Old 16th April 2013, 17:22   #16
Thanked: 52 Times
Default Effect of incorrect setting of TPS sensor
Hi All,
Im trying to diagnose mileage issues with my maruti zen(old model)
This is my observation today.
Throttle Position Sensor voltage as per the manual is,
Throttle valve fully close: 0.78 – 0.83V
Throttle valve fully open: 3.7 – 4.7V
Im getting a reading of 0.76 V
My question is, is 0.76V acceptable?
Will it affect fuel cut operation?
Like i said, im trying to resolve high fuel consumption problem.
Note: everything else like plugs, filters, value setting, has been changed and engine serviced.
T1000 is offline   Reply With Quote
Old 10th July 2013, 11:58   #17
Default Re: Maruti Zen (MH410 16V) Sensor Codes
Hi there !
Can the members on this thread let me know if the Mahindra Bolero 2003 GLX has an ECU unit ?
I have a problem currently. The car will not start when the engine is warm.
The car cranks in one shot when the engine is allowed to cool and the key is turned.
Cranks fine when the engine is cool (mornings-first start)
Seems like the case of the coolant sensor or the cam shaft position sensor.
Hope I could solve this problem with some help from members in this forum.
HELP
Thanks!
Sai
Sai Sudhir is offline   Reply With Quote
Old 10th July 2013, 16:51   #18
Thanked: 52 Times
Originally Posted by Sai Sudhir View Post
Hi there !
HELP
Thanks!
Sai
Hi Sai
I dont know if your car has an ECU.
But even if there is one, the problem you mentioned cannot be related to coolant and cam shaft sensors.
Old 10th July 2013, 18:22   #19
Hi T1000!
Thanks for your input .
I've been going through quite a few threads online on the issue and was particularly going through a Honda and a Jeep thread that pointed to a defect coolant sensor issue and hence I mentioned the same .
I have just found out from a thread on TBHP that it could be a starter motor problem. I'm following up on that .
Shall post on developments ASAP
Cam Sensor-Crank Sensor-TDC Sensor. Are They The Same Thing? genesis Technical Stuff 8 5th October 2009 11:17
Zen MH410 1995 need_for_speed Modifications & Accessories 41 20th November 2008 13:16
For Sale - White ZEN - MH410 - End December 1997 - Hyderabad vbhatia Shifting gears 0 7th September 2007 10:54
Enthusiast maintained 2001 16V MPFI Esteem LX for sale turbo_c Shifting gears 0 24th October 2006 13:20
