Thread Tools
Old 10th August 2007, 10:13   #1 (permalink)
Default Windscreen Washer problem
Hello Friends,
You have always helped me in tackling issues with my car.Thanks a ton for the same.
2-3 days back I have noticed that the windscreen washer fluid streams in my SWIFT are not oozing out with force.Previously water streams used to be in such a force that it reached roof of the car.
Now whenever I do that to clear the windscreen, water streams come out about a feet and half high maximum.
I thought that there may be less water and so I tried to fill it up.But it seems that there is adequate qty.of it and problem still persists.
Please let me know if I can do something myself to solve the problem or I need to go to MUL workshop for this.
Thanks and Regards,
Rajendra
raja748 is offline   Reply With Quote
Old 10th August 2007, 10:47   #2 (permalink)
ad75's Avatar
there might be some dust/grime blocking the flow of water use a pin to clear the nozzle,while you use the washer.
ad75 is offline   Reply With Quote
Old 10th August 2007, 10:52   #3 (permalink)
rishibravo's Avatar
Check if the pressure has reduced in both the sprinklers or just one of them. If its in just one of them then cleaning the nozzle with a pin will help . Otherwise there is something stuck in the hose which supplies water to the two nozzles.
__________________
Boyz will remain Boyz.......Only their Toyz change
rishibravo is offline   Reply With Quote
Old 10th August 2007, 10:59   #4 (permalink)
The pressure has been reduced in both the nozzles.Pls tell me how to check/clean the pipe?Thanks.
Old 10th August 2007, 11:08   #5 (permalink)
sushrutha's Avatar
I second this...
Clean the nozzle with a pin. Or else check out for any leakage in the hose pipe
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 10th August 2007, 17:26   #6 (permalink)
n_aditya's Avatar
Open the hood. U will see the pipes on the bonnet cover (generally thin and transparent) which direct the water from the reservoir to the jets. Remove the pipes, blow into them to clean any particles lodged inside, refit them and you're good to go.
__________________
RIP Tootie !!! Missing you terribly.
Old 11th August 2007, 07:21   #7 (permalink)
goldsun's Avatar
Clean the Nozzle and it should be OK.
__________________
Have a pleasant and safe driving
goldsun is offline   Reply With Quote
Old 11th August 2007, 09:19   #8 (permalink)
Moby's Avatar
I had the same problem, it was caused by the dirt in water.. Use a small pin, to clean the jets .Always use clean water for Windhseeld washer.
Moby is offline   Reply With Quote
Old 16th August 2007, 13:30   #9 (permalink)
Default Thank you
Dear Friends,
Thanks a lot for your suggestions.You have helped me out as always..
Thanks.
Thread Tools
(DIY) Head lamp washer manikjeet Modifications & Accessories 33 31st July 2008 17:39
Missing wiper washer cap nirmalts Modifications & Accessories 5 17th May 2008 11:44
Windscreen Defogger Problem in My Accent harsha.cs1 Technical Stuff 18 28th April 2008 12:28
Headlight washer project moralfibre Modifications & Accessories 21 26th June 2007 22:31
Portable pressure washer available? jp1 Modifications & Accessories 17 10th July 2006 11:31
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
