Thread Tools
Old 26th December 2007, 09:29   #16 (permalink)
Just got his problem today in my Getz, a drip of water, not inside the car, but outside, it drops from the right mudflap. I had parked my car in the garage for a full day, and notice this trail of water this morning. At first I thought it may be the wiper fluid, but the container is full. I suspect it is the blocked drainage hole. Any idea where it is located and whether it's a DIY job?
__________________
Hyundai Getz 05
Baleno Vxi 05
filcord is offline   Reply With Quote
Old 9th May 2008, 14:40   #17 (permalink)
Default Water logging In Aveo
Twice I face this problem whenever it rains. The rear passenger side foot area(only on right side) was soaked with water. Only on the foot area carpet, not a single drop is seen in any other place
First time I'd noticed this around 1 1/2 month back after a big rain.
Vijay(GM) guys thoroughly checked my car, after removing seats and carpets(to takeout base carpet we have to remove seats - a big work) by spraying water to all doors/rubber bleedings from outside, put up the car in ramp and tried to spray it from underbody. Not a single drop is coming side. Then we thought, may be in hurry during the rain I didn't close back side door properly. Actually the back door we have to close very strongly.
But again yesterday evening I was driving through some mild rain, back home I have checked the rear passenger foot area, the carpet was soaked with water. That too only on the "right rear passenger side foot area", and not a single water droplets on any other place. The rain was not that heavy and I didn't drive through much water logged area also.Looks like water is coming from under body only. This time i am sure all doors/glass were closed properly.
I am really worried about this. Please help me.
Spoke with Vijay guys, today I didn't get time to take the vehicle and tomorrow they are closed because of election. Now only on Monday I can take my car to service center.
Is there any rubber plug in the floor bed of Aveo, last time when i checked I couldn't find any? Then where is the water outlet?
kavu75 is offline   Reply With Quote
Old 9th May 2008, 15:43   #18 (permalink)
Hard luck man. Very weird problem. While you are yet to take it to the service center, just park the car in a covered parking lot, remove the carpet and open the windows a little so that your car can dry. Else corrosion may set in.
I hope the GM guys sort out the problem. they better! Else take it to some private mechanic. i know one one JC road.
Worry not,
Cheers,
Harsha
__________________
If you're incompetent you have to be honest, and if you're crooked you have to be clever.
harsha.cs1 is offline   Reply With Quote
Old 9th May 2008, 16:19   #19 (permalink)
Originally Posted by harsha.cs1 View Post
just park the car in a covered parking lot, remove the carpet and open the windows a little so that your car can dry. Harsha
Thanks for the update. Today i have to wipe out the water with some sponge or something. I can't take out the carpet, we need to remove seats for that. Planning to take to Vijay itself since they have already worked on it once.
Thread Tools
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 10:19
OHC trouble after engine flush. EDIT : Now Solved! ankitahuja Technical Stuff 56 22nd August 2007 16:21
Help - cannot tune 104 FM - NOW SOLVED normally_crazy Ask the Gurus 20 26th April 2007 12:46
Years of mystery SOLVED! The Sultans Garage an it's whole LIST! comfortablywacky The International Automotive Scene 34 26th September 2006 14:01
Fuel Tank Rusting and Leaking in my Fiero F2 souravbasu Motorbikes 15 21st April 2006 12:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
