Old 4th August 2007, 11:19   #1
spider77's Avatar
Thanked: 9 Times
Default Baleno at 160kmh steering problem
hi
recently i when was driving my baleno on NH7, i faced a weird problem.The steering of the car which is electronic was behaving perfectly till 140kmh, it was hard, car was completely in control but when i was crossed this speed the steering got very light, at 160 and 180 kmh, it was very nervous ,its like a normal power steering where a light rotation can make a sharp move on car.it feels very risky.
I have put 15 inch yokos avs sports on HR rims.
Can u guys help on this , is it normal with baleno or some kind of defect..
Here r the pics :Picasa Web Albums - karan - elagiri P01
Picasa Web Albums - karan - elagiri P02
spider77 is offline   Reply With Quote
Old 4th August 2007, 16:04   #2
esteem_lover's Avatar
Thanked: 451 Times
AFAIK, the baleno does not have a EPS, correct me if i am wrong.
Old 4th August 2007, 16:04   #3
binz's Avatar
Thanked: 412 Times
Steering is hydraulic not electric.
Old 4th August 2007, 16:41   #4
Jaggu's Avatar
Thanked: 8,693 Times
What do you mean by light, yes as speed increase the steering will become sharper, but thats the way it is supposed to be.
Old 4th August 2007, 16:45   #5
Optimus Prime's Avatar
i have a similar problem with my lancer. when i cross 130... if i'm accelerating, the steering may or may not be fine. but if i'm decelerating from anything between 160-120, the steering feel starts vibrating like mad, with a continuous khatkhat khat khat sound. it doesnt effect the driving in any way but your hands go sore. i spoke to he showroom guys and they say some bush has to be replaced. the lancer has done around 50000 kms... what is this bush they're talking about??
Optimus Prime is offline   Reply With Quote
Old 4th August 2007, 17:13   #6
Jaggu's Avatar
@optimus: ask them the name and post, hope you have cleared the option of wheel balancing already.
Balance rod/lower arm/tie rod end all these can be culprits in your case since car has done 50000 kms
Old 4th August 2007, 18:21   #7
Exclamation
i also have the same problem in my baleno........this starts after 140kmph.....but still have touched it till 170...mine is 2006 baleno....n running on stock tyres..But i believe it is normal.....if this happens at high speed...
ashishjhamb is offline   Reply With Quote
Old 4th August 2007, 18:26   #8
spadival's Avatar
Thanked: 16 Times
The steering on my Baleno vibrates at around 120kmph.. Thats probably because of wheel alignment issues. Havent fixed it yet.. prefer to limit myself to sane speed limits. IMHO, its madness to cross 120kmph on ANY Indian roads.
spadival is offline   Reply With Quote
Old 4th August 2007, 18:30   #9
Jaggu's Avatar
@spadival: its wheel balancing issue that the wheels are vibrating.
Old 4th August 2007, 22:10   #10
I also have similar problem when i cross 120 kph. Think this is the problem with wheel alignment itself.
premdiv is offline   Reply With Quote
Old 4th August 2007, 23:06   #11
kpzen's Avatar
Thanked: 1,655 Times
Thats a wheel balancing issue.
Old 5th August 2007, 05:02   #12
BlackPearl's Avatar
Thanked: 5,144 Times
@spider, this is not normal in a Baleno. get your tires, rims, wheel balacing checked.
BlackPearl is offline   Reply With Quote
Old 5th August 2007, 06:30   #13
1100D's Avatar
Thanked: 2,503 Times
Seemingly a wheel balancing issue, could also be your front bearings (but that would tell itself at other times)
edit - get your toe setting checked as well.
1100D is offline   Reply With Quote
Old 5th August 2007, 06:34   #14
1100D's Avatar
Optimus, if I am not mistaken, when you are decelerating, you are decelerating on the brakes right? If yes, then the issue is most probably your front rotors. If you have machined it, let me inform you, that machining can only smoothen the rotor surface but cannot align the rotor. Replace the front rotors it will be fine. I have faced this a lot of times, and is an indicator of when to change rotors.
Old 5th August 2007, 09:54   #15
not only on the brakes, no need to use the brakes when you're dropping down from 130-150, lifting off the throttle is enough,, but it still shakes like crazy...
Loose Steering (Too much play in the steering) mithun Technical Stuff 5 23rd October 2012 12:35
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
