Old 5th August 2007, 14:34   #16
Jaggu's Avatar
Thanked: 8,686 Times
Originally Posted by 2fast4u View Post
jaggu@ all can fail if sugar is added to fuel.
ENGINE CAN FAIL IF SUGAR OR SALT IS ADDED!!! But i guess its a case of fuel gumming in one of the injectors.
Old 6th August 2007, 02:32   #17
roms's Avatar
Thanked: 22 Times
Originally Posted by merve_extreme View Post
if it is not your injectors,check your ignition coil.they are known to malfuntion often.tell them to put your ignition coil on another 1.2 and check it,because the ignition coild failure is sometimes not reported by the scanner.
yep, thats a brilliant suggestion. It is a very common problem. But the question is that does the injector lamp remain on constantly or is it intermittent?
roms is offline   Reply With Quote
Old 6th August 2007, 21:20   #18
jalsa777's Avatar
Thanked: 1,065 Times
ohkk guys...
had to replace injectors in cylinders 1 and 3...now its working perfectly
thanx for all your help
(the shaman guys said that they say all four injectors initially but then replace only those that are faulty...they do that because sometimes, other injectors not replaced blow up later and costumer says that work is not done properly)
fools....
jalsa777 is offline   Reply With Quote
Old 6th August 2007, 22:02   #19
Even Shaman replaced 2 of my Palio GTX injectors a month ago. But the problem occurred again last week. The problem got fixed on its own,but I have lost confidence on the fix. Did they actually fix the correct problem? How do I take my car on long drives, with such uncertainty.
I drove last weekend, there was no problem.
-Vikram
Palio GTX 50K, 2002
gudakesh is offline   Reply With Quote
I think I Screwed up my Swift suspension! Need Help! Spartan Technical Stuff 28 29th April 2009 21:23
Auto Fusion screwed up my Alpine nirmalts Modifications & Accessories 6 30th October 2007 20:52
Starting problems-Injectors just cleaned,engine flushed rahul_intlad Technical Stuff 16 9th February 2007 12:07
How to check if Fuel Injectors are alright? extreme_torque Technical Stuff 4 28th July 2006 10:00
Fuel Injectors Added to an Indian Bike? srikantans04 Motorbikes 3 15th June 2006 19:01
