Old 15th July 2007, 10:47   #1
Thanked: 54 Times
Default Optra magnum -Hyundai elantra -same engine ??
HI ,
I had thought of buying a magnum and while comparing cars in the same segment found that the magnum and the elantra have the same engine by VM Motori -both are 1991 cc and develop almost the same power as well as torque . DO you guys know if they are the same engines by any chance ?I would like to know as ,even if GM discontinues the car ,may be the spares can be sourced from Hyundai ?
Old 15th July 2007, 10:53   #2
shuvc's Avatar
Thanked: 283 Times
Could be. @shuvd was telling me that the block is probably the same.
Old 15th July 2007, 10:54   #3
Rudra Sen's Avatar
Thanked: 4,092 Times
Where did you find this? Is there any link?
Old 15th July 2007, 11:03   #4
Thanked: 54 Times
VM Motori S.p.A.
thats the daewoo agreement link and we already know that hyundai sources its engines from VM motori .
Most probably the engine block ,pistons ,cams are the same except the ECM .
even the new embera also has the 1991 cc diesel .
So I guess a ECM swap could probably make the Elantra much faster .
Anwyas I was talking with a guy at Sundaram motors and he says GM over the next few months will be launching the CAPTIVA in the 15 lks price bracket .
Old 15th July 2007, 11:08   #5
manikjeet's Avatar
Thanked: 109 Times
now this is a news to me
i think they share the engine block will confirm and spread more light on it
PS dad works were the head block is made
manikjeet is offline   Reply With Quote
Old 15th July 2007, 11:21   #6
Thanked: 1,503 Times
Both engines are from Detroit Diesel - its only the newer Elantra, Verna etc that have Hyundai's own diesels.
Therefore its quite possible they're the same. However the new Elantra features a 142 bhp engine.
Steeroid is offline   Reply With Quote
Old 15th July 2007, 11:38   #7
Thanked: 9,727 Times
Hyundai sources its engines from Detroit Diesel
Old 15th July 2007, 12:00   #8
shuvd's Avatar
I think that both the engines are same. Same displacement of 1991cc and from the same manufacturer. I have the Elantra CRDi and TD'ed the Magnum yesterday. The Magnum did feel like the Elantra with a few more horses. Now I don't have any idea of the speeds we were doing as the Magnum speedo was disconnected but the engine felt quite familiar. Yes, the clatter was missing from the Magnum and maybe it uses a current gen common rail tech but I have a strong suspicion that the block is same. Gurus, can you shed some light?
shuvd is offline   Reply With Quote
Old 15th July 2007, 12:06   #9
shuvd's Avatar
Sir, agreed. But, the following statement is from ACI July 2007, pg 49.
"The Optra's diesel motor is not designed by Chevrolet or Daewoo, but by another company that was recently acquired by GM; Detroit Diesel that now includes VM Motori of Italy."
@ steeroid - Sir, maybe the new Elantra has the same engine but with VGT. Just like the Embera.
Old 15th July 2007, 12:11   #10
Not anymore - just the first batch of CRDi engines.
1. There are no 'Sir's here - everyone has the same petrol flowing in their veins.
2. The new Elantra's engine is not the same engine with VGT. They offer two states of tune on all their new engines - with vgt and without.
Old 15th July 2007, 12:20   #11
mclaren1885's Avatar
Thanked: 28 Times
Infractions: 0/1 (10)
AFAIK every elantra engine (sold in India) were the Detroit ones. The Verna engines are now a hyundai manufac only.
Old 16th July 2007, 08:31   #12
IMP
It seems that both the engines are same, got this from the VM motori website
"This engine is not currently produced by VM Motori but is produced under license by GM Daewoo and Hyundai M.C. in versions suitable to the respective applications."
here is the link to that page.
VM Motori S.p.A.
IMP is offline   Reply With Quote
Old 16th July 2007, 10:19   #13
artofzen's Avatar
Thanked: 54 Times
I thot GM and Suzuki sourced the diesel engine from FIAT,which inturn sources it from VM MOTORI?
artofzen is offline   Reply With Quote
Old 17th July 2007, 19:35   #14
Thanked: 54 Times
Seems its a case of old bride in a new saree ..hmmz
Old 17th July 2007, 22:12   #15
reignofchaos's Avatar
Thanked: 1,175 Times
AFAIK its the same engine in different states of tune. However the old elantra is a much better handling car than the Optra. No clues as to which will be a faster car on track .
Would you buy the "same car" with "Same Color" as your immediate neighbour? cool.aquarian The Indian Car Scene 39 12th November 2010 13:57
Same Profile, Same Make. But still difference in diameter. Possible? vrooooooom Tyre & Alloy wheel Section 34 13th August 2008 21:07
Civic-Octavia-Optra Magnum-Corolla-Elantra-Cedia Specs and Feature Comparision hitinv Sedans 3 20th June 2008 18:05
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
