Thread Tools
Old 19th August 2007, 17:54   #1 (permalink)
Default Any advice on Optra 'thumping' tire/road noise at 40KPH
My Optra Royale (1.6 ) has done 15000KM -- regular 185/64 R14 alloy wheels. I find a slighly annoying 'perodic' thumping sound at exacly 40KPH , not below and not above this speed. Apparently from the front tires. Its loud enough to be annoying to some one who is very particular about a cars running condition
Havent checked wheel balance yet but I was puzzled by the exactly at 40 and not above/below symptom. Sound occurs on neutral coasting as well.
Does anyone have any advice /comment to offer ?
Thanks in advance.
Ravich
Ravich is offline   Reply With Quote
Old 19th August 2007, 19:26   #2 (permalink)
akshay1234's Avatar
is this everywhere or only on specific types of roads? ive noticed something like this on marine drive in my innova and getz.
akshay1234 is offline   Reply With Quote
Old 19th August 2007, 20:11   #3 (permalink)
Every road!. I suspect it could be a suspension mech resonance conciding with balance problem at 40kph.
I'll check with the garage and post
Old 19th August 2007, 20:22   #4 (permalink)
drifter's Avatar
It could be a stone in one of your tyre treads. It was at least in my case.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 19th August 2007, 20:43   #5 (permalink)
BUSA's Avatar
There is a small stone stuck on your front discs, go to GM they will remove it. Faced the same in my 1.8LT a year back. Came at only one particular speed.
__________________
thecarsandmore.blogspot. com
Old 19th August 2007, 20:47   #6 (permalink)
veyron1's Avatar
Rotate tyres. Check again. If problem persists, check alignment, balancing & knuckle bushings.
Now this might sound odd, but nevertheless- check if the thumping sound is coming from under the dash, from the driver's side. if yes; check out the speedo gear/cable & rack.
But first, check the front tyres & sidewalls for wear/tear...& check them stones too..
__________________
DAD
veyron1 is offline   Reply With Quote
Old 19th August 2007, 20:53   #7 (permalink)
Busa, (or anybody else, please) if this only a stone in the tread / discs, why does this happen only at specific speeds? I have seen / heard tyres with patchwork (like when damage to the crossply fabric is repaired with patch) giving out this sound at all speeds; and have noticed transmission / differential components on the verge fo failing complaining at specific speeds / specific gears.
I can understand drifters post.
__________________
ɹǝʌıɹpʇɐǝsʞɔɐq
Old 19th August 2007, 23:22   #8 (permalink)
BUSA's Avatar
Well it happens at specific speed because of resosnance, i can assure you that there is a small stone stuck on the front discs, had the same noise at specific speeds in my Optra too so i know it was a 2 hour job for GM to remove the stone by removing the tyre and the whole disc assembly and then the stone and then putting back the whole assembly.
__________________
Old 27th August 2007, 20:20   #9 (permalink)
BUSA's Avatar
Any updates on the problem?
__________________
Old 8th September 2007, 16:45   #10 (permalink)
Apologies. (My MTNL triband has been out and could not access. )
1. I replaced the suspect wheel with the spare. Noise went down
2. Got all 4 wheels and spare balanced again
Noise went away completely.
Suspect it was balance and resonance.
BTW - do you advise alignment periodically ( 5000 , 10000) even if there is no uneven tread wear or straightline stability is good. ?
Old 8th September 2007, 16:49   #11 (permalink)
Update on the problem - interchanged suspect wheel with spare, noise reduced. So balanced all wheels. Noise went away completely. Apologies for late update. Broadband problem after shifting house.
Thinking of getting alignment done as well.
Old 8th September 2007, 18:17   #12 (permalink)
Lukeskywalker's Avatar
It's always good to get the alignment done at periodic intervals (5000kms recommended), that way you don't have to wait till there is uneven wear which is non reversible.
Lukeskywalker is offline   Reply With Quote
Old 9th September 2007, 21:10   #13 (permalink)
BUSA's Avatar
Getting the alignment right for a Optra aint a easy task since the steering tends to be off and making it straigh is ot of the capability of GM or any other tyre wala.
__________________
Thread Tools
Swift LDI issues need some advice (EDIT: Too much of road vibration?!) trancejam Technical Stuff 11 3rd October 2007 20:34
Advice for Pune to Nasik Road Trip awarty Route / Travel Queries 0 9th May 2007 19:22
KB100's Heart Thumping IC Install....... maxbhp Ask the Gurus 1 27th April 2007 09:14
Advice needed on used Optra? umvarma Sedans 26 12th April 2007 09:41
What is the price / discount offered on Optra on road in Mumbai? gutsy Sedans 5 3rd June 2006 17:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
