Old 3rd September 2010, 11:40   #526
Visaster's Avatar
Thanked: 199 Times
Damn rats chewed away my car rubber tubing when it was parked for 3 days straight without moving. Had to get it changed before i could even think of moving my car. Missed an appointment, late to work, Tension and money loss...
They have a liking to immobile vehicles, so drive your car and dont just keep it parked, especially during the rainy season.
Get rid of all the bushes around your house
Stop throwing junk around the car park.
Keep a clean environment and vola no pests.
Get pest control. they do a great job. Never tried for the car
Next time it happens, i will go all the way to get ride of their whole kandhan.
Visaster is offline   Reply With Quote
Old 3rd September 2010, 11:50   #527
Guys,
Luckily i have do not have such problems with my cars. But, back at my hometown rats are building up their arms it seems.
So i got some sticky pads (not sure what it is called, i got them from my pest control fellows) which has a glue on it (mind you pretty strong for rats). Get those, keep it under the engine bay or if you can accomodate inside whereever there is a threat.
And BOOM...u dont feel guilty of killing those rats but will be happy of trapping them
Lets face it, we think we are smart, they are much smarter as they live under ground
Try it, might work for you as well...
parashakthi is offline   Reply With Quote
Old 22nd September 2010, 14:59   #528
Thanked: 7 Times
Default My Swift - fighting a losing battle against rats.
For last 2 years rats have made the air intake duct (A/c) under my Swift bonnet, as their abode. To avoid all the trash coming into the passenger cabin, the recirculation flap is permanently kept shut and occasionally got cleaned at MASS. But last week someone accidentally switched off the recirculation button and a lot of muck nearly jammed the blower fan. Later found that even in recirculation mode, outside air was getting sucked in.
Took it to a local A/c mechanic. He opened up and cleaned the blower as usual and when he inspected the flap, he found the flap closing motor was getting jammed. The flap was only partially closing allowing the rats to sink in their teeth into the flap and gnaw at it. Today I have got the flap motor to be disconnected and the flap to be kept in a closed position with a hole where the plastic has got gnawed out by the rats.
I am at my wits end regarding how to solve this rats problem. Unless I have a permanent solution no use replacing the flap and maybe the motor too.
emkay456 is offline   Reply With Quote
Old 22nd September 2010, 15:29   #529
planet_rocker's Avatar
Thanked: 367 Times
there is a similar thread running: http://www.team-bhp.com/forum/techni...highlight=rats (How do you protect your car from rats?)
you can use the following as a measure:
1. tobacco leaves available with the pan-wala
2. sticky pads available at small grocery stores
3. mouse trap below the engine.
planet_rocker is offline   Reply With Quote
Old 22nd September 2010, 16:06   #530
speedsatya's Avatar
Thanked: 706 Times
The brush is the most effective of all the listed solutions
speedsatya is online now   Reply With Quote
Old 22nd September 2010, 16:40   #531
Thanked: 59 Times
For me, Brushes along with tobacco and hammam soap are working wonders. Till date, touch wood. Explore the losted options by others.
lambuhere1 is offline   Reply With Quote
Old 23rd September 2010, 22:46   #532
Sushubh's Avatar
holy cow. i noticed a live rat in the dickey of the car today.
took it to a washing station. they searched through the dickey and inside the car. still cannot locate the damn thing.
it is still somewhere inside the car because i can see **** on the floormat.
currently i have placed a mouse trap in the dickey of the car.
i would try getting tobacco leaves. and look for more tips through this thread.
Sushubh is offline   Reply With Quote
Old 9th November 2010, 12:22   #533
n.devdath's Avatar
Thanked: 1,737 Times
Brushes? Can you please elaborate.
Also, I have sprayed phenyl in the engine bay of Hariya. Do you think it would work? I will get naphthalene balls today and tie them as well.
Old 9th November 2010, 12:40   #534
shishir_bn's Avatar
Thanked: 104 Times
Forget about these Dev, Just tie tobacco leaves in the engine bay and you will not see any rats near your car. Proved and tested.
shishir_bn is offline   Reply With Quote
Old 10th November 2010, 16:16   #535
n.devdath's Avatar
Not working Sir, Hariya was attacked again, yesterday.
Old 10th November 2010, 17:31   #536
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 461 Times
With all these colorful brushes, hanging pearls (naphthalene balls), tobacco leaves, hanging socks, sticky pads etc. the engine bays would be looking like decked up fairgrounds inviting the rats over.
What about placing some LED lights (3-4 of them) powered by cells or car battery in the engine bay and turning them on at night? Will that work?
pjbiju is offline   Reply With Quote
Old 11th November 2010, 00:21   #537
yogi1771's Avatar
Tobacco leaves do not work,while buying the tobacco leaves the dealer asked me why do you need them so told him the reason the answer he gave me was they don't work cause the the sacks in which they are stored are also chewed up by rats.
yogi1771 is offline   Reply With Quote
Old 18th November 2010, 15:58   #538
n.devdath's Avatar
Hi All,
Please read my post in the link below and suggest what can be done. This has become a never ending issue now.
http://www.team-bhp.com/forum/test-d...ml#post2144864
Old 19th November 2010, 12:30   #539
Sushubh's Avatar
nothing has worked for me now. roamed around the city (gurgaon) and finally managed to get this...
the plastic quality is not very great. i am not sure if it would be able to hold a big sized rat.
funny enough, when i was placing this thing in the car's boot, the rat was right in front of my eyes in the boot! and i could not do anything. seriously. very annoying.
Old 6th December 2010, 16:21   #540
I have a santro Every night rats enter inside the car. Does anybody know
from where the rats enter the car ? Not sure if the rodent is a rat or mouse.
I have managed to kill about 5 or 6 of them by placing poison cakes, but they keep on coming :-(
nd81 is offline   Reply With Quote
ARTICLE: How to protect your car from THEFT Dippy On owning a car 244 7th December 2017 18:40
Insurance against electrical damages due to Rats etc. psp62in Indian Car Loans & Insurance 6 25th July 2016 21:39
How to protect your car on 'Holi' akash_m Technical Stuff 15 21st March 2008 23:30
Rats! tsk1979 Technical Stuff 9 28th June 2005 17:03
