Old 19th August 2009, 17:25   #31
Thanked: 139 Times
I remember reading a long time back about Russian car production in the communist era. The plant manager's progress up the food chain was highly dependent on metal consumption and meeting the budget estimates (little mention about the number of cars). Result: maximum metal usage on the car doors and bodies.
vasudeva is offline   Reply With Quote
Old 19th August 2009, 20:34   #32
akshay_b's Avatar
Originally Posted by gpa View Post
akshay,
The Santro's door thunk is much better than most cars in its and even above its class. If you still want a much more firm sound, you can think of some using some rubber matting on the insides of the door. There is a great thread in the DIY section and you can check it out.
There are also options like Dynamat and Noisekill that are more expensive.
BTW, but telling the passengers not to slam the door, you are actually doing your car doors a lot of good.
Cheers,
gpa
Are you talking about 'Fibreglass and Rubber mat damping for SAFARI '?
Will damping INSIDE the door help? I thought it has something to do with the exterior rubber or the lock hook.
akshay_b is offline   Reply With Quote
Old 20th August 2009, 10:13   #33
gpa
gpa's Avatar
Thanked: 282 Times
No, not the safari thread. There is another thread where rubber youga mats were used to damp vibrations in the boot of the Santro. I think this would come under the DIY under the ICE section. You could use the same mats for the Santro's doors.
I don't think you will get the door to close firmly by manipulating the door lock or the small rubber stopper near the lock.
The thud sound at the closing of a door is to do with the sound of resonation from the metal door panels. Damping the door panels from inside will remove the resonation and give you a much firmer sounding thud when you shut the door.
Old 20th August 2009, 10:41   #34
freewheelburnin's Avatar
Thanked: 26 Times
I have to disagree a bit here... Solid thud is a result of heavy metal plus good damping(example empty spaces less and some kinda material stuck to inside which damps the vibrations on closing resulting in a thude)...else there will be a metallic sound..like a clank(example safari Heavy metal plus poor damping and hollow space)
freewheelburnin is offline   Reply With Quote
Old 20th August 2009, 11:28   #35
Thanked: 364 Times
is there an public information about the sheet meta quality used by various manufacturers for various cars, and even countries cause I do feel the same model abroad sometimes have a more solid feel to them and maybe its because of the quality of metal used. Does anyone have any info/links on this?
raul is offline   Reply With Quote
A loud 'thud' sound whenever my Ford Ikon passes over potholes on the road. InternetUser Technical Stuff 24 25th June 2013 21:38
Thud Sound from Clutching Action atheistrical 4x4 Technical 6 29th October 2010 18:29
Need advice - Thud Sound while taking IKon out from Parking FlairBoy Technical Stuff 10 8th September 2009 19:52
Wake up to a THUD .... SCREE...CH...SCREECH.... DRC Street Experiences 6 5th September 2006 12:05
