Indian conditions.
It would be good if you could share with us the cost of engine work.
Shockers were Munjal Showa. Had the option of TRW but I've always been told against them. Gabriel was another option.
Lower arms I do not remember, will check and re-post. Piston rings were NPR and valves were Kirloskar. Genuine Honda packing etc., Gates timing belt.
There is another thread that talks about the top speed attained and a lot of OHC owners have posted. Search and you shall find it.
Originally Posted by Desmosedici View Post
Top speed of 160 on my Vtec which was very scary. It could do more but I didn't think its sane. Done that only once. I maintain 100 - 120 on expressway. I generally keep 30psi and recheck again before heading back. I guess my tyres are 185/65 14 on stock alloys.
30 psi is good!
Old 25th October 2012, 23:57   #1269
Thanked: 84 Times
Showa original!?! I have been told they are only refurbished available in market. That is why I had to go for TRW.
Please share the shop info. and cost of shocks, I am looking to change soon.
Old 26th October 2012, 14:00   #1270
ankitahuja's Avatar
Thanked: 46 Times
Rs 3600 or Rs 3800 for the set of front one's. Sourced from Tamanna Auto itself.
If you want something else, I can get them for you from Kashmere Gate, should be cheaper than this.
I have the rear shocker bush kit for both sides if anyone is interested in buying it for cheap please let me know.
Old 26th October 2012, 14:44   #1271
Thanked: 38 Times
Thanks Honda Monk ! I'm relieved !
My OHC has just crossed the 1lac mark , doing fine !
Recently replaced the disc pads and belts from a local mechanic = Rs 1500(some squeaking noise exist when i brake now)
Back suspensions needs to be changed-any suggestions which brand & cost?
Gears are getting sticky - does it need a clutch replacement.
The car goes to Solitare honda every 4 months for a tune up and oil change the bill does not exceed Rs1500
City average 8 kmpl with ac 70% on
Latest installation
Head Unit - DEH-P4200UB (removed the JBL 333 )
Projectors
Woofer (Focal in vented box)
A Pic of her
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-20120926img_4852.jpg
ryan_wheelz is offline   (2) Thanks Reply With Quote
Old 26th October 2012, 21:34   #1272
ankitahuja's Avatar
Thanked: 46 Times
Latest installation
Projectors
A Pic of her
Nice, neat looking OHC. 8 kmpl is pretty low in my opinion!!!
Which brake pads did you get? I got BOSCH for mine this time around for Rs 1050, always used to NISSIN otherwise since they never screech. BOSCH are doing good too, just hoping that they should not start squealing in time - hate that!
Clutch replacement could be possible. Replace gear oil if not done ever.
I just got the clutch bearings changed last week for the first time ever. Clutch plates etc were in perfect condition.
Old 27th October 2012, 22:19   #1273
Thanked: 84 Times
You are welcome friend!
and Yes you have got a really neat looking car.
Regarding rear suspension, there are only struts and bush kit to be replaced.
For shocks you can go for Munjal-Showa (if you can procure new as market is flooded with refurbished ones) or KYB is also there. I am using KYB (Gas filled) for one and half year, ride is marginally stiff but I am liking it.
Bush kit can be procured of any decent local brand as your reliable mechanic suggest.
Flush the gear box and fill with fresh oil. Use OE, I hope you can get it at H.A.S.S.
That is an impressive cost of tune up at Honda. I believe that doesn't include oil cost off-course!?!
Yes non-OE pads make screeching sound. I am also using bosch since last replacement. It made some noise after 500Km something but later stopped itself.
Please do keep sharing the experiences.
Old 29th October 2012, 01:18   #1274
cityvic's Avatar
Thanked: 2,584 Times
For all the FE People
VTEC & Picture Courtesy: Shantanu
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-vtec.jpg
cityvic is offline   Reply With Quote
Old 29th October 2012, 11:07   #1275
Thanked: 84 Times
What have you done with the car!?!
When was this picture taken?
If OHC is giving such a good FE, WHERE is the need left to buy a diesel car!
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
