Old 9th August 2007, 18:06   #1
gopz's Avatar
Default M800 - Raised Suspension
Guys, has anyone here done this? I am planning to raise the suspension with spacers. Is it a good idea? I am doing this because the underbody hits big speed breakers even if I go at really slow speeds. I can either do this or I can replace the tyres with 145/80 instead of the stock 145/70
Will this cause any issues with the stability of the vehicle at high speeds, because CG would be higher?
Any competent mechanics who can do this in Bangalore?
gopz is offline   Reply With Quote
Old 9th August 2007, 18:51   #2
humyum's Avatar
Thanked: 2,503 Times
Go for 145/80/R12s ..have been running them in my 800 since a year and 13 thousand km.And since 13 thousand km i dont remember even once my cars underbelly touching the speedbreaker plus the ride has become softer and small undulations go undetected.
The only downside is bodyroll and the steering is not as precise as it was with the 145/70/r12s.
Also there is a speedo error of around 6 km seen on the speedo as well as the odometer.
Old 9th August 2007, 19:54   #3
humyum's Avatar
Also forgot to add the pickup decreases a tad bit.
Old 9th August 2007, 20:45   #4
dont put speacers..your handling will decrease ....
zenopio is offline   Reply With Quote
Old 10th August 2007, 09:12   #5
gopz's Avatar
Thanks guys...I would probably upgrade the tyres then
Old 10th August 2007, 09:47   #6
Ram
Ram's Avatar
Thanked: 149 Times
@gopz: Do read my experience with the 145/80R12 tires.
http://www.team-bhp.com/forum/tyre-a...800-tires.html
It even influenced humyum to change to 145/80R12.
Ram
Ram is offline   Reply With Quote
Old 10th August 2007, 10:02   #7
gopz's Avatar
Ram, do you also have the same issue with steering, like humyum? after the tyre upgrade?
Old 13th August 2007, 12:16   #8
Ram
Ram's Avatar
Thanked: 149 Times
@gopz: No, I have no issues with steering at all. I am very happy with the tire upgrade. That said, I feel, installing a strut-brace across the McPherson strut towers will improve the Maruti 800's cornering. I have not yet done that, but intend to do so, soon!
Pune - Mumbai expressway toll raised to Rs.165 wanderlustindia Shifting gears 51 24th March 2017 19:07
You'll never see a Rolls Royce with its hood raised v12 Super-Cars & Imports in India 13 4th September 2012 23:12
Fiat - Punto/Linea prices raised by up to 3k echo77 The Indian Car Scene 20 20th June 2011 15:15
