Old 5th August 2007, 13:12   #1
ksr
Default Lot of tyre noise in Aveo
Hi all,
Aveo makes lot of tyre noise on rough roads. Specifically on Mumbai-pune expressway which is made up of concrete, I find that as soon as you touch decent speed (80kmph), the tyre noise is noticeably high. This is with windows rolled up. On smoother tar roads, the noise disappears and the difference is very clear. I have once travelled in NHC on the same expressway and NHC had little or no tyre noise at all.
Any observations or solutions on this ?
Thanks.
-- ksr.
ksr is offline   Reply With Quote
Old 5th August 2007, 15:05   #2
bottle's Avatar
Thanked: 138 Times
goodyears ?
bottle is offline   Reply With Quote
Old 5th August 2007, 15:43   #3
vnabhi's Avatar
Thanked: 1,311 Times
Goodyear radials make a lot of noise above 80kmph. I had them long back on my 800. When I changed to Bridgestone, the sound disappeared.
Old 5th August 2007, 16:10   #4
CrAzY dRiVeR's Avatar
Thanked: 19,782 Times
Most Aveo owners do change the stock tyres immediatly after delivery. Road noise is due to the Goodyear tyres that come as stock.
Go in for bridgestone/michelins if you want a change.
Old 5th August 2007, 16:24   #5
kpzen's Avatar
Thanked: 1,655 Times
Get Michelin's and u'll have silent drives forever.
Old 5th August 2007, 17:57   #6
sreenivass's Avatar
Default Michelin may be a better bet
Not sure about Bridgestone. Michelins definitely are quieter while providing better ride. On some roads my stock bridgestones on petra make noise too.
sreenivass is offline   Reply With Quote
Old 6th August 2007, 19:43   #7
rosh_aveo1.4's Avatar
Thanked: 310 Times
Had faced the same issue with my aveo. Would be considering Michelins now. Ksr, you got the aveo with thr 185/60 tubeless goodyears?
rosh_aveo1.4 is online now   Reply With Quote
Old 7th August 2007, 00:00   #8
namit's Avatar
Thanked: 49 Times
The moment i read the title of this post i knew the culprit would be Goodyears.........
Ksr !! the initial lot of aveos uptill 2007 came with Goodyears .......... even i am switching to Bridgestone.
BTW ... do u notice car skidding on bad / potholed roads on speeds between 30 and 50 kms/hr ????
namit is offline   Reply With Quote
Old 7th August 2007, 00:49   #9
iraghava's Avatar
Thanked: 156 Times
Well the tyre noise is primarily caused by tyres & their patterns. Some produce a lot of noise (Goodyear Eagle F1 series) and some produce nearly none (Michelin Energy XM1 series).
So, this problem can be solved in most cases by a simple replacement of tyres with better ones.
Old 7th August 2007, 17:18   #10
ksr
Hi all,
Thanks for your replies.
I bought Aveo two months back and it is March 2007 model. It has 185/60 Goodyear tubeless tyres. Didn't know at that time whether tyres are good or bad.
Namit, I haven't noticed any skidding on the stock tyres.
How much approximately the Michelin tyres would cost if we want to replace the stock tyres after 2 months of use. (approx 1500 kms). ?
Old 11th September 2007, 01:07   #11
kamy450's Avatar
Arrow
Originally Posted by ksr View Post
Hi all,
Same issue i am facing and would like to know the expenses behind this,
i would go for exchange and i have done 2300 kms so far. Please suggest.
kamy450 is offline   Reply With Quote
Old 11th November 2007, 22:45   #12
itwasntme's Avatar
Thanked: 1,727 Times
All you guys,
Apologies for bumping up an old thread but did any of you get around to actually changing the tyres? Specifically to 195s or 205s?
Thanks,
itwasntme is online now   Reply With Quote
Old 11th November 2007, 23:09   #13
jerish666's Avatar
Go for Michelin Energy.It doesnt have any sounds.I am using that on my skoda 205/55/R16.
jerish666 is offline   Reply With Quote
Old 12th November 2007, 12:23   #14
Default Bridgestone Turanza
Some lots of Aveos have Bridgestone Turanza and I was lucky enough to get one of those in my July '07 model.
They are very good on comfort and low on noise.
arup10 is offline   Reply With Quote
Old 12th November 2007, 13:43   #15
kpzen's Avatar
Yes they are better than Goodyears which also comes with Aveos..
Try Michelins or Yokohama next time they are even better.
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Aveo Shocks noise agbenny Technical Stuff 11 20th May 2011 20:36
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Aveo vs Verna EDIT: Bought Aveo an10 Sedans 82 8th April 2008 17:01
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
