Old 4th September 2008, 23:21   #151
govigov's Avatar
Thanked: 531 Times
purchased philips essential vision 100/130 2 days back. got them fitted into the ikon. the throw is good and definitely the road shows up much clearer.
govigov is offline   Reply With Quote
Old 4th September 2008, 23:23   #152
Vid6639's Avatar
Thanked: 21,085 Times
Originally Posted by govigov View Post
Hope you changed relays, wiring and holder. That's some serious wattage upgrade.
Old 5th September 2008, 06:55   #153
Path_Finder's Avatar
Good to see the difference with extreme vision - any idea about the life of these bulbs. I have heard that these have very short life?
Path_Finder is offline   Reply With Quote
Old 5th September 2008, 09:56   #154
gpa
gpa's Avatar
Thanked: 282 Times
Default Lifespan of the Philips X-treme power bulbs
Hi Path_Finder,
These bulbs do have a long life. You can find more details about them on the Philips website.
Cheers,
gpa
Old 5th September 2008, 10:08   #155
Thanked: 31 Times
Originally Posted by sj_koova View Post
You got it at such a good price. Rs-210/- lesser than ebay.
Mine was in a red pack, but I see a blue packing every time I search for this in Web. I was worried about the authenticity until I fixed them. Now I am almost convinced that they are genuine.
I can manage with this until I upgrade to HID next year
Hi sj_koova,
I think in this upgrade you don't need to change relays, wiring and holder. I was also planning to go for it. after seeing the comparisons. Nice photo
aka_iitd is offline   Reply With Quote
Old 5th September 2008, 11:28   #156
sj_koova's Avatar
Thanked: 176 Times
Originally Posted by aka_iitd View Post
Hi sj_koova,
No relays required. I got it changed it the service centre, but if your car is out of warranty, you can do it yourself.
Just need to make sure that you buy the appropriate type of lamp. Mine was H4 type.
If you buy it at shop, it is Rs-660/- for a pair
sj_koova is offline   Reply With Quote
Old 5th September 2008, 11:34   #157
Thanked: 31 Times
I want to get it done from my SX4. I was checkign the website PHILIPS - X-treme Power Lamp but only one type is mentioned. Does these fit for all cars.
Old 5th September 2008, 13:44   #158
gpa
gpa's Avatar
Thanked: 282 Times
Default Check the type of bulb on your car
Check by peering into the headlamp clear lens and look for the marking on the steel base of the bulb. There it will state what type of bulb is it (H4 or H7). Another option is for you to check the spare bulb pack that came with your car as the type of bulb will be mentioned there.
For this upgrade, you won't have to change any wiring or relays and your warranty will stay intact. So no worries on that front as well. I changed these bulbs on my car (Alto H4) this morning and will be posting a review of them here once I get a chance to test them.
Cheers,
gpa
Old 5th September 2008, 16:00   #159
sj_koova's Avatar
Thanked: 176 Times
Also search in car's manual. It is usually mentioned in the car manual.
Old 5th September 2008, 16:05   #160
anantnehru's Avatar
SX4 is H4 and fogs are H7 or H8. Apparently, they can be used interchangeably (??)
anantnehru is offline   Reply With Quote
Old 5th September 2008, 16:07   #161
Thanked: 31 Times
Yes they are mentioned in the same
Originally Posted by gpa View Post
Cheers,
gpa
Also i can see the type of bulb from the spare one. Only left is get them and get them fitted.
Thanks gpa and sj
Old 5th September 2008, 21:46   #162
govigov's Avatar
Thanked: 531 Times
@vid, changed the relay's long back.. after one of the bulbs blasted out, had changed it to normal 55/60. now changed it back to 100/130
Old 5th September 2008, 22:25   #163
Thanked: 258 Times
@sj_koova: Can you tell me from which shop in Bangalore I can get the xtreme power bulbs?
I'll be leaving to Trivandrum on Sunday night. It would be great if I can get it replaced before that.
I'm really unsatisfied with my current Crystal Vision bulbs.
Holyghost is offline   Reply With Quote
Old 6th September 2008, 11:12   #164
gpa
gpa's Avatar
Thanked: 282 Times
Default You can buy the X-treme Power bulbs here
Hi Holyghost,
You can get the bulbs at the below mentioned address if your interested in fiiting them yourself. Also tell the gentleman at the shop that you were recommended to go to his shop and push for a discount.
I bought a pair of these bulbs jusst this week.
A.K TRADERS
PH: 4114-3199, 4114-3958
# 22/23, 1 FLOOR, SEETHALAKSHMI COMPLEX,
3'RD CROSS, JC ROAD, BLORE 02
Cheers,
gpa
Old 6th September 2008, 11:15   #165
sj_koova's Avatar
Thanked: 176 Times
This thread may be useful. gpa got it at this shop.
http://www.team-bhp.com/forum/modifi...tml#post963136
Philips Rally Bulbs Headlamps jkdas Modifications & Accessories 32 8th May 2018 18:58
Philips Vision Plus / X-Treme Power bulbs in Chennai for Avenger VSG12777 Motorbikes 41 24th June 2015 21:05
Review : Philips Xtreme power bulbs for my M800 para_7k Modifications & Accessories 50 8th August 2012 15:08
Product Review: Philips Crystal Vision Halogen headlamps Rtech Modifications & Accessories 308 13th March 2007 13:38
philips blue vision h4 bulbs 65/55w dadudeonfire Shifting gears 5 31st October 2005 18:24
