Thread Tools
Old 25th July 2007, 11:00   #1 (permalink)
Default Notchy Gear Shift in my new Chevy Aveo UVA
I own a Chevy UVA June 2007. I have a problem with a notchy (hard) gear shift.
The car I had test driven had a gear shift smoother than butter. And that was one of the reasons I went for this car.
My Qs:
1. Is the notchy gear shift because its a new car and hasnt run even 500km?
2. Can a notchy gear shift be corrected in the service?
3. What are the reasons of having a notchy gear shift?
4. Has anyone else has this experience where the td car was smooth but the car you buy isn't? I am worried whether dealers deliberately keep their better cars for TD-ing?
5. Is my car a lemon? Should I report this and get a replacement or something?
-EMD
If this post doesnt belong here, MODS pls modify the section.
EatMyDust is offline   Reply With Quote
Old 25th July 2007, 11:07   #2 (permalink)
benbsb29's Avatar
EMD, the gear shift is probably notchy as its a new car. If you may have observed, the demo car would have clocked up quite a few thousand kms before you got to test drive it. Hence, the gears shift becomes smoother with time. Give it some time. This doesnt mean your car is a lemon, and there is nothing to worry about.
That said, i feel GM cars dont really have among the best gear shifts around. This based upon my test drives of the Aveo, both before and after the improved gear shift versions.
__________________
"Wise are they who invested in a diesel powered automobile" - Benny
Old 25th July 2007, 11:30   #3 (permalink)
gemithomas's Avatar
Chevy was known for its notchy gear. But i heard they had worked on this in the Aveo. SO the Uva should also have got the modified versions. I think i've seen an aveo review where he says the gear became smooth only after a few 100 kilometers. I guess you should wait for longer till you reaally try to get something done. Let it complete 1000km. Maybe it its still the same you could bring it up at first service.
__________________
"Our world is in its current state because of the choices WE made ...or failed to make"
Old 25th July 2007, 12:42   #4 (permalink)
CrAzY dRiVeR's Avatar
500 kms is too early to say that.
Please let the car complete run-in and first service. Most probably should be sorted out by first service. (or you might get used to it )
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 25th July 2007, 16:48   #5 (permalink)
nitrous's Avatar
Take it to the service centre.
Drive a few other cars that are present there.
If ur car doesn't feel the same, take it up with them.
These days, GM is being very loyal and loving to their customers and they won't give U a tough time,IMO.
__________________
Maruti - Everyone comes home with rattles!
nitrous is online now   Reply With Quote
Old 25th July 2007, 16:51   #6 (permalink)
I think you should wait till your first service. You might have put up about 1500 km till then. Check if the gear is still notchy. If yes, then GM might not have extended the gear shift improvement of Aveo to UVA. You should definitely take that issue up in such an eventuality.
__________________
Deepak Honnalli.
deepakhon is online now   Reply With Quote
Old 17th April 2008, 20:51   #7 (permalink)
nirmalts's Avatar
My Aveo (not UVA) is the facelifted one without a gearshift problem. But after 7000kms it has become extremely notchy. When I shift gears, I get a feeling of dragging a metal piece between two rusted metal bars. Got it checked with Vijai Auto last week. They said they greased it. I dont see a difference.
How could a gearshift that was not at all notchy become so after a while?
Nirmal
nirmalts is offline   Reply With Quote
Old 17th April 2008, 21:04   #8 (permalink)
PatienceWins's Avatar
Did they check the gear oil as well?
Otherwise, i do not see any reason for this change?
PatienceWins is offline   Reply With Quote
Old 17th April 2008, 21:57   #9 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Replies inline. Hope it helps.
80% yes
Report it by 5000 kms if things dont improve
Bad design, synchro's in gear box are kaput, bad installation etc etc
I have, except for my ol iKON
Try your luck if you want a new color just kidding.. NO!
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 17th April 2008, 21:58   #10 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Nirmal
Check your clutch settings first, most of the time this is the culprit.
__________________
Old 19th April 2008, 11:09   #11 (permalink)
Super-Admin
Just wait until you car has complete 2000 - 3000 kms. The shift will surely *open* up by then, though it wont be as smooth as some slick-shifting Japanese boxes. GMs (Daewoos) cars in India are famous for vague gearshift quality.
__________________
Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 19th April 2008, 19:14   #12 (permalink)
DieselFan's Avatar
My Swift VDI initially had a very notchy gear shift. Now at almost 20000 km it is as smooth as butter except for reverse gear. NOt to worry let the car age with time.
__________________
If you have not failed you have not tried enough.
Swift Diesel VDI - Feb '07 onwards
Santro LS- Mar '01-Feb '07(59000 KM) Sold.
DieselFan is offline   Reply With Quote
Thread Tools
Chevy UVA kay.kay Hatchbacks 14 31st March 2008 21:37
My new Aveo UVA kumar25rs Long-Term Ownership Reviews 39 16th March 2008 19:08
The new Chevy UVA 1.2 LS - test driven !! GeekSrik Test-Drives & Initial Ownership Reports 16 7th June 2007 20:16
What do you think of the Aveo UVA prabuddhadg Test-Drives & Initial Ownership Reports 2 16th March 2007 20:41
Dicounted Chevy optra vs Chevy Aveo 1.4 LS vs NHC GXI kumar Sedans 41 25th May 2006 15:35
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
