Old 18th February 2008, 12:40   #106
Thanked: 37 Times
I want to change my safari bulbs, please suggest.
Dealer says, if we put a brighter bulb the clear lens is made of fibre, it will melt. Is it true?
He also says, due to high voltage the wiring might get burnt & warranty may be void?
Guys who have changed, please suggest what to do.
regards
Deepak
kdeepakk is offline   Reply With Quote
Old 18th February 2008, 13:28   #107
smith's Avatar
Originally Posted by iraghava View Post
Smith - Better you go in for Halonix +60's in 100/90 with a relay change. Much better than Philips and cheaper too.
thanks IRAGHAVA - what i basically want to know to know is that which headlamp bulb is the best within legally permissible range(biharis never violate the law)
Any idea about philips extreme power?
smith is offline   Reply With Quote
Old 18th February 2008, 13:31   #108
tsk1979's Avatar
Thanked: 15,646 Times
Within legal limits you have /Osram Nightbreaker and Philps Xtreme power which give highest light output.
But the problem of these extreme bulbs is that they have a short life.
If you use then 2-3 hours a day with frequent dipping expect couple of months of life atmost.
Old 18th February 2008, 16:24   #109
smsrini's Avatar
Thanked: 256 Times
regards
Deepak
You can try Philips Crystal vision 60/55 H4 bulbs. They are of the same rating as the OE bulbs, but have a better light spread. I've fitted them on my 2.2 Dicor. PM me if you would like to compare with OE.
smsrini is offline   Reply With Quote
Old 23rd February 2008, 06:42   #110
Awaiting Email Confirmation
Default Please tell me the location
i am also in chennai... i own a verna... the head lights aren't effective especially when i am travelling in the highways. can you give me the details of the shop from where you got it waith address.
sakthi350 is offline   Reply With Quote
Old 19th May 2008, 11:19   #111
appuchan's Avatar
Thanked: 16 Times
Could you guys please let me know where in South Bangalore to get the Philips visionplus and rally 100/90 bulbs. Mine got fused and it seems Trident Hyundai dont stock them.
appuchan is offline   Reply With Quote
Old 19th May 2008, 11:41   #112
whatcanthisbe's Avatar
just got a set of phillips put in my accent on saturday from driven, even though the shopw was under construction call mr rana up and voila it was all done, pretty satisfied with the spread and visibility of light over the stock 55/60 bulbs... cheers
whatcanthisbe is offline   Reply With Quote
Old 19th May 2008, 11:44   #113
Thanked: 244 Times
From where did you buy these, I am also looking at Osram Silverstar 50% which are of the same OEM rating.
Old 19th May 2008, 11:56   #114
tsk1979's Avatar
Osram silverstar +50% give very good spread in a safari. Have fitted them in a 3.0 DICOR, and the light is brilliant.
Tried crystal vision and blue vision too, but they pale in comparison(in the 60/55W) space. All show and no go
Old 19th May 2008, 12:19   #115
Vid6639's Avatar
Thanked: 19,377 Times
Tsk, I put the Vision plus in one side and the Silverstar in the other side. I found the vision plus gives better intensity than the Silverstar but the spread was better in the silverstar. The visionplus in high beam is way too high and theres no visibility just below.
Old 19th May 2008, 13:50   #116
tsk1979's Avatar
Different bulbs perform differently in different reflector designs. MY comments were with regards to a safari.
For example in a Getz, the vision + gives excellent spread and throw.
Old 19th May 2008, 14:07   #117
smsrini's Avatar
Thanked: 256 Times
Osram Dealer in Bangalore: Reliance Auto Near Minerva Circle, JC Road. Contact : Nilesh Gandhi 9880896117. Osram Marketing Manager: Satya Prasad : 9740000650
Philips Distributor :
Contact Sunil Mittal,
AK Traders
22/23 1st floor
3rd cross
JC road
Bangalore
Ph: 9844166794
Old 19th May 2008, 14:44   #118
Vid6639's Avatar
Do we need to adjust the headlight alignment after we change the bulbs to a non OE one like the silverstar or Visionplus?
I am sure if i lower the beam height it will be much better.
Old 19th May 2008, 18:22   #119
dionysus's Avatar
Thanked: 17 Times
got to know that Vision Plus is getting discontinued, dealers have limited stocks. However the xtreem is coming our way by end of May. Source "Spoke with the head of lights Philips Delhi"
dionysus is offline   Reply With Quote
Old 26th May 2008, 22:14   #120
dionysus's Avatar
Thanked: 17 Times
guys got vision plus from Kashmeri gate, Delhi, the name of the shop is amla sales and deal in Philips. But I am kinda confused, the light is yellow pretty similar to the regular bulbs, am i missing something, i was not expecting white light but a color range so alike regular bulbs was not something that i expected. Please enlighten me.
Philips Vision Plus / X-Treme Power bulbs in Chennai for Avenger VSG12777 Motorbikes 41 24th June 2015 21:05
Review : Philips Xtreme power bulbs for my M800 para_7k Modifications & Accessories 50 8th August 2012 15:08
Philips Rally Bulbs Headlamps jkdas Modifications & Accessories 16 15th April 2012 21:16
Product Review: Philips Crystal Vision Halogen headlamps Rtech Modifications & Accessories 308 13th March 2007 13:38
philips blue vision h4 bulbs 65/55w dadudeonfire Shifting gears 5 31st October 2005 18:24
