Old 25th August 2007, 22:51   #16
PatienceWins's Avatar
Thanked: 265 Times
Originally Posted by PatienceWins View Post
Hi Moral, My understanding is that reseting the ECU programs the ECU with new value based on the modification. The diagnostic tool is gr8. Will try that as well. But will the device give the recommended setting after any modification or it just displays the current value?
Tried the diagnostic tool from hyundai today when i visited them..they checked different sensors and the car is fine..
PatienceWins is online now   Reply With Quote
Old 6th July 2010, 01:52   #17
dhanushs's Avatar
Thanked: 4,126 Times
Why should one do ECU reset? Think you guys should find an answer to that first
rj, just follow the steps in post #1. 30-45 min if you want
the 4th point is the answer to why we do this. If you want more performance, skip that step and drive your car as you usually do when you want performance out of it, for about 4-5kms atleast.
Hey, I'm brushing up this pretty old thread.
Well, jkdas, After resetting the ECU, will sprinted driving tune the ECU towards 'sporty' values, and 'sedate' driving tune it towards economy?.
Like, will be be able to get the car perform well or extract more economy with an ECU reset??.
Old 6th July 2010, 03:35   #18
ghpk's Avatar
Thanked: 192 Times
ECU reset will not do any wonders to your car.
only thing it would to is re-arrange all incoming sensor values and arrange them to nearest value set by manufacturer, for best diagnose its better to get car checked at A.S.S. using the ECU Scanner before/after you D.I.Y.
Old 6th July 2010, 04:25   #19
CPH
Thanked: 33 Times
All the so called 'reset' does is deleting the long term fuel trim. The long term fuel trim is adjusted constantly because of changing ambient conditions, cloog rate of the filter etc.
The ECU would adjust to a new filter in any case, whether the long term fuel trim is deleted or not.
When the long term fuel trim is deleted the ECU operates from the base map and adjusts to a preferable setting after runjing through the different mapping points.
CPH is offline   Reply With Quote
Old 6th July 2010, 16:05   #20
dhanushs's Avatar
Hey ghpk & CPH , I too was of the same impression until THIS made me think otherwise?.
Check out the 4rth point jkdas mentioned.
Old 6th July 2010, 16:15   #21
clevermax's Avatar
Thanked: 419 Times
If you drive it in a sporty manner (instead of idling) after reconnecting I guess the long term fuel trim will be assigned richer or sporty or bigger (or whatever it should be called) values. This will be good start if you intend to drive the car like that every time.
But, what kind of difference it will anyway make, when you do all these after installing just a new K&N filter? I guess the difference is negligible but your mind tends to think that there is some significant improvement in performance!
clevermax is offline   Reply With Quote
Odometer Reset on Apache FI FZ6 Motorbikes 18 28th August 2012 18:01
Attn i20 owners! Hyundai's installing a Rubber Cover to protect the main ECU Cable tsk13 The Indian Car Scene 51 23rd July 2010 22:50
Accent ECU Reset - Is it advisable? jasher26 Technical Stuff 15 20th October 2009 15:53
Esteem Battery discharged -ECU reset muke31 Technical Stuff 12 4th September 2008 16:03
