View Poll Results: How long do you wait to switch on the AC in your car during a cold start ?
Immediately on starting 52 22.51%
1-2 Mins after start 92 39.83%
4-5 Mins after start 71 30.74%
10 or more Mins after start 16 6.93%
Voters: 231. You may not vote on this poll
Old 5th June 2008, 20:41   #166
jassi's Avatar
Thanked: 11 Times
Smile
i vote 4-5 mins cos thats when my santro's engine gets heated up good enough
jassi is offline   Reply With Quote
Old 7th June 2008, 21:04   #167
sidd_city's Avatar
Thanked: 11 Times
In the NHC we don't have a temprature gauge, we got hot and cold lights instead. So when I cold start I idle till the cold light goes off which takes a min or so and by the time i reverse the car out of the garage its warm enough to switch on the AC.
sidd_city is offline   Reply With Quote
Old 7th June 2008, 21:36   #168
DirtyDan's Avatar
Thanked: 776 Times
Default All wrong so far
You are all wrong so far. Amazing. What a bunch of chuckle heads!!!
The correct way is for you to sit quietly in your favorite chair sipping a cold beverage while you watch the news or ESPN. Let your good and dutiful wife go out in the blazing hot sun and start your car and turn on the A/C. Then after a few minutes when the car interior has cooled sufficiently, sally forth and take on the day.
It does not matter how she does it, as long as she does it. She will thank you later for letting her attend to your needs and letting her find fulfillment as a woman by serving you. Do not deprive her of these small happinesses.
Old 7th June 2008, 23:10   #169
Thanked: 660 Times
lolz! what if you are somewhere else far from home!
Old 25th June 2008, 11:44   #170
esteem_lover's Avatar
Thanked: 451 Times
You are damn lucky to have such a wonderful wife, congratulations.
Old 25th June 2008, 11:47   #171
Rahulkool's Avatar
Thanked: 591 Times
In the morning i start the car and let it idle for 4-5 minutes, then move the car outside and switch AC on full with rear windows open, and while i close the garage door and came back , its super chill ...... otherwise i switch on the AC 2-3mins after starting the car ....
Rahulkool is online now   Reply With Quote
Old 25th June 2008, 12:26   #172
rider60's Avatar
Thanked: 47 Times
i turn on the ac immediately but idle the car for 1-2 minutes with the ac on and windows down, because the cars i have are diesel and idling is a must for the car's (turbo's) health, and i am chilling and fiddling with the ICE at the same time.
rider60 is offline   Reply With Quote
Old 25th June 2008, 12:44   #173
Thanked: 146 Times
i dont know how it works for mpfi engines but in a carb engine in perfect tune cranking, ac on and immediate movement is not a problem and in winter with heater on, again its not a problem as the Fast Idler Breaker will come do its job to keep the revs higher until the optimum engine temperature is attained and then revs will drop to normal idle.
Jr Godzilla is offline   Reply With Quote
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
Karizma Cold Start Problem jazzy_2cool Motorbikes 18 19th May 2010 18:07
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
How many KMs after cold start the car will feel better sreenivass Technical Stuff 30 13th November 2009 12:14
Esteem 2001 White smoke on Cold start Slick Technical Stuff 9 3rd April 2008 02:16
