| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Apr 2007 Location: Bangalore
| Hi guys , My new one and half month wagon r Duo with immobilzer broke down yesterday .I just drew a km and stopped to pick up some thing from my friend's house and to my horror the car refuses to start both fuel are half tank full.Called the maruti 24hr helpline service the guy took down my complaint and my contact number saying that the mechanic will call me back for the adress,promptly i recived a call from the RNS guys for the adress they came checked all the fuses and battery but now way she wasnt starting ,he told me there must be some electrical fault and this is common it happens all the time ,then he told me he will tow it to RNS motors guy me the recipt and towed it away .Now guys can you plz help me out in this what could be really the probs? Should i place a complaint to maruti HO ? Will i be charged? ( he told me only towing charges) Thanks in advance Shivkumar BS |
| | #2 (permalink) |
| BHPian Join Date: Mar 2007 Location: Sindelfingen/Stuttgart-Germany
| towing by a help line should normally be free of cost. Do not worry, its not turning out to be a major problem, might be just a busted fusible link or faulty earthing.......it is difficult to locate but very simple to fix. I know it pinches , if happens to a new car, be assured it will be allright.
__________________ Arun |
| | #4 (permalink) |
| BHPian Join Date: Sep 2006 Location: Bangalore
| They do charge for towing, but not something very high.. And the problem may be due to the immobilizer. I think there should be someway to reset the immobilizer using the remote itself. I had a similar experience once. The car suddenly refused to start, and not even the cranking sound was there. Called the helpline and the guy at the helpline told me to lock and unlock twice using the remote .After that the car came back to life again. BTW mine is a much old car and so the same may not have worked with your car's system.. Regards Kaushik |
| | #5 (permalink) |
| Team-BHP Moderator ![]() | Well, I have noticed that Duo WR's are not as seamless in operation as perhaps their petrol counterparts. For instance, a colleague's WR Duo used to have its engine malfunction light come on everytime he switched to LPG. This was before the 1st service even. RNS did reset the indicator saying that this was a common occurence in Duo WRs. Now, he's been asked to rev the engine if the malfunction light comes on in LPG - a small "click" sound later - its gone. Not right from Maruti's side I say.
__________________ If you lose your temper, you’ve lost the argument |
| | #7 (permalink) |
| Senior - BHPian | Many guys reported same issue about WagonR Duo. Its expected minor and common issue from Maruti! Last week I saw one WagonR Duo in front of house tried to start the engine for more than 10 minutes and it started after trying again and again to start. Just relax and lets hope for the best, I am sure they will fix it soon. All the best! Ravi. |
| | #8 (permalink) |
| Newbie Join Date: Dec 2006 Location: kolkata
| I have bought Wagon R Duo in Sept' 07, having some or other problem thereafter. I will discuss them in detail later, but currently the main 2 problems are as follows: 1) Sounds under the bonnet - "THUD" sound while starting the car after waiting a while in traffic light, its irregular. My driver opened the bonnet and found that the clamp of the air cleaner has opened, he fixed it. It happened 3-4 times and then we reported it to the service centre in the 2nd service. Mechanic changed it without any fuss, saying that may be air cleaner was not ok. Just 7 days back it happened again and when this time the one of the two clamp was broken, I called the service station guy and told him regarding the incident. He told me to come to the centre for a check up. I will be sending it today? What could be the reason/s? 2) There is some knocking / "KHAT KHAT" sound from steering with maximum turning to right when the car is started from standing position or in minimal speed. This sound is absent when the car is having moderate speed. The service guys are saying the problem is with the 'Diasper' or Axle and it needs to be changed. What do you suggest guys should I go for a change of axle of a new car or wait for some time. What could be the other reasons? |
| | #9 (permalink) | |
| BHPian Join Date: Jun 2007 Location: Kochi
| Quote:
Somebody posted a similar problem, (different car, different model) couple of weeks back here, and it turned out to be a bad mud flap hitting the tyres. So first check the mud flaps. You should be able do it your selves. More so because the problem occurs only when turning right.
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq | |
| | #10 (permalink) |
| BHPian | sallubhai, Khat-khat may be a flap issue, i will leave it to the more experienced ones. the bang bang - SERIOUS ISSUE, its a engine back fire, have you heard of a diwali cracker -phatak- sound from autowallas mostly. It means either the iginition coil has taken in some water or the timing is altered. Please get it checked by a reliable mechanic ASAP or you are going to end up a sad owner. I am saying this by personal experience. Ques - Do you get your car water washed in a authorized maruti place Or a local one. Did you drive through heavily water logged area? Damn - this is the 3rd wagon R DUO I am hearing about this issue. My friends car had the whole Air filter assembly blown away from the intake manifold, turned out the LPG injector had some tiny fault because of which there was a bang-bang every few minutes. Got a warranty job done at RNS bangalore, but at what cost? Who knows what the engine has suffered already?
__________________ Dont wear Helmets & Seatbelts to reach Heaven Faster You hardly have any time left in this world to be a sinner |
| | #11 (permalink) |
| BHPian | hmm.... guess the 'thud' sound which lifted the aircleaner clip is due to timing issue which happens with multiple reasons. Once I faced this trouble immediately after filling Reliance LPG and continued intermitently till the tank go dry! Later when I checked the air cleaner, that was a shocking sight as I could find many burns here and there!!! It didn't showup with IOC/BP LPG's! So I think the quality of fuel has to do something with it! Check it!
__________________ MISSED the action!!! :-( Guess another one has already started happening!! :-) |
| | #12 (permalink) |
| BHPian Join Date: Aug 2006 Location: New Delhi
| I hope he didn't charge for towing. If it's a manufacturer defect they should bear ALL costs and charges. When I had problems with my Estilo, they had the car picked up and dropped from my residence which is about 10 -12 kms from the workshop. No charges.
__________________ People who talk in metaphors ought to shampoo my crotch. -Jack Nicholson As Good as It Gets (1997) |
| | #13 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Hmmm. Towing charges should not be payable as the vehicle is new and it just dropped dead in the middle of the road. Its the manufacturers fault. They should be lucky if the owner of the vehicle did not press charges against them. ![]() As a matter of fact Tata does not charge towing charges in similar cases. They did not charge me long back when my brakes jammed in the middle of the roads and the car refused to budge an inch. |
| | #14 (permalink) | |
| Quote:
Even today at service centre 'Machino Techno' the guys who were handling my car were giving it back to me after changing the air cleaner. But this time luck was not favoring them, there was a thud or phatak sound from the engine when started and I said firmly that I will not be taking the car if the problem is not solved. One Maruti Duo engineer was called up and after checking the tuning of the engine he rebuked all the centre guys who were in charge of the car... it showed something near 20-22. He changed the tuning of the LPG and after doing the whole job the reading showed 62. One very important thing that me and my driver found later that the vibration of the Gear shaft when the engine is running (LPG) but the car is not in motion has gone (This vibration was absent when the car was run in Petrol mode) and the AC sound has gone down considerably!! According to the driver the car has become smoother when being driven in LPG. The 2nd issue regarding steering issue - Mud flap has been checked, no problem. The engineer who has come also said that the problem lies with the axle, but regarding change he said there is no urgency! | |
| | #15 (permalink) | |
| BHPian | Quote:
1. driveshaft 2. tierod and tierod ends. It could be the drivehsaft (axle). but your car is quite new, strange! Do one thing. turn your steering to extreme right. and chk underneath. you will see something like image below. check that rubber boot is not damaged and leaking grease. if yes your axle is had. it can be repaired but best bet would be to go for new (Rs.3600 MGP) if you hear similar sound even when driving over speed breakers, then tierod and ends are damaged, they are quite cheap.
__________________ Living Life a quarter mile at a time... | |
| Thread Tools | |
Similar Threads | ||||
| Fight: Maruti Wagon R Duo Vs. Indica Diesel | gary4gar | Hatchbacks | 36 | 10th January 2008 14:08 |
| ICE for my new Wagon R DUO | shivkumar19 | Ask the Gurus | 19 | 24th May 2007 10:56 |
| Fiat palio stile or Wagon R Duo | sundance | Hatchbacks | 26 | 17th May 2007 18:03 |
| Wagon R LXI Duo or Swift Vxi | nikunj_cal | Hatchbacks | 7 | 3rd April 2007 15:49 |
| New Wagon R DUO or Swift?? | ~~VinZ~~ | Hatchbacks | 10 | 9th August 2006 17:14 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
