Thread Tools
Old 24th August 2007, 22:23   #1 (permalink)
Team-BHP Moderator
Mpower's Avatar
Default Opel Astra misfire/backfire
Guys
We have an Opel Astra that is stationed in Chennai and driver is reporting engine misfires and backfires. I guess its OK when driven gently but when you step on it you can hear firecrackers going off.
Since my dad is here in the US, we have told him to minimize driving.
Any idea what its could be? I did some research on the web and its pointing to either a MAF issue or an ignition module issue. Anybody faced the same problem?
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 24th August 2007, 22:47   #2 (permalink)
gigy's Avatar
mostly it should be a bad spark plug and or bad fuel. replace all plugs and drain out the fuel if it was filled up at a non normal filling station. should solve the problem
__________________
Suzuki Baleno
Old 24th August 2007, 23:57   #3 (permalink)
wolfinstein's Avatar
Most likely Bad Plugs, Check them and Replace if needed- Also have the Throttle and Air Filter Cleaned, In most cases these 3 things can have the PATAKA Effect coupled along with Poor Pickup,Bad FE and ofcourse the Misfires.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 25th August 2007, 00:18   #4 (permalink)
In my opinion its bad plug wires. See if it works ok with new HT plug cables.
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Old 25th August 2007, 00:28   #5 (permalink)
highwayblaze's Avatar
Deep you might also check if this issue has started recently (during monsoon)? Increase in moisture = may a cracked coil pack and/or cracked plug wires = misfire/backfire?
I have been told (gti-vr6.net) that after market plugs (4 - point iridiums) are not good on several german cars so maybe that could be an issue too.
__________________
Chill Pill
Blaze
highwayblaze is offline   Reply With Quote
Old 25th August 2007, 00:34   #6 (permalink)
Team-BHP Moderator
Mpower's Avatar
I think we can rule out the bad fuel part since new fuel has already been tried. If its indeed is the plugs then I am happy since its a cheap fix.
If I am not mistaken, misfires are caused because the plug is firing at the wrong time. That's why I have this nagging feeling that its the ignition module(elecrtonic distributor) that is causing this issue.
__________________
Old 7th August 2008, 00:23   #7 (permalink)
RacingHart's Avatar
Infractions: 0/1 (4)
I had the same problem too. Get your vehicle to a genuine GM service center and they will take care of it. you can check if it is a ECU problem. you have to change your ECU unit if it has gone bad. or may be fixed if in a good condition. And it also may be a timing issue. GM will be the best people to assist you further. I strongly recommend you to take your vehicle to those guys. and if you want to increase your vehicles FE, pm me. I get a FE of 18km/L in city and 21km/L on highways. Beautiful technology installed in my OPEL ASTRA
RacingHart is offline   Reply With Quote
Thread Tools
Opel Astra adya33 Long-Term Ownership Reviews 10 3rd January 2008 00:19
Opel Astra Club or Opel Corsa bsashwin Sedans 2 11th July 2006 17:34
Opel Astra!!! Want to do something to it... cyba123 Modifications & Accessories 18 6th June 2006 08:39
Opel Astra for Sale sonic Shifting gears 3 1st February 2005 12:52
Opel Astra amit The Indian Car Scene!! 24 22nd March 2004 16:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
