Old 12th August 2007, 11:54   #1
Default Tactrix - OBD-II query
Hey Ya'll,
Does anyone know about MUT-II or MUT-III reader. I managed to get a Tactrix cable work in our Lancer... The Tactrix cable has pin 1 blank so I had to disengage the pin 14 (which is blank in our Indian Lancer) and connect it to pin 1 location. (Not ground yet)
Now after doing this the ECU is transmitting codes...but the readers which I am using is EVOSCAN. Evoscan claims to read the codes from an EVOIV ECU which is same as our Indian Lancer ECUs (...bloody restricted).
I can see the ECU entering Transmission mode but make the software read it...
Note;The tactrix cable also has a Flash port which is not applicable in my case. (Not sure about the new Cedia though!!)
Can someone please help?
get_hiyyer_714 is offline   Reply With Quote
Old 12th August 2007, 21:40   #2
Ford Rocam's Avatar
Thanked: 16 Times
OBD II uses 4 distinct Protocols to communicate with the outside device using a diagnostic port depending upon vehicle to vehicle they are mainly
1) SAE J1850 PWM
2) SAE J1850 VPW
3) ISO 9141-2
4) ISO 14230 (KWP2000)
Some latest cars post 2004 uses CAN (Controller Area Network) communication protocol, U need to find out what protocol is used by Mitsu in your current ECU & your scanner should support that or else get a scanner which supports all four protocols.
Ford Rocam is offline   Reply With Quote
Old 13th August 2007, 11:09   #3
1) SAE J1850 PWM
2) SAE J1850 VPW
3) ISO 9141-2
As far as I know most of the Asian vehicles use IS0-9142...also the showrooms here use protocols which support the ISO-9142.
Old 9th July 2010, 16:23   #4
sarath's Avatar
Bumping up this old thread. Get_hiyyer, any success in datalogging from the Lancer 4G15 ECU using EVOSCAN ?. I was in the lookout for an affordable option to datalog from the Lancer 4G15 ECU and display the data using a CarPC setup.
Couple of months back, I came across evoscan . After a bit of reading, assumed that the OpenPort 1.3D cable is the cable that we need to read from our Indian Lancer ECU. I had ordered one cable couple of months back but made a mistake in chosing a standard shipping without tracking option. The cable hasn't reached yet and I have no idea about its status.
Guys, has anybody been able to successfully read parameters from a 4G15 ECU?. I am particualrly looking for a cable-software combo and not a handheld tool. The generic OBDII tools like ScanGuage will not work with Mitsu ECU. If my pocket allows, I will order one more cable again- this time with tracking option, but then I am not sure if it is going to work with this ECU. Any pointers welcome.
sarath is offline   Reply With Quote
Old 24th July 2010, 20:42   #5
sarath's Avatar
Smile Finally able to datalog from the Lancer 4G15 ECU
Update: After long contemplation, once again ordered an OpenPort1.3D cable from EVOSCAN last week. Got the cable today via DHL Express courier. I dont have a laptop, so had to bring my PC near to the Car. Connected one end to the DLC, other end to the USB port of the PC. Started EVOSCAN and it could connect to the ECU in the first go . Tried logging some parameters like rpm, Air temp, Throttle position, AFR, Coolant temp, Air flow etc and it works like a Charm. I am so happy.
Since I don't have a laptop, couldn't do much testing. A friend has agreed to lend his laptop for a week, so will update details in the OBDII thread once I get it.
Cable used: OpenPort 1.3D
Software: EVOSCAN v2.6
Old 5th October 2011, 16:48   #6
shekhar_gogoi's Avatar
Thanked: 11 Times
Default Re: Tactrix - OBD-II query
Guys I need a help here. Can anyone tell me if there is a ODBII port in a 2000 model lancer? And where is it located (if there is one!!)...
shekhar_gogoi is offline   Reply With Quote
PC to ECU Interface (OBD compliant cars) turbo_c Technical Stuff 48 9th March 2015 13:34
OBD-II scanner for Gypsy COUGAR Technical Stuff 5 21st December 2009 20:03
OBD-2 Handheld Scanner NPD: Survey subache Shifting gears 3 16th November 2009 14:31
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
OBD For Logan and Other Cars ezee Technical Stuff 0 12th October 2009 17:29
