Thread Tools
Old 27th July 2007, 19:29   #1 (permalink)
Optimus Prime's Avatar
Default Clutch Setting in the Swift
got my swift yesterday and while driving it back from the showroom i realized that i have to release the clutch pedal a lot more than in my other car (2000lancer). because of this i had a few occassions in traffic where i revved quite high (well, higher than normal) before the clutch engaged. and there was a bonk i press the accelerator and engage clutch.
i hope i'm able to explain this properly.
what i mean is.
in my old car, i release the clutch a little and i can accelerate.
in the swift, i have to lift my foot a lot more.
is it like this in all swifts? is there any point in having the clutch setting changed or should i just get used to it.
and the brakes, they're damn sensitive, i tried blipping while downshifting and the car nearly stopped .. guess it takes a while to get used to the swift.
also the steering, it's really light. doesnt give the impression that the car around it is quite heavy, i'd have preferred a little more feedback
thoughts...
__________________
Autobots Rollout!!
BMW Power
Optimus Prime is offline   Reply With Quote
Old 27th July 2007, 20:17   #2 (permalink)
akash_m's Avatar
Default swift clutch..
looks like you've got a new swift! I was the first one to own a swift two years back in Noida. Covered 32k kms. As for the clutch settings, if its getting released too late, then you better get it adjusted, because the clutch slipage may. I adjust my swift's clutch myself .
The sterering is light but i have noticed it going hard over a period of time!
akash_m is offline   Reply With Quote
Old 27th July 2007, 20:22   #3 (permalink)
jack7's Avatar
Hey Optimus,
I guess i'm no pro but i've driven a few Swifts and did notice this clutch setting on all of them. Apparently thats how they've set the clutch settings on swifts but I'm sure you can get this altered from your default setting . But I'd suggest you leave it the way it is since you'd easily get used to it after a while.
Yeah about the brakes, I'm sure they're spanking new, thats why
jack7 is offline   Reply With Quote
Old 27th July 2007, 20:47   #4 (permalink)
highwayblaze's Avatar
You mean you have a tall clutch. I dont know about swifts since i've not driven one but its the same way in my Golf. They're known for tall clutches. What I mean is the pedal travel from unpressed to full depressed is a long way down and same way back until the clutch engages. Its the same in the Nissan 350Z as well.
It was not the same in my honda prelude however. The travel was really short and clutch engaged almost instantly.
__________________
Chill Pill
Blaze
highwayblaze is offline   Reply With Quote
Old 27th July 2007, 23:42   #5 (permalink)
maybe i should wait for a bit longer, in that case.
@highway blaze, you got a lot of cars man....
__________________
Autobots Rollout!!
BMW Power
Thread Tools
Does the Maruti Swift have a weak clutch tsk1979 Technical Stuff 130 7th October 2008 20:19
Swift Diesel - Clutch Rattle at 2000km P1tBull Technical Stuff 14 7th February 2008 10:11
My Swift & Its Clutch passioncool74 Technical Stuff 10 20th December 2007 16:16
Upgraded clutch for swift ?? khaadu75 Technical Stuff 13 9th November 2007 09:36
Swift clutch replacement - Suggestions needed ASAP! karthik247 Technical Stuff 35 7th August 2007 22:33
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
