| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Friends, I had got my exhaust redone recently and since then i see the 'malfunction lamp' glowing while driving. There is NO noticeable difference in driving handling, FE etc.. just that light irritates. On reading about it, came to know that it is linked to the catalytic convertor thing. Now what to do about it? What could be wrong here? - Is there some part in the exhaust that connects to the senor? - Some wiring? How to check? - Could the sensor be gone? If yes, where to get one and what cost? - What about disabling the lamp itself? what could be the risk? [I plan to go for either the FFE or just Headers/Expansion Chamber for more low end torque. So should i just ignore this.???] Cheers, -SK |
| | #2 (permalink) |
| BHPian | Hi! In some cases, there's a sensor in the exhaust! I'm doubtful if it'll be present in the Gypsy.. Perhaps when your exhaust was redone, the sensor was not connected properly. I wouldn't disable the light. I'd prefer to keep the light connected. cya A
__________________ Ford Ikon 1.6 Nxt ZXi, 2005 I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM. |
| | #7 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| There is a sensor at the exhaust manifold which is known as O2 sensor, hope you have fitted it correctly and is functioning proper.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #8 (permalink) |
| Senior - BHPian | Where did you get it done? Please go to someone good for your work. An automobile is an expensive piece of machinery, and a lot of things can go wrong if the person in question does not know what to do, and do it right.
__________________ I've lost my phone. Please PM me your phone number if I'm on your contact list. |
| | #9 (permalink) |
| BHPian Join Date: Jul 2007 Location: Delhi
| Hi there Along with post i am enclosing information about the sensor codes of Gypsy might be helpful to you. Perhaps you might be able to find out the problem by doing so. This link below expains about the sensors and its codes. In case you need to have more information about working of these sensor then you could refer to MARUTI ZEN SENSOR CODES thread. http://img66.imageshack.us/img66/398...esmg413wk9.png The link below shows the image of the connector you need to bypass using a wire http://img444.imageshack.us/img444/3...psykingpl7.png Ones you successfull fully by pass the connector, the malfunction indicator light (MIL) will blink according to the sensor code. In case if there is the O2 sensor is faulty, the MIL will blink ones and then four times more which represents code no 14. I hope you will find this information usefull. Thanks Amit |
| Thread Tools | |
Similar Threads | ||||
| Gypsy Veterans Please help me... Is this a Gypsy King ?? | Sabareesh | 4x4 & Off-Roading | 26 | 1st September 2008 17:20 |
| Malfunction-Indicator light stays on after push-starting car. How serious is this ? | supremeBaleno | Technical Stuff | 17 | 28th July 2008 14:03 |
| old honda city - malfunction indicator | yuv | Technical Stuff | 48 | 5th July 2008 13:04 |
| Sprucing up Gypsy King MPFI and making it more reliable (for the RAID etc) | aditya.b | Modifications & Accessories | 16 | 6th May 2008 21:23 |
| Gypsy King HT MPFI - 2001 | khan_sultan | SUVs, MUVs & 4x4s | 19 | 28th January 2007 17:50 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
