Old 6th August 2007, 12:39   #1
Thanked: 52 Times
Default Indica Drive shaft problem
Hey guys
I need to know if the universal joints on the drive shafts [both left and right] can be changed or do I have to buy complete drive shafts[axles]. Cause the joints are available in the market at Rs 400/- each and the complete set along with the shat is 5000/- each. My mechanic and My cousin both say that they can be changed and they have done it, the service station says I need to change every thing ....the service station usually trys to get money this way, I had bad experience with them with my fuel system. they told me to get the pump serviced at 70,000km as the engine did not ideal properly, I paid 6000/- for this and then found out from the person from MICO where the pump was serviced that only the filter casesing where not properly fixed and had a gap in it so air was sucked in the system [servicing this would be Rs 300 /-]
so please advice on this....
dinar is offline   Reply With Quote
Old 6th August 2007, 22:45   #2
Pankaj401's Avatar
I am not sure about the CV joints but you can have those re-machined for a grand each. Those would survive for not long though depending on your driving demeanor.
What are the symptoms that your car is exhibiting to conclude that you have bad CV joints?
Pankaj401 is offline   Reply With Quote
Old 6th August 2007, 23:35   #3
nikkibike's Avatar
Default Thatz a complete rip off!!
Thatz tooo much man!! I too had an Indica few yrs back and I too have reclaibrated the pump and injectors for less than 1500/-!!
Also, I didn't had any troubles with the drive shafts (no sounds) till I sold it at 98k kms!! As your mech and cousin says... try changing the parts and see the performance..... thatz a lot more cheaper than the other option also!!
nikkibike is offline   Reply With Quote
Old 7th August 2007, 00:34   #4
1100D's Avatar
Thanked: 2,360 Times
Can you please explain the original problem for which the Driveshafts need to be replaced?
1100D is offline   Reply With Quote
2009 Skoda Fabia Diesel 1.4 TDI - 93K KMs - Engine Crank shaft problem KishoreC Technical Stuff 37 14th January 2017 09:59
Accent Crdi Drive Shaft Problem!! kphilip Technical Stuff 22 25th October 2010 23:26
Drive shaft for Baleno sundabs Technical Stuff 4 23rd February 2009 15:39
Drive shaft sound-how long will it last now? deetee Technical Stuff 8 7th February 2008 21:11
Drive shaft noise - Need help girishab Technical Stuff 15 18th April 2005 19:29
