Old 13th August 2007, 15:31   #1
Default Wind Noise in Safari
Hi Guys,
I have recently bought a Safari LX last tuesday and have travelled around 1000kms in the last few days. There is a lot of wind noise from the driver side door while travelling above the speed of 100. while there is no noise on the other side. Has anyone faced this problem.. is there a solution to it??
Ramkumar is offline   Reply With Quote
Old 13th August 2007, 16:28   #2
1.check for any gap in between the glass pane and the rubber beading.
2.does the door close properly?
take it to a TASS near you.they'll mend it.
doctorkats is offline   Reply With Quote
Old 13th August 2007, 17:58   #3
simply_sunny001's Avatar
Thanked: 15 Times
Originally Posted by Ramkumar View Post
Hi Guys,
The beading seems to be the culprit here.its' pasting shd have gone off from the corner of the doors,so resulting in the wind noise.
try using a bash of engine oil on the beading and wipe off from cloth
it will make the beading bind in more closely with the door.
simply_sunny001 is offline   Reply With Quote
Windshield - Wind Noise bjawah Technical Stuff 4 11th September 2014 16:25
Eliminating Wind Noise Seacat Technical Stuff 12 31st July 2014 13:51
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
