Old 15th August 2007, 07:12   #1
Default Cold starting with the new Indica NA
Hi all
i got a new indica DLS (NA). But it has got a problem with cold starting. Whenever i crank it doesn't start. i have to manually pump diesel by pressing a black bush or button under the hood. the problem is there only while cold start(starting after 4 or 5 hrs after parking). what could be the problem.
Also there is black smoke comin out of exhaust sometimes. is it normal behaviour of diesel cars.
Thanks,
HAPPY INDEPENDENCE DAY
sidharths84 is offline   Reply With Quote
Old 15th August 2007, 14:59   #2
condor's Avatar
Thanked: 4,911 Times
Sidharth, these are not normal behaviour. pls take the car to your dealer.
Old 15th August 2007, 15:59   #3
ATRONIX's Avatar
Almost all of the indica's have starting problems.
Mine had too.
Had to open the starter and replace it's carbon.It's fine now.
I think you should take her to a mechanic and have the starter checked.
ATRONIX is offline   Reply With Quote
Old 3rd September 2007, 14:14   #4
anonymous's Avatar
Thanked: 15 Times
I think I have also started facing the problem.
I have driven my Indica 70K so far and never had such starting problem but now I have noticed that it doesn't start in first crank. I have to keep the key on and push the padel and than it starts after 4/5 seconds, where earlier it used to get started in half crank. I have just done the service but this issue is still there.
anonymous is offline   Reply With Quote
Old 3rd September 2007, 16:55   #5
kpbhatt's Avatar
Thanked: 23 Times
hi i had this problem with my indigo and it was due to a fault in the heater switch -- it has been taken care of -- i was told by the service guy that many indica's\indigo's have been known to have faced this problem.
kpbhatt is offline   Reply With Quote
Old 3rd September 2007, 16:57   #6
anonymous's Avatar
Thanked: 15 Times
Kpbhatt,
Thanks for the suggestion. I will goto TASS and get it checked soon.
Old 3rd September 2007, 17:38   #7
nikkibike's Avatar
Default check everything!
Heater switching system, heater plugs, starter motor, rate of Battery charging etc etc!! Any NEW car should start with a single flip of the key!!!
ANYTHING other than that is NOT normal!!
nikkibike is offline   Reply With Quote
Starting the Engine in Snow / Cold Areas Bapu Technical Stuff 62 28th January 2014 09:39
Old Indica LEi / New Indica DLS / New Alto LXi shuvc Hatchbacks 20 19th February 2008 17:31
Starting problems Indica DLG vfmanuel Technical Stuff 19 14th December 2007 00:09
Starting problem in INDICA... hianooo Technical Stuff 29 17th April 2007 18:15
Indica Turbo --Screeching sound while starting?? werfish Technical Stuff 8 4th March 2007 14:18
