Old 2nd November 2012, 13:58   #1291
Dr.Sav's Avatar
Thanked: 39 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by raycers_honda View Post
I was curious to know the top speeds you'll have reached in the Ohc.
Originally Posted by Desmosedici View Post
Top speed of 160 on my Vtec which was very scary.
My 2000 OHC 1.5 EXI has reached 180 on the stretch between Nipani and Kolhapur. After that it vibrates a bit but we've all felt pretty secure. We had a full car (4 pass + me), full luggage, a full LPG tank and almost full petrol tank at that time. Never reached that top speed again but 170 is doable on that stretch without any stability issues. And yes, I drive mostly at night so the roads are pretty deserted.
In the city, I would rarely cross 100. But then it all depends on situations, traffic, road conditions, etc.
Needless to say, I'm a Team-BHPian so naturally a safe and lawful driver.
Dr.Sav is offline   Reply With Quote
Old 2nd November 2012, 14:20   #1292
sagarpadaki's Avatar
Thanked: 1,330 Times
100 inside city is definitely unlawful even if you cross it rarely
sagarpadaki is online now   (1) Thanks Reply With Quote
Old 2nd November 2012, 16:55   #1293
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by _raviShankar_ View Post
Its high time that i get new tyres for my OHC. Planning to do it this weekend. The car is running on stock size tyres 175/70-R13 Apollos. I want to switch to 14 inchers. I believe the correct upsize is 185/60-R14.
Since i am on a tight budget i am looking for Yokohoma A Drive, Apollo acelere or MRF zlo (not sure if this size is available). Please suggest which ones should i go for ?
Are there any other brands which i should consider ?
Isn't 185/65/14 the correct up-size! Then comes 195/60/14. Get Yokos or Michelin. Basically, I'd say, suit your pocket!
Originally Posted by sanket91 View Post
When I was there I took it to the mechanic who ran the engine and petrol washed under the bonnet to find the leak but he was unable to find it. Didn't check the belts but all pipes seem to be fine. Also the coolant levels are fine. AC needs to be checked and I am going to do that once I get home in the meantime any more suggestions?
Check the mechanical parts. Could the dampers be shooting oil, or the axle?
Do these splashes come everytime you drive?
How does one get the space to reach a 100 in the city anyway? Unless it's very late at night!
Old 2nd November 2012, 17:23   #1294
Thanked: 84 Times
I had the same doubt, BUT we also have G.Noida Expressway, I have touched 140 there.
We can't think of Gurgaon expressway definitely, no one knows where you may find a stationary truck in mid of road or a tractor, as we have seen it all.
Honda Monk is offline   Reply With Quote
Old 2nd November 2012, 18:05   #1295
Dr.Sav's Avatar
Thanked: 39 Times
Here, in Mumbai, I travel to Dadar on a regular basis in the morning and return back in the afternoon. I would say most vehicles cross 100 easily on the Eastern Express Highway.
Old 2nd November 2012, 19:35   #1296
Thanked: 16 Times
even if its late at night it does not make it any less dangerous for you or the other people on the road. whatever the time, season, car, road; 100 in city is still unlawful.
guptavis is offline   Reply With Quote
Old 2nd November 2012, 23:10   #1297
_raviShankar_'s Avatar
Thanked: 67 Times
I am slightly confused here. I have an OHC 1.5 Exi and when i checked the old recommended tyre up-size chart, it said that the correct upsize was as you mentioned 185/65-R14. THe OHC Vtec (which i assume had the same body parts except the awesome 1.5Vtec engine) came with 175/65-R14 tyres have an upsize of 185/60-R14.
So can i go for any of the above 2 R14 sizes (Conveniently forgetting the odometer calibrations) ?
Still havent decided on which tyre brand though !
_raviShankar_ is offline   Reply With Quote
Old 3rd November 2012, 10:44   #1298
di1in's Avatar
Thanked: 92 Times
What have you done with the car!?!
When was this picture taken?
If OHC is giving such a good FE, WHERE is the need left to buy a diesel car!
The OHC is truly a remarkable car isn't it my best FE with the OHC was 17.3 with 4 people and boot loaded with luggage + ac on the partially bumpy route from Kerala to Bangalore.
di1in is offline   Reply With Quote
Old 3rd November 2012, 11:13   #1299
Thanked: 84 Times
I also own one and have got upto 16 kmpl with 3 (2+1) on board in city driving.
But it have dropped to 11 only and I haven't tried to figure out the reason (as car is running fine). But soon it will be sorted.
Well yesterday I have replaced my Steering pump with another. (My trusted mechanic got one from mayapuri) total job costed 6K. Haven't driven much afterwards, have to see how its working.
Old 3rd November 2012, 16:28   #1300
di1in's Avatar
Thanked: 92 Times
I've never reached those numbers in city driving, my tops in the city is 11, 12 if without AC.. my city average is usually around 10. I think it has got to do with the 15inchers - too big..
Old 4th November 2012, 10:38   #1301
Thanked: 42 Times
I recently did 500+ kms on a full tank. Filled her up with 39 litres of fuel. This was on the morning last week when I went to Pune. Drove down the expressway, drove around Pune city for two days or so, drove back to Mumbai on the expressway, and been driving in the city. All this with the ac on.
I was wondering what the capacity of the fuel tank is. I think it's 45 litres but I'm not too sure. I wanted to know if I coast, does the fuel get cut off or is the fuel still being supplied to the engine. I have read about coasting on the forums but was wondering whether the Ohc had the fuel cutoff thingy when the accelerator is not pressed.
raycers_honda is offline   Reply With Quote
Old 4th November 2012, 14:04   #1302
[quote=ankitahuja;2951552
[/quote]
The suspensions are new.No idea about how the axle can do it. And the problem occurs only while turning on the AC.
sanket91 is offline   Reply With Quote
Old 5th November 2012, 15:04   #1303
pranavt's Avatar
Thanked: 274 Times
Zero fuel is injected during engine braking. You have to leave the car in gear and the clutch engaged. Pressing the clutch pedal will require the ECU to inject some fuel to keep the engine running.
Old 5th November 2012, 15:12   #1304
KSM-Vtec's Avatar
Thanked: 440 Times
Hey Pranav...i agree that some fuel will be injected when the clutch pedal is pressed.
But are you sure that no fuel is injected during engine braking?
KSM-Vtec is offline   Reply With Quote
Old 5th November 2012, 17:43   #1305
pranavt's Avatar
Thanked: 274 Times
Yes, very sure. Closed throttle, high vacuum and higher-than-idle revs automatically puts the ECU into fuelcut mode. I could've just said "Yes" but the spam filter won't let me reply with less than 20 characters.
pranavt is offline   (3) Thanks Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
