Old 27th September 2011, 10:26   #16
Thanked: 1,083 Times
Default re: Uneven Tyre Wear?
Each rear wheel, in a front wheel drive car is independently sprung. The suspension components have to ensure that the wheel moves only vertically. As it is difficult to design suspension which moves only vertically, normal suspension moves in an arc, hence the camber and toe-in settings change as the wheel moves up and down. The nominal settings make sure that the wheel sits "true" when the car has a "normal" load on a flat road surface. In an accident or due to wear and tear, part or whole of the suspension mechanism can move/rotate to change these settings, resulting in abnormal tyre wear.
Old 14th October 2011, 17:31   #17
Default Re: Back tyre wearing out quickly
I have checked the alignment and it is in order but the shock absorber on that wheel left side rear is weak and has an oil leak could that be causing the uneven tyre wear
Originally Posted by biju.bala View Post
I have a swift VXI which has covered 56,000 Kms and is running on its original set of tyres. Now the rear left tyre has started wearing out quickly. Wheel balancing and alignment was checked recently. Please advice what the possible reasons could be .
Thanks in advance
biju.bala is offline   Reply With Quote
Old 16th October 2011, 23:20   #18
IndigoXLGrandDi's Avatar
Thanked: 161 Times
If the Shock Absorber is leaking then get it changed ASAP . If your car is under warranty, you will get Free Replacement.
Also check for Rear Suspension Bushes if they have developed play in them. If so get them replaced too.
I don't think Swift has Independent Rear Suspension. So no alignment for Rear is needed.
IndigoXLGrandDi is offline   Reply With Quote
Old 2nd June 2012, 11:49   #19
Thanked: 25 Times
Default Unusual wearing of tyres of my Chevy Spark
Hello Bhpians!
My spark has completed 40k on stock tyres. All the four tyres are worn out from the one side (the side facing the car) while the other side is alright. Its strange
I do not know if this normal. What can be the reason?
And which tyres to go for now.
I reuire your quick response as i was planning to buy today.
car-o-phile is offline   Reply With Quote
Old 2nd June 2012, 11:54   #20
ankan.m.blr's Avatar
Thanked: 520 Times
Default Re: Unusual wearing of tyres of my Chevy Spark
have you done wheel balancing and alignment in these 40k Km ?
ankan.m.blr is online now   Reply With Quote
Old 2nd June 2012, 11:59   #21
Thanked: 25 Times
Yes. Its even strange if i tell you that i have got the wheel alignment and balancing regularly.
In last say 10 months or so, it has been done almost thrice and every time the caster was out.
is there something wrong with suspensions??
I dont feel anything while driving, no clutter from suspension, it takes on the bumps properly.
one thing that i noticed is the road noise has started filtering in the cabin more.
I guess after i got it converted to CNG.
Old 2nd June 2012, 12:08   #22
dhanushs's Avatar
Thanked: 4,507 Times
Most common reason is incorrect toe setting. Get an alignment done.
And, if toe settings are correct, then the reason could be suspension components worn out, or camber adjustment. Check the ball joints, lower arm bushes, and springs/dampers. As these will also cause camber to change, and hence one side tyre wear.
Old 2nd June 2012, 12:16   #23
rajeev k's Avatar
Thanked: 1,750 Times
Some of the OE tyres are likely to give such shoddy performance and by the by which make are they. Where they rotated every 5K or 10 K ?
Do a complete alignment and suspension check up and settle for new ones.
The pattern of car usage also determines tyre life and performance.
rajeev k is offline   Reply With Quote
Old 2nd June 2012, 12:24   #24
Thanked: 25 Times
the tyres MRF. my driving is in and out of delhi, mostly to gurgaon with poor road conditions.
Alignment was done regularly with tyre rotation in every service.
Do the tyre dealers do the alignment and suspension check up as well?
Old 2nd June 2012, 14:37   #25
rajeev k's Avatar
Perhaps the run through bad broken tarmacs and pot holes could alter the alignment. Go for better tyres next time and afford the marginal higher price of such tyres.
Tyre dealers, now most of them have alignment machines but for a comprehensive suspension set up checks you need to go to a brand Service center or other garages of repute.
Still I feel that 40K on OE tyres are fairly OK.
Old 2nd June 2012, 15:34   #26
Thanked: 25 Times
Hello, Thanks.
I just did a bit of research and found out that Michellin and Bridgestone are the best. Getting it done from Carnation.
I hope these tyres are fine and the Carnation, i believe is a good brand.
Old 2nd June 2012, 17:01   #27
rajeev k's Avatar
Hello, Thanks.
I just did a bit of research and found out that Michellin and Bridgestone are the best. Getting it done from Carnation. I hope these tyres are fine and the Carnation, i believe is a good brand.
I also feel the two brands are good ones and would give a better ride than the OE MRFs. Which type were those MRFs?
Regarding carnation have a second opinion about the Delhi center before leaving the car there because I have seen some bad experiences with Carnation in this forum. Purchasing tyres from some reputed tyre dealer would be the best as you can get fresh stocks and a competitive price and perhaps when you buy 4 tyres they may offer a free of cost tyre alignment check and correction. corrections
If your car's suspension is not making any abnormal noise and the feel is fine simple check up at a chevvy dealership can also be thought of.
Wishing you a fine and smiling drive on new tyres.
Is your car covered under the three year free maintenance package?
Old 3rd June 2012, 12:58   #28
Thanked: 25 Times
Hello
I just got new bridgestone tyres (not michellin as they r softer and since my driving is more on rough roads of Gurgaon) through carnation and the alignment, balancing was complimentary. I work in Magneti Marelli with which Carnation has a joint venture so i go there for service.
But i have a habit of sticking around my car and see what and how they service it.
And yes i had the three year maintenance pack but my car now is more than 3 years old.
car-o-phile is offline   (1) Thanks Reply With Quote
Old 3rd June 2012, 22:03   #29
SS-Traveller's Avatar
Thanked: 11,630 Times
Default Re: Uneven Tyre Wear?
...40k on stock tyres. All the four tyres are worn out from the one side (the side facing the car) while the other side is alright.
Are you running stock rims or after-market alloys?
Old 3rd June 2012, 22:11   #30
Thanked: 25 Times
hey!
these are still stock rims
HELP! Uneven rear tyre wear in Wagon-R ravi@64bhp Tyre & Alloy wheel Section 13 4th July 2016 17:02
Uneven wear of tyres on Santro coolbareilly Tyre & Alloy wheel Section 21 21st November 2013 12:46
Uneven wear & tear of front tyres on my OHC vijays15 Tyre & Alloy wheel Section 17 20th November 2012 11:24
Uneven tyre pressures Hells Bells Technical Stuff 8 13th November 2006 15:27
Uneven Tyre wear!? - Goodyear GSD2 Eagle F1 anarchist Tyre & Alloy wheel Section 4 10th March 2006 13:00
