Thread Tools
Old 26th July 2007, 12:04   #1 (permalink)
manveet's Avatar
Default AC Compressor Problem: Info & Advice
My OHC has done about 70k kms in about 8+ odd years.
2-3 days back I suddenly hear a sound like - gadd gadd gadd gadd gadd gadd when I switch the AC on. The sound immediately disappears once I switch it Off.
I popped the hood to check it out because my immediate thought was that something is touching the fan-belt. However, that was not the case.
Although he does not so any AC work, I take it to my trusted mechanic who's immediate diagnosis is that the Compressor is damaged and it should be replaced ASAP. Also, he mentioned that in the past few days, I must have been feeling a major drop in pickup with the AC On - that happens due to Compressor taking extra load just before it reaches the conking off stage. In retrospect, I realized that what he was saying was true, therefore was almost sure of his judgment on Compressor being the problem.
Also, as per him, this is a common ageing problem that crops up in OHC's. Repairing is not an option in this case. He recommends I show it to the local AC guy (his reference) the next day.
I then called up the inhouse OHC expert - Iraghava - he confirmed that the sound corresponded to Compressor issue. Apparently, his compressor had packed when the car was at 11k (or was it in 11 months?) and he got it replaced under warranty.
Later, Courtesy Honda confirmed that Compressor had packed and gave a quote of 43K. Mentioned a couple of things that would be changed apart from the compressor like the AC clutch(?) etc.
Mechanics Reference has given me a quote of about 12k.
10,200 - Compressor (3 months warranty only !!)
1000 - AC gas
500 - some bottle that will be changed
300 - Air flow cleaning, general servicing etc.
Experts, Please Advice -
  • Anything specific I should keep in mind, pointers etc. ??
__________________
Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
manveet is offline   Reply With Quote
Old 26th July 2007, 12:09   #2 (permalink)
manveet's Avatar
Default For the Mods
Although I found 2 small Threads on a similar issue, I've created a new more comprehensive one - Please merge as you deem fit.
http://www.team-bhp.com/forum/techni...cessively.html (AC compressor loading engine excessively) - A small thread where he tries to figure out the problem in his OHC Ac, narrows it down to compressor and fixes it for 15k
http://www.team-bhp.com/forum/techni...en-turned.html (AC Issues & Noise when it is turned on)
- some screeching noise in his AC. I think it was the fan-belt.
__________________
Old 26th July 2007, 12:32   #3 (permalink)
gd1418's Avatar
Infractions: 0/1 (4)
Why does the bottle need to be changed? Compressor changing has got nothing to do with the bottle unless the oil from the compressor has run into the lines totally.
But even in that case a thorough cleaning settles the issue.
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 26th July 2007, 12:46   #4 (permalink)
manveet's Avatar
I had asked him the same. He had mentioned that something is eating into something as a side-effect of the gadd gadd noise which changes its shape at the edges or something like that, and leads to ineffecient sealing bla bla bla. Therefore, to avoid future problems, changing is best.
Since I didn't even know which bottle he was talking about, I really bother as it was less that 5% of the total cost.
As it'll be a 2 hr job or so, I'll be with him when he works on it, so will check it out then and let you know accordingly. I could take a few pictures of WIP if you want me to?
__________________
Old 26th July 2007, 13:25   #5 (permalink)
Pankaj401's Avatar
Is that an OEM Sanden or some local compressor. The compressor costed me around 14.5K last year in Bangalore apart from Rs.1500 for AC gas & oil and leak test.
Pankaj401 is offline   Reply With Quote
Old 26th July 2007, 14:11   #6 (permalink)
manveet's Avatar
@ Pankaj - Thanks for the info.
He mentioned that mine would be OE and sealed etc. but I didn't know what the OE brand was. Now that you say its Sanden I will verify the same.
Now that its been an year, any issues with the AC or is it as good as new?
@ iraghava - Can you confirm? Are there any other OE suppliers as well? Do the vtec and non-vtec use the same Compressor?
__________________
Old 26th July 2007, 14:27   #7 (permalink)
Jaggu's Avatar
Sanden is the OE compressor, our old city had same issue and in Bangalore the dealer charges Rs 33,000 for replacing the same 2 years back. Only compressor was replaced and gas refilled.
Car had done just 30,000 kms at that time.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 26th July 2007, 14:29   #8 (permalink)
Pankaj401's Avatar
Denso is the other OEM for Honda. But the OHC had Sanden.
There hasn't been any problem since I got it replaced.
Old 26th July 2007, 16:57   #9 (permalink)
iraghava's Avatar
Manveet - Pankaj & Jaggu are right, Sanden is the OE on all OHC's, so ideally look for that.
And my car's compressor was replaced when she had done about 30k-odd & was 11 months old, so it was covered under warranty.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 26th July 2007, 17:06   #10 (permalink)
gd1418's Avatar
Thanks Manveet, no need of pics of WIP. But would be interested in the reason for change of the bottle; irrespective of the cost.
__________________
Old 26th July 2007, 18:05   #11 (permalink)
Jaggu's Avatar
Manveet do post WIP pics, will be helpful for others to understand the AC system better.
__________________
Old 1st August 2007, 04:25   #12 (permalink)
navin_bhp's Avatar
Hi Manveet, so what happened then got the AC compressor rectified?
__________________
Navin
_________________
Honda city 1.5 Exi
Dream Machine!!
navin_bhp is offline   Reply With Quote
Thread Tools
advice for all you people with pioneer HU problem(alt whine) clipto333 DIY - Do it yourself 38 19th August 2008 15:50
advice request: Is broken silencer a problem ? make:Fiat Petra mchulet Modifications & Accessories 14 14th July 2008 17:29
Compressor problem udaydesai Technical Stuff 16 30th January 2008 16:39
Help & Info Required. viper Ask the Gurus 18 14th May 2007 11:13
Hi, I am new here & Some info required veipe Technical Stuff 17 16th June 2004 17:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
