| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2005 Location: Mumbai
| Recently, I came across a bizzare problem in my Getz. Early last week, I noticed that AC in the car was not very effective. Later I noticed that passenger side carpet was wet. I assumed that AC gas has leaked and hence ice is forming on the evaporator coils. (This had happened to my home AC once). And that the drainage must have got choked and hence AC water is spilling inside the car. Yesterday evening, I get into the car in the parking and found that there was 2 inches of water on the passenger side. It had rained the whole day and car was parked in the open. I checked the door etc. to see if water could have possibly entered.....but all seemed ok. (At home I have a covered parking and hence this problem did not crop up earlier.) On the drive back it was raining heavily and then to my horror (surprise !!), there was water trickling in from the blower. Today, when I gave my car for service, the chap understood the problem. He said that there is some drainage point under the wiper and if that gets choked, water tends to seep into the car. He said that its a known problem with Getz and possibly other Hyundai cars as well. Last edited by risga : 2nd August 2007 at 16:05. |
| | #3 (permalink) |
| BHPian | Actually today only I went to the dealer with the same problem in my Lancer..But they say the water has not entered from the underbody.They have to open the dashboard and check for the exact cause.I dont want to open the dashboard again as they have opened it one month earlier for changing the filter(Sponge inside the air vents) which cost me 2500rs.Can anyone tell me the eact reason for the problem?The wetness is mainly on the driver's side extending upto the clutch and brake pedal// Regards Dilip Kumar |
| | #4 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Bah! So many people and the same problem? And I never ever heard of such a crazy problem before. @risga, now I have a faint remeberance... did you not open a thread earlier on this subject sometime back when you were hunting for a reason for this strange happening? Edit: Ok, I think I found out where I read this problem earlier. It was in Pawan's Palio (Strange water leak in my Palio). Strange! Different cars, different environments and yet a similar and equally wierd problem.
__________________ Having problems with new board rules? A solution is available at hand. Last edited by Zappo : 3rd August 2007 at 01:42. |
| | #6 (permalink) |
| BHPian | risga. really appreciate that you put up a thread fora problem that was solved. This would really help lots of people out here. I've seen a few threads that just stop abruptly without a proper update on the issue by the person who started the thread. I've always thought that people just never think of posting once their problem is solved. ONce again, its really good to see threads like this.
__________________ "Our world is in its current state because of the choices WE made ...or failed to make" |
| | #7 (permalink) |
| BHPian | Hi Team.. The 1st day of Delhi rains as i entered my car i noticed that there is quite a lot of water on the floor.. Fearing rust, i quickly took a cloth and dried out the water (about 1 bucket full) and took it to my regular workshop. On inspecting the mechanic noticed the water is leaking from the lower part of the rear doors just near the joint between the door body and the cardboard like stuff on which the PW and the door handle is attached. He said that its caused due to clogged door holes at lowermost part of door due to which the water filled in the door and thus leaking after which he cleared it.. The day went like that.. Just yesterday i noticed that after the rains there is a tint of water and ignored but it rained hard this evening and i found that still the water is entering the cabin from the rear doors ..I am really worried about my baby.. Please help by giving suggesions on this...
__________________ Anish a.k.a romy 1997 Maruti 800(Sold) 2001 Fiat Palio |
| | #8 (permalink) | |
| Quote:
BTW, my other car (2001 Wagon R; purchased 2 months ago from Truevalue) also had a leakage issue. I could see drops near the rubber beading (on the inside) on Front LHS. The guy at service centre just adjusted the rubber beading and problem was solved. @streetlife: Just shake the door. If you hear liquid, then water could be collected inside. Kindly also check the rubber beading. The chaps at the service centre can usually identify the problem. They would have come across similar cases in the past. | |
| | #9 (permalink) |
| BHPian Join Date: Jan 2006 Location: Delhi
| This is a strange and an annoying issue. Exactly same problem happens with my Santro once in every monsoon season and yes i did see the service guy doing something near the wipers to drain out water. Surprises me that these companies like Hyundai and Ford dont have an alternative to overcome such a problem. I mean never had this problem in my NE118 which is an old generation car with A/C ..... dont know about Contessa though ??? Touchwood no such issue experienced with my Aveo yet. Hope Chevys dont have such design issues. |
| | #10 (permalink) |
| Team-BHP Moderator ![]() | Spent my Sunday morning removing the plastic cowling around the wipers and cleaning all the gunk, dead leaves, a few feathers and a dead spider that had mixed together with the rain to form a smelly, yucky paste that choked the drain hole on the drivers side. The water must have filled up and entered the cabin giving me a damp carpet.
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| | #11 (permalink) |
| Senior - BHPian | Hi, I guess we are all going thru exactly the same problem. Entered the Santro yesterday to find the entire front left matting floating in water with the carpet soaked. Fortunately the drivers side and the rear got saved. Identified the problem this morning. The car is parked under a tree and the drain holes were blocked with leaves, muck and dirt. Car is still at the garage to check for any more leaks. Had to remove the full carpet to dry out. Viper
__________________ NO ONE DARES COME CLOSE |
| | #12 (permalink) |
| Distinguished - BHPian ![]() | Same thing happened with me on Thurssday after some heavy rains in Delhi, water got inside the cabin & soaked the carpet & the boot which lead to my Pioneer amp getting screwed. Still investigating as to where the water came in from since it has never happened to me before in any of my cars. I've driven Dhanno through some much worse rains & standing water before but no seepage ever happened.
__________________ I'm killing time while I wait for life to shower me with meaning and happiness. |
| | #13 (permalink) |
| BHPian Join Date: Mar 2005 Location: goa
| Had this in my old Ford Escort. There was a shelf below the wiper that contains the a/c condenser or something. This had developed minute pin holes that drained directly to the cabin. Never managed to solve the problem, it needed major welding and re-painting. I would just remove the carpets for the monsoon and replace them in October.
__________________ Hyundai Getz 05 Baleno Vxi 05 |
| | #14 (permalink) |
| BHPian | I face the same problem whenever it rains now or when the car is washed. Recently, the rear passenger side foot area was soaked in 1-2 inches of water and the boot was terrible with more than half of the spare tyre drowned in water. I have a permanent polythene on the CD Changer in the boot and have to put the car cover on everyday. I can see water droplets on the rear LHS door trim. My car is parked on an incline so as soon as it is brought down to stand straight, the water from the boot travels down to the passenger side rear seat and front seat carpet. ![]() Please tell me what to check! Last edited by ankitahuja : 7th August 2007 at 02:55. |
| | #15 (permalink) |
| BHPian | try this test. light a couple of bad quality agarbathis, the kind which smoke real heavy. use a steel plate cos you dont wanna drop the ash anywhere. get all the windows up. take agarbathi inside and slowly move it around the entire car. someone is to stand outside and note where the smoke leaks out from. you got the problem spots...
__________________ ThunderBird 2003, no speedo, no range limits. Wagon R, 2004. Well trained reflexes are quicker than luck. |
| Thread Tools | |
Similar Threads | ||||
| Idling problem in my WagonR Lxi..EDIT : Now solved. | ramki067 | Technical Stuff | 8 | 17th December 2007 10:19 |
| OHC trouble after engine flush. EDIT : Now Solved! | ankitahuja | Technical Stuff | 56 | 22nd August 2007 16:21 |
| Help - cannot tune 104 FM - NOW SOLVED | normally_crazy | Ask the Gurus | 20 | 26th April 2007 12:46 |
| Years of mystery SOLVED! The Sultans Garage an it's whole LIST! | comfortablywacky | The International Automotive Scene | 34 | 26th September 2006 14:01 |
| Fuel Tank Rusting and Leaking in my Fiero F2 | souravbasu | Motorbikes | 15 | 21st April 2006 12:28 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
