Old 23rd August 2007, 14:17   #1
arunkumar_rec's Avatar
Angry Hyundai Getz Parcel Tray Rattling Noise
Hello Friends,
I bought a new Hyundai Getz 6 months back from Advaith Motors, Mysore. I have a problem. There is an irritating rattling noise from the parcel tray. Just to avoid this rattling noise, I am forced to blast music always. I dont have any speakers mounted on the parcel tray.
The sound is really bad when the road is rough.In smooth roads however the rattling from parcel tray is less but it is always present. This is defintely not from the rear number plate(number plate has been pasted with the sheet metal in additon to the 3 screws).
Anyone has found a solution for this problem. The dealer says that this is a problem in many of Santros and Getz..
Appreciate if someone can help me get rid of this noise.
Thanks.
Arun
arunkumar_rec is offline   Reply With Quote
Old 23rd August 2007, 16:26   #2
vivek_pinkoo's Avatar
Either remove it or always keep some thing (toys or books) on the tray so that tray will not vibrate.
vivek_pinkoo is offline   Reply With Quote
Old 23rd August 2007, 16:31   #3
In fact I tried out with sticking dual side adhesive tape. It worked for 2-3 days. Then again the same old story... Now that tape also was removed by the dealer when it went for 2nd service last week...
It is surprising that Hyundai is not addressing this basic design flaw even though the dealers are well aware of...
Mod's Note: Do not break a possible single post into two unnecessarily. Even if you forgot something while hitting the submit use the Edit button to add the content rather than making another post.
Old 23rd August 2007, 17:36   #4
Akshay1234's Avatar
Thanked: 7,243 Times
are you sure its from the tray.. event he rear seatbelts if not clipped they can rattle.
Old 24th August 2007, 10:41   #5
Yes. Surely its from the parcel tray only. The seat belts are clipped properly.
Getz parcel tray rattling? arunkumar_rec Technical Stuff 14 29th June 2009 21:35
Mounting speakers on Boot tray.. good or bad for tray?? varunghatge Modifications & Accessories 11 5th December 2008 20:07
mounting oval speaker in parcel tray of SX$ budrukkar In-Car Entertainment 3 1st June 2008 16:31
What is in your Parcel Tray? mhafeez_13666 Shifting gears 22 23rd May 2008 10:13
Parcel/Speaker Tray saintsinner In-Car Entertainment 11 5th December 2007 10:23
