View Poll Results: How long do you wait to switch on the AC in your car during a cold start ?
Immediately on starting 52 22.51%
1-2 Mins after start 92 39.83%
4-5 Mins after start 71 30.74%
10 or more Mins after start 16 6.93%
Voters: 231. You may not vote on this poll
Old 12th September 2006, 23:37   #1
esteem_lover's Avatar
Thanked: 451 Times
Default Switching on Your AC in Cold Start
In the morning rush hour, when you start your car for the first time, do you give the engine enough time to heat up & then switch on the AC ? This is one thing most of us fail to do. So let us see which is the majority here. I am giving 4 options here. A.C is switched on after
1. Immediately after start
2. 1-2 Mins after start
3. 4-5 Mins after start or
4. 10 or more Mins after start.
I know, for some of us the whole drive wont be for more than 10 mins. And some of you are living in cold places where you dont need to switch on at all.
Which of these is the best to follow ? experts can pour in with their opinions please.
cheers
Old 13th September 2006, 15:35   #2
naveendhyani's Avatar
Thanked: 7 Times
delhi is too hot . so i start the car, unlock the parking gate, open it & when i sit back, i turn on the A/C with blower on full blast with the back windows open. keep it like that for 1-2 minutes & then reduce the blower to 1-2 as per requirement & close the windows.
one should always open the rear windows to allow the heated air of the cabin to dissipate resulting in faster & efficient cooling.
naveendhyani is offline   Reply With Quote
Old 13th September 2006, 15:54   #3
pradeepmm's Avatar
I read it in the manual (Honda City). Keep the rear windows open and switch on the Blower to the max for around 1 minute. Resulting in pushing the heat air out. Then close the rear windows and switch on the A/C.
Since that all cars have two modes of intake air settings.
1. Intake the air from outside (will take couple of seconds to cool)
2. Circulate the inner air. (this results in faster cooling)
pradeepmm is offline   Reply With Quote
Old 13th September 2006, 16:04   #4
nitrous's Avatar
Thanked: 285 Times
@esteem_lover: No matter how enthusiastic u're about cars, when u live in a place like chennai, u just switch on the AC as soon as the ignition is turned on.
All the blah-blah about engine condition,AC condition isn't much cared for.
Moreover, Synthetic oil always helps keep the engine from wear&tear!
Old 13th September 2006, 16:11   #5
trrk's Avatar
Thanked: 13 Times
Unfortunately the four choices do not contain my way.
The AC is permanently on. The car is started with the AC on.
trrk is offline   Reply With Quote
Old 13th September 2006, 16:15   #6
navin's Avatar
Thanked: 4,286 Times
Still Oil does need a few cycles to circulate after an overnight rest.
I'd say 15-30 secs should be enough. After all in hot weather the car is not really that cold!
Old 13th September 2006, 16:26   #7
Thanked: 451 Times
very true, especially in the mornings, when you are in a hurry to get started & going, i sweat a lot & if the AC isn't running when iam inside the car, i would drown in my own sweat. LOL
Old 13th September 2006, 17:37   #8
Smile A/c!!!
Well there are 2 reasons why I guess you shoudl give it a good gap irrespective of outside temperature, only during a cold start. When I say cold start, I am refering to the start that has to be done, when the car is left overnight in the garage!!! and not when left in the place like outside your office or bank or any other place!!!
There are 2 good reasons for giving a 5 mins gap. ONe the main one being that the engine needs to be kept warm before it is sapped off power because of the AC. This will ensure that the baby is really hot to handle additional load
The second reason being that its a good idea to open your windows and let off all the stale air thats inside the car by opening the windows for a while or two and thus also warming the car on the run!! Then start the blower with outside air to come in, start the AC and let this run for around 20 - 30 seconds and the finally close the outside air vent!! This will keep good the AC and the car.
Exceptions, when you are driving through dust, dont make the mistake of opening the window or runnign blower with outside air in!! Well this is my view and method, it need not be the best. Your comments!!
vincentt is offline   Reply With Quote
Old 13th September 2006, 19:20   #9
Knight Rider's Avatar
Thanked: 11 Times
Okay this question is a little bit out of context, But does the blower speed has anything to do with your cars F.E?
Knight Rider is offline   Reply With Quote
Old 13th September 2006, 19:56   #10
MalluDude's Avatar
Thanked: 39 Times
Not at all. Doesn't matter how you keep the blower speed.
MalluDude is offline   Reply With Quote
Old 13th September 2006, 19:56   #11
supremeBaleno's Avatar
Thanked: 1,711 Times
It sure does. Higher the blower speed, higher the load on the engine and lower the FE. However, I am not sure whether there are any exact figures as to by how much the FE goes down.
Old 13th September 2006, 20:15   #12
quicksilver's Avatar
I normally wait like 10-20 secs before I switch ON the A/C. Have this problem with rolling the windows down that makes me feel "Exposed" and vulnerable some how...
quicksilver is offline   Reply With Quote
Old 13th September 2006, 21:10   #13
angelfire's Avatar
Originally Posted by trrk
Not such a nice thing to do buddy..atleast turn off the AC while startin the car....
angelfire is offline   Reply With Quote
Old 13th September 2006, 22:30   #14
It really depend upon the weather. In case weather is really hot and I am in a hurry, I switch on the AC as soon as I start the car... though I do roll down the windows for some time. In case the weather is pleasent, I start the car for a minute and then switch on the AC... Thus voted for the first option.
Sumed is offline   Reply With Quote
Old 13th September 2006, 23:08   #15
vivekiny2k's Avatar
Thanked: 184 Times
I roll down all the windows, drive for 30-60 secs, then swich on the AC, keep driving for another 30-60 secs, then roll up the windows.
I like the idea of ventilating my car once a day naturally this way.
vivekiny2k is offline   Reply With Quote
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
Karizma Cold Start Problem jazzy_2cool Motorbikes 18 19th May 2010 18:07
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
How many KMs after cold start the car will feel better sreenivass Technical Stuff 30 13th November 2009 12:14
Esteem 2001 White smoke on Cold start Slick Technical Stuff 9 3rd April 2008 02:16
