| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) |
| Awaiting Email Confirmation Join Date: Sep 2006 Location: Chennai
| Chetan, Agreed with you - my car runs better @ cold too... possibly bcoz it is in open loop till 02 gets heated up as well... VAG has measuring blocks - one group shows retard for cylinders - none shown. 6-8 degress not % - sorry typo. Flipsyde, my car drives great otherwise - you should ride in it to feel the mid range. ![]() Thanks,
__________________ Octavia 2.0L [K&N, Magaflow Can, Full decat, Custom Skirts+Spoiler, Alloys, BlueVision 100/90, OWS Plugs, Art Leather, Tuning-VAG] |
| | #32 (permalink) |
| BHPian Join Date: Jun 2005 Location: ERNAKULAM
| On cars with a piston and cylinder( hence wankels are out since they always tend to run rich). Running on a mixture of Gasoline, adultration and 5 to 10 % ethanol blend. On any planet with an atmospheric content similar to ours When warm 11:1 and when it is hot about 12.5:1. The piston cylinder engines rarely achieve the stoichiometric ratio of 14.7:1.. Thats only a dream/goal to achieve with pollution norms geting stricter. AutoSpeed - Real World Air/Fuel Ratio Tuning K&N Air/Fuel Ratio Monitors Air-fuel ratio - Wikipedia, the free encyclopedia Air-Fuel Ratio Meter Tuning- Car Craft Magazine NGK Powerdex AFX Wideband Air-Fuel Ratio Monitor Kit Last edited by drpullockaran : 20th August 2007 at 01:37. |
| | #33 (permalink) | |
| Quote:
Read the previous URL's I posted inthe preceding post. | |
| | #34 (permalink) | |
| Quote:
Read the first URL to understand about faulty sensor and its diagnosis. The OBD connector isnot the sure fire way to diagnose a faulty sensor. Last edited by drpullockaran : 20th August 2007 at 02:12. | |
| | #35 (permalink) | |
| BHPian Join Date: Nov 2006 Location: Chennai
| Quote:
i've had issues similar to yours on a optra 1.8 upon cold start.... just as soon as the engine reaches normal operating temperatures its as responsive as usual. @chetanhanda - when your trying to spin your wheels i'm sure you don't let the clutch go at cold start RPM's (1200-1500). what i mean is in a cold engine when you punch the throttle it takes .5 sec before it gives you the revvs unlike a hot engine. its always been this way for me. @octy2 - nevertheless i'd like a ride it it sometime.
__________________ An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright Last edited by flipsyde : 20th August 2007 at 22:28. Reason: almost missed a chance to ride in a fellow t-bhp members car | |
| | #36 (permalink) | ||
| BHPian Join Date: Mar 2005 Location: Minneapolis
| Quote: dude !! first of all relax !! u are mixing up 2 things we are dscussing his AFR at idle, please read the 1st post.Quote:
It makes sense to have 11 to 13 when u want power or under hard accelaration. 1st of all u should understand that 12:1 or 13:1 etc etc is good for power when the engine is loaded or accelarating. everyone knows that optimal bhp is not @ 14.7:1... But at idle when the air is being supplied by the secondary IAC/EAC etc u dont need 11/12/13:1 ratio ..u dont need BHP u just need sufficient air to keep the engine alive with minimum emissons.. I hope u are aware of the secondary air control system and Tp sensor at idle ..u get an entrely diff set of readings for AFR and also consider what happens when u have a cold engine and a hot engine.. so 14.7:1 is OK at idle and 11,12,13:1 is great at engine loads under part throttle or WOT condition under load take a wideband o2 sensor, plug it in if it says ideal or 14.7 let it be... when u are accelarating or simply going wide open then go for <14... dont point us guys to another set of "basic" Urls on AFR and please no "Wikipedia stuff" .. we have seen enough of these ... and I think you should read your own URLs more carefully before asking people to tune their idle for AFR, also there is a big diff in practically seeing a tuner prepare a drag car and just reading URls... Last edited by chetanhanda : 21st August 2007 at 21:47. | ||
| | #37 (permalink) | |
| Quote:
But even If I did my engine would be more "peppy/responsive" to slight throttle inputs becoz its already running at higher RPM already due to open loop .. even "Octavia2" feels the same on his skoda .. plz explain how ur engine(when cold) would be less responsive ? in cold engine the engine is already revving higher for a TP reading as compared to when the the engine is hot(or o2 sensor is warm) for the same TP reading ... | |
| | #38 (permalink) | |
| Quote:
knock sensor , ignition retard.. nothing cutting u off ? do you get the same feel when u r in any other gear+with AC+load and try to floor the throttle ? | |
| | #39 (permalink) | |
| Quote:
Engine Modification A Literature Review Based Assessment on the Impacts of a 10% and 20% Ethanol Gasoline Fuel Blend on Non-Automotive Engines: 5. Fuel System and Control System Definitions | |
| | #40 (permalink) | |
| Quote:
e.g If I use regular pump gas 97 octane I will look for green zone on my AFR = normal during idle, again if I were to tune with a crazy higher octane race gas I would again look at my AFR and make changes.. to fuelling and timing...i would have diff maps for diff octane so at a given AFR the race gas is going to give me more power... BTW the second article is on open loop non automotive systems so I wouln't use that as a reference. the minute the o2 sensor gets warmed up the car goes into closed loop.. are we on same page.. or r u still saying u should idle at 11:1 as per lab report when ur foot is of the throttle using pump gas? if u were running a high compression high octane race gas with crazy high lift hi duration cams i would keep my AFR more rich in order to keep it from stalling or run more smoother maybe something like 13.5 etc etc .... but on a stock car with pump gas I would follow the AFR and say idle according what the AFR says is perfect "14.xyz" | |
| | #41 (permalink) | |
| Quote:
Please note that our engines in India are fed on a diet of E10petrol mixed with adulterants too and do remember that E10 absorbs moisture from the atmosphere too. I still maintain that at idle the mixture has to be far richer than when coasting along at 1500 to 2000rpm and even then we India can only dream to achieve to run with a smooth engine with ratios leaner than13.5:1. I will try and get further articles before putting up my case any further and that has to be after the Onam festival in Kerala which will be over after the 27th of August. Bye till then.Bye and wear your seat belts. Last edited by drpullockaran : 25th August 2007 at 00:39. | |
| Thread Tools | |
Similar Threads | ||||
| After Spark, GM to launch second small car in India | windsurfer | The Indian Car Scene!! | 11 | 1st August 2008 23:04 |
| Volkswagen might launch a small car in India as well | askicode | The Indian Car Scene!! | 21 | 23rd July 2007 22:24 |
| engine hesitation when turning OFF | 2fast4u | Technical Stuff | 13 | 14th September 2006 23:01 |
| GM to launch Aveo-UVA with 1.2 Ltr motor..launch by Nov/Dec'06 | ashutoshb | The Indian Car Scene!! | 5 | 12th September 2006 03:36 |
| Maruti to launch luxury car | tsk1979 | The Indian Car Scene!! | 53 | 21st December 2005 21:11 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
