Old 28th July 2007, 22:49   #1
Default Is this the indication to change the battery ?
Guys it has been more then 2 yeras that we bought scorpio it clocked 73,000 km till now this is the first time that my scorpio refused to start.
when i turned the keys their was some strange sound comming from the battery and the lightes also became dim..then i called my mechanic..he bought a battery along with him ,he connected it and now my scorpio started
Now i want to ask u guys is this the indication to change my battery.....?
what is the life of the battery that comes from the company????i got amaron battery from the company .
zenopio is offline   Reply With Quote
Old 28th July 2007, 23:18   #2
theMAG's Avatar
Thanked: 1,574 Times
2 years is a short time for a new battery to fail in a modern alternator-driven car; older dynamo-charged cars did have a reputation of not consistently charging the battery at required levels.
Amaron is one of the better brands today. There are regular cases where the stock battery has come around for upto 4 years under normal usage. if 4 yrs seem to be the upper limit 3 yrs is still an expected life of a new battery in a modern car - under normal usage.
Chk to see if the battery is getting charged properly in your car - without headlights; and with headlights-main beam
Old 28th July 2007, 23:37   #3
as soon as the car stared i travelled around 7 kms and reached home..and i tryed to stop the car and start again.,..i thought the battery will get charged to some extent atleast ,the battery was totally dead..the car didnt even crank..???what might be the problem guys ...
Old 28th July 2007, 23:38   #4
wolfinstein's Avatar
Check if it needs some Battery Water or Simple Charging, which could have happened if the Alternator was not providing the right current.
Ideal time for an OEM to knock off is from 18 months- 48 months depending on the user feedback right here.
Some had the OEM go in 18 months, while others even clocked above 3 years with the OEM.
My Lancer's OEM Exide went off 30 months later.
wolfinstein is offline   Reply With Quote
Old 28th July 2007, 23:41   #5
esteem_lover's Avatar
Thanked: 451 Times
It is time to check the battery. Sometimes they do conk off in 2 years.
Old 29th July 2007, 10:56   #6
gd1418's Avatar
Thanked: 656 Times
Amaron conking off in 2 years is rare. Was the battery properly maintained during these years? Alternator malfunctioning could be a factor, but the indication would have come much too earlier.
Batteries conking off suddenly without any prior indication is quite an often occurrence. The same happened with me as well. Went to relatives for dinner and their son wanted a ride in my Scorpio. The truck wouldn't start; the lights would go dim and some funny sound emanated from the bonnet. Had to push start, aborted the dinner and returned home.
Next day morning too the same scenario. Push started and went to mechanic. One of the cell of the battery had gone bust. Replaced the battery; now a happy man.
Assuming all parameters are ok, boy, you need a battery replacement asap.
Old 29th July 2007, 11:11   #7
sreenivass's Avatar
Default battery and alternator unit need to be checked
Please get battery specific gravity and if alternator is charging the battery. Since you could drive 7 KMs after start there are no supply problems from alternator, but there could be problems with alternator charging the battery. You need to do 2 things
First get the battery checked if it can retain charge, if so get it recharged, secondly get the alternator unit checked to see if it is charging the battery.
sreenivass is offline   Reply With Quote
Old 29th July 2007, 11:48   #8
nitrous's Avatar
Thanked: 285 Times
Check Battery water and get the battery recharged by Amaron.
It should help.
Old 30th July 2007, 22:17   #9
guys got the battery checked..its the battery problem one of the cell got damaged..
buyed new battery same amaron itself got 1 1/2 year warranty(complete battery replace ment in case if the battery gets damaged with in this period) and costed me around 4000 after exchaging the old battery is the price correct guys.??
Old 30th July 2007, 22:21   #10
fiery enzyme's Avatar
Thanked: 23 Times
1 1/2 years looks like a wierd warrenty period. Isn't it supposed to be 3 years?
Bala
fiery enzyme is offline   Reply With Quote
Swift Diesel: Engine oil indication remains on till 3200 rpm narry Technical Stuff 8 24th February 2010 21:09
Swift - Fuel gauge indication MC Mayank Technical Stuff 19 28th October 2006 11:00
Seat belt warning indication Surprise Technical Stuff 18 29th July 2005 15:50
Tyre pressure indication on the sidewall!! Shan2nu Tyre & Alloy wheel Section 11 7th February 2005 15:37
