Old 22nd August 2007, 12:39   #1
nirmalts's Avatar
Thanked: 7 Times
Default Knick sound from horn relay
Hello,
I changed the horn in my Aveo to Roots Windtone. I notice that there is a "knick" sound soon after I release the horn. Possibly from relay. This was not there with the stock horn and it is a bit nagging. What could have gone wrong?
Nirmal
nirmalts is offline   Reply With Quote
Old 22nd August 2007, 12:53   #2
navin's Avatar
Thanked: 4,284 Times
Originally Posted by nirmalts View Post
Hello,
Nirmal
does it come when your stereo is playing (from the speakers) or even when the stereo is off.
navin is online now   Reply With Quote
Old 22nd August 2007, 13:29   #3
nirmalts's Avatar
Thanked: 7 Times
Hi Navin,
It doesnt come from speakers. It comes everytime horn is used (even without the key in)
Nirmal
Old 22nd August 2007, 13:46   #4
n_aditya's Avatar
Thanked: 2,780 Times
Seems to be pretty normal to me. My horns (roots) are also wired through a relay, PMP make. The sound you hear is the contacts or relay points opening and closing. If the relay is electronic, you wont have this sound. Get it checked by a local mechanic if u must.
Old 22nd August 2007, 15:49   #5
nirmalts's Avatar
Thanked: 7 Times
The noise is ok, but a bit nagging as it is clearly audible after the honk. Could anyone explain technically what happend between changing horns that made the relay point opening/closing audible?
Nirmal
Old 22nd August 2007, 16:15   #6
ankitahuja's Avatar
Thanked: 46 Times
I too have a similar problem. I hear a slight kir kir (electric spark) sound from the speaker only when I press the horn from the top right spoke on the steering of my OHC. It does not come if the horn is used from any other contact point.
The horns are fitted well with the relays (Red Grill and Nautilus). What can be the problem, do I have to get the steering connection checked?
Old 22nd August 2007, 17:11   #7
nirmalts's Avatar
Thanked: 7 Times
Hi Ankit,
My problem is different as the sound is not coming from the speakers.
There are some threads related to the issue you mentioned
http://www.team-bhp.com/forum/ask-gu...-speakers.html (Horn playing through speakers)
http://www.team-bhp.com/forum/ask-gu...horn is blown)
Nirmal
Old 22nd August 2007, 17:15   #8
Sam Kapasi's Avatar
Thanked: 1,473 Times
Nirmal,
I think it's perfectly normal and OK and I see no reason to worry about it.
Possibly the horn relay was changed with the horn, or the horn itself has a relay built in. Regardless, no need to worry about it.
Old 22nd August 2007, 19:52   #9
n_aditya's Avatar
Precisely... and if the noise is irritating, its time to invest in a nice ICE setup.
It already is nerve racking listening to all the traffic noise around you. Better get some good ICE and enjoy your drive.
Old 23rd August 2007, 08:52   #10
esteem_lover's Avatar
Thanked: 451 Times
Maybe the OE horn did not have a relay & that is why you did not hear it.
Try relocating the relay to somewhere in the front so that noise is under control.
Old 23rd August 2007, 13:26   #11
gbpscars's Avatar
Is the NVH of a Palio so bad that one can hear a relay clicking inside the engine bay?
Or is the relay installed under the dashboard??!!!
gbpscars is offline   Reply With Quote
Why relay for high watt lamps DRC Technical Stuff 11 9th September 2010 22:34
Relay : Bosch or PMP venkatrx Modifications & Accessories 10 19th January 2009 16:46
Relay for headlight Akkiben Technical Stuff 7 14th December 2005 09:46
