Thread Tools
Old 13th July 2007, 10:56   #1 (permalink)
Default Oil consumption in a Baleno
Calling all Baleno owners Vp13, mclaren and the rest. I normally service my car every 5000 kms and find that the oil level is close to the lower indicator at the end of 5000 kms (it is midway after the service). Is this normal? And what is the viscosity grade specified by Maruti for a place like Mumbai?
Floyd de Souza is offline   Reply With Quote
Old 13th July 2007, 11:01   #2 (permalink)
mclaren1885's Avatar
I think the grade of oil is 20W40. Also, I don't think the engine consumes that much oil specially in the 5k km mark. I could be wrong though.
__________________
Phoenix!
Old 13th July 2007, 12:00   #3 (permalink)
Jaggu's Avatar
i dont think 5000 km will cause oil drop, unless its having small leak (check around oil filter) or engine is consuming oil.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 13th July 2007, 18:05   #4 (permalink)
gigy's Avatar
buddy your engine is consuming oil for sure . please check if it is a leak or if its oil burning. get the spark plugs checked. are any gaskets leaking? did you change the type of oil? mineral to semi synthetic to synthetic? was any work done on engine and its accessories in past? how does the engine sound these days?
check if the oil filter is installed properly and the oil drain plug is tight enough. lift the car at any local car wash shop and do under car inspection before washing. wet marks around should show up. while under the car check at the small hole on gearbox at its lower side for mud accumulation near the small vent. this can tell if the engine rear bearing seal is leaking. i had this trouble last week.
__________________
Suzuki Baleno
Old 13th July 2007, 19:07   #5 (permalink)
Ricky_63's Avatar
No matter which car - NO CAR is supposed to consume oil in the normal course of running. 5k is normal service interval mileage (could also be longer). There is something more to it. It merits an inspection by your MASS at the earliest.
__________________
Everybody is entitled...... to an opinion !!
Old 13th July 2007, 20:27   #6 (permalink)
nitrous's Avatar
OT:
Mcl, U use 20W40 in ur redliner baleno??
__________________
youtube.com/watch?v=FiVicNOA3bY
Old 14th July 2007, 00:14   #7 (permalink)
Not sure Nitrous baba. Oil gets filled in the garage. Its not synthetic though. Will be changing over real soon.
__________________
Phoenix!
Old 14th July 2007, 07:35   #8 (permalink)
What's method that you use to check the oil level ? I mean do you check it when the engine is cold OR when the engine has been brought up to normal running temp.?
What does the service manual say ?
Thanks,
rb2399
rb2399 is offline   Reply With Quote
Old 14th July 2007, 10:48   #9 (permalink)
All engines consume oil. The quantum depends on engine size and running conditions. I haven't noticed any oil leak as such and the engine sounds fine. The exhaust at start-up too is fine. As some of you said, it may be that there may be a barely noticeable leak. I shall ask the dealer to check at the next service. Thanks to all of you for your replies. And yes the grade is 20W40.
Old 14th July 2007, 12:02   #10 (permalink)
spadival's Avatar
Thanks,
rb2399
U need to check when the engine is cold.. basically when the oil has settled down.
Also, when we switch to synthetic, Do we need to flush out the existing engine oil ? I don't think we can top up .. right?
spadival is offline   Reply With Quote
Old 14th July 2007, 14:56   #11 (permalink)
2fast4u's Avatar
5k is just too little for so much oil to be consumed
and also 5k is too little for an oil change unless ur time duration is over 4 months for this mileage.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 15th July 2007, 16:55   #12 (permalink)
Ricky_63's Avatar
Well in which case my cars are "different" - coz they do not consume oil. I still think you should get it checked. Your call sire !!
__________________
Thread Tools
ARTICLE: Synthetic oil vs Mineral oil GTO On modifying a car 1148 11th October 2008 02:07
Hyundai Accent 1.5 GLS Engine Oil Consumption Peter Technical Stuff 23 29th September 2008 15:19
Second gen Gypsy (1000cc) compression ratio & oil consumption question xxaarraa Technical Stuff 1 19th November 2007 20:38
Oil consumption after "flushing" rb2399 Technical Stuff 1 29th May 2007 21:23
AC Fuel consumption... scorpio118 Technical Stuff 7 6th May 2007 21:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
