Old 2nd August 2007, 15:47   #1
LLL
Default Rains aftermath - Water enter my santro
I drove through heavy rains last night and parked my car in a dry area. This morning when i took out my car, i noticed carpet on passenger footwell both in front and rear was water soaked. I also noticed water in the spare tyre well.
Anyone has any clue as to how it got there? The windows were firmly closed and i dont see water dripping from top anywhere.
Also what should i do to dry this water completely?
LLL is offline   Reply With Quote
Old 2nd August 2007, 15:51   #2
Thanked: 245 Times
If the water level has not gone beyond this, you need to dry out all your carpets and remove the spare wheel and jack, spanner and dry them too.
If the car is in a safe area, open all doors to avoid stale smell but if not, you might need to be standing around for an hour or so.
Old 2nd August 2007, 16:27   #3
rohan_fonseca's Avatar
Check the beadings. Also this thread http://www.team-bhp.com/forum/techni...ue-solved.html (Leaking Getz - weird issue - solved)
rohan_fonseca is offline   Reply With Quote
Old 2nd August 2007, 16:55   #4
whatcanthisbe's Avatar
in the floor board there are holes which should be ideally plugged with rubber plugs remove the carpet and check @@
whatcanthisbe is offline   Reply With Quote
The Great Indian Monsoon, 2013: Aftermath in Bangalore raveesh_k Street Experiences 30 15th September 2015 20:46
Advice-Help Need Santro collecting water LL4X4 Technical Stuff 21 22nd September 2010 08:57
Urgently Wanted a Santro/Zen (Before The rains) SohailPistawala Shifting gears 1 31st July 2007 13:06
ALERT!! Rains strike Mumbai again GTO - Touring The Indian Car Scene 6 11th September 2005 03:42
