| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Apr 2007 Location: Hyderabad
| Hi, I have recently done a trip to Hogenakal from hyderabad. Before that I have changed the stock tyres to Michelin tubeless 155/65. The grip I felt was very good throughout the tour. The tour was uneventful, except for the left front rim edge bend acquired when I hit a pothole at 90 kmph speed. I replaced the left front wheel with the stephany. Now, the problem is when I leave the steering the car pulls to either right or left and steering is unpredictable some times. I am not feeling the stability the car has before. I feel as if the wheels are weak. I did wheel balancing and alignment and still feels the same. Even with slight unlevelled road the car sways a lot. Checked with the service guys at Varun and they said everything is okay. But, I still feel the difference with the car. What would have been the reason?? Please help me. Thanks in advance. ![]()
__________________ '03 HH Splendor - 28,000km '06 Kinetic Blaze - 10,700km '07 Kinetic Flyte - 4500km '06 HH Zma - 21,600km '07 WagonR Lxi - 25,600km |
| | #2 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Try swapping the front tyres, i.e move RT tyre to LT and LT tyre to RT. You will have to remove the tyres and swap them on the rim, if the tyres are uni directional.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #3 (permalink) |
| Senior - BHPian | Shouldn't you do wheel alignment again after swapping wheels? Specially the front wheels? @Jaggu: If i remember correctly, he has michelin energy xm1.
__________________ I'm far from perfect. I hope i can improve. Thats why i'm here!Last edited by CrAzY dRiVeR : 17th July 2007 at 11:39. |
| | #4 (permalink) |
| Actually, the front left tyre is almost new and the front right tyre is 1500-km old tyre. Does that cause a problem?? What about the suspension point of view?
| | #5 (permalink) |
| 1500 km tyre shouldnt cause much issue, if you are still worried just do a front to back tyre rotation. Car might pull to a side due to road banking also, this is very evident if the surface is very good. You will feel the steering pull to either of the side depending on the banking of the road. Wider the tyre, bigger the pull is felt. Keep this in mind before you do anything.
| | #6 (permalink) |
| The car is pulling to right or left even on levelled and smooth roads. What about the steering column setting?
| | #8 (permalink) | |
| Quote:
__________________ '03 HH Splendor - 28,000km '06 Kinetic Blaze - 10,700km '07 Kinetic Flyte - 4500km '06 HH Zma - 21,600km '07 WagonR Lxi - 25,600km | |
| | #10 (permalink) |
| I will try that tomorrow. Interestingly, today when I took a 90-degree turn, I heard a screetching sound from the steering . I think I should meet a service engineer at M.S.S. and ask him to check thoroughly the suspension and steering. I will do this after I swap the tyres.![]()
| | #11 (permalink) | |
| BANNED Join Date: Nov 2005 Location: ??
| @ravi, since your tyres have done less than 1500 kms, you should check whether they have been fitted with the runout stripes in the proper position. Take a look at the section "What about the coloured stripes in the tread?" from the following website: Car Bibles : The Wheel and Tyre Bible Quoting the relevant passage: Quote:
In my case the runout stripes were in the correct position, but the car was pulling left just after fitting the brand new S322 tubeless tyres. Since the alignment/balancing was fine, I just waited and the problem disappeared on its own after about 2000 kms. Another possibility is that there may be some damage to one or more of your tyres, like a flat spot or a sidewall bulge. You should check the tyre surfaces carefully to eliminate that possibility. Last edited by rks : 18th July 2007 at 13:20. | |
| | #12 (permalink) | |
| Quote:
Thank you so much for the information and the suggestion. I could not find any color stipes now on my tyres, (I found them when I bought, but did not bother to check). I have checked all the tyres and all are in very good condition without any abnormalities as suggested above. All tyres have a moulded "OUTSIDE" written on them, which are fitted correctly. Now I stopped bothering about the problem and will wait till 2000 more km and check again. I did not get the time to exchange the front and back tyres, and will do the same this sunday. Thanks again ,
| | #13 (permalink) |
| Make sure you maintain tyre pressures and do alignment/balancing and tyre rotation at regular intervals. And keep a close watch on the tread wear. If the wear is even, your alignment is fine and you don't have too much cause for worry. The problem might just go away on its own after some running, or upon rotation. |
| | #14 (permalink) | |
| BHPian | Quote:
ravi.. any update on this... Ramki.
__________________ Silky Silver Maruti Suzuki WAGONR 2007 | |
« Chevy Turbo
Vibrations in car »
| Thread Tools | |
Similar Threads | ||||
| Baleno pulls towards the right when braking at high speed | kailashnj | Technical Stuff | 18 | 11th April 2008 08:20 |
| Brand New FIESTA Pulls like a TVS Moped on Test Drive!! | DileepKS | Street Experiences | 30 | 30th July 2007 10:42 |
| Doubtful of my WagonR front-left tyre | CheeseGuy | Tyre & Alloy wheel Section | 18 | 7th June 2007 17:51 |
| What car to replace WagonR? | devarshi84 | Hatchbacks | 7 | 10th April 2006 09:49 |
| Red Bull pulls a fast one on Mclaren! | Rtech | Motor-Sports!! | 8 | 11th November 2005 10:59 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
