Old 18th July 2007, 14:28   #16
Jaggu's Avatar
Thanked: 8,671 Times
@bottle and finney: for palio i think you will have to get separate bulbs for high and low. Madbull has used H4 which has both high and low beam.
Old 18th July 2007, 14:43   #17
finneyp's Avatar
Thanked: 175 Times
Thanks Jaggu for the info!
finneyp is offline   Reply With Quote
Old 18th July 2007, 14:59   #18
gemithomas's Avatar
Thanked: 138 Times
what does this H1 to H7 stand for. Is it about the output or about the design.
Old 18th July 2007, 15:12   #19
tsk1979's Avatar
Thanked: 16,420 Times
H1/H3/H4 etc., are bulb type or design.
Old 18th July 2007, 18:16   #20
madbullram's Avatar
Thanked: 76 Times
Vision PLus has both high and low beam...i dont have two separate bulbs if thats what u r asking...
madbullram is offline   Reply With Quote
Old 18th July 2007, 19:01   #21
Thanked: 24 Times
Originally Posted by madbullram View Post
Fully Compliant with ECE Regulation 37
can you speak in english ....
does it mean its legal in india???
I have 2003 indica V2 DLS, can these be installed with out changing anything else, if only i need to change the dome, i dont mind.
Also can these be used for my Suzuki Zeus, I feel the stock bulb is just a peice of junk.
kkr2k2 is offline   Reply With Quote
Old 18th July 2007, 19:48   #22
Jaggu's Avatar
Indica yes, since OE is also 55/60.
Zeus no, since the OE lamps will be around 35 w rating and these are 55/60.
Old 19th July 2007, 00:36   #23
Thanked: 24 Times
Thank you jaggu, the first thing I am going to change in my indica after its return is to go in for these. (currently the car is at farm house).
well, i understand from the posts in this thread that Phillips vision plus bulbs are better-of than the stock ones even at the same power. (or am i missing something here)
In that case can I find 35W rating in the phillips range which is better than the stock bulb on my zeus.
Old 19th July 2007, 10:39   #24
tsk1979's Avatar
DO not put 60/55W in your bike unless you are sure the wiring can take the load. Otherwise you will get lesser light.
The bulbs are rated 10//90, 60/55 etc., at 14 Volts in some cases and at 12V in others.
If you get lower voltage, i.e. 11 volts for a 12V bulb light output will drop by 20%
Old 19th July 2007, 11:28   #25
suman's Avatar
Thanked: 257 Times
Tanveer, so you're saying that Phillips or Osram H4 can be fitted on the Dicor without any additional relay - and it would make a major difference in illumination right?
If so, which of them is freely available, where and at what cost?
Old 19th July 2007, 11:44   #26
tsk1979's Avatar
Suman, Osram Silverstar +50 and Vision + from philips, bith 60/55W are easily available in Ludhiana.
But in case of Noida, I could see only Vision+.
Noida Vision+ stock is mostly Fake bulbs, so you better go to the distributor listed in the Auto Lighting thread at CP.
Check out speedonline post.
Old 19th July 2007, 11:58   #27
finneyp's Avatar
Thanked: 175 Times
Firebird, after going thru this thread, I went & checked my Palio User Manual to understand the bulb types used in Palio.
The User Manual states: H1 for Main lights and H7 for Dipped light.
Now, the question is - Is Main light the Normal/Low beam lights?
And is Dipped light the High beam lights?
Experts, please help?
Old 19th July 2007, 12:12   #28
bottle's Avatar
Thanked: 138 Times
hey finney thanks for that couldnt find the manual.. now this was in the faq for vision plus
1. Can I exchange my current headlamps against a pair of Philips VisionPlus?
Yes of course. Philips VisionPlus exist in H4 and H7. If your car is currently equipped with H4 or H7 bulbs, just replace the existing ones against a pair of VisionPlus. If your car is currently equipped with H1, a direct exchange against VisionPlus is not possible at this point in time, but you might like to try the Philips BlueVision or the Philips Premium.
so vision plus is out for main light ? :(
bottle is offline   Reply With Quote
Old 19th July 2007, 12:26   #29
suman's Avatar
Thanked: 257 Times
Thanks but no relays required and a huge difference over what's fitted currently?
Old 19th July 2007, 12:59   #30
tsk1979's Avatar
Yes suman with Osram silverstar +50% H4 bulbs there is a huge improvement in safari lighting.
Philips Rally Bulbs Headlamps jkdas Modifications & Accessories 32 8th May 2018 18:58
Philips Vision Plus / X-Treme Power bulbs in Chennai for Avenger VSG12777 Motorbikes 41 24th June 2015 21:05
Review : Philips Xtreme power bulbs for my M800 para_7k Modifications & Accessories 50 8th August 2012 15:08
Product Review: Philips Crystal Vision Halogen headlamps Rtech Modifications & Accessories 308 13th March 2007 13:38
philips blue vision h4 bulbs 65/55w dadudeonfire Shifting gears 5 31st October 2005 18:24
