| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #122 (permalink) |
| BHPian | to some of the earlier posts. Its always a great feeling to hear your engine sing. And i guess everyone competent enough to drive a car would know that its practically impossible to shift your gears at 14.7km/hr ot at 45.8km/hr because you want to see how much F.E you can extract!!But i just do not choose to be complacent with that feeling of practicality. ![]() No offenses but i believe there is a lot more to learn out there though that deos not lead to sitting with tons of charts and ratios beside our driving seat.
__________________ "Our world is in its current state because of the choices WE made ...or failed to make" Last edited by gemithomas : 26th October 2007 at 00:05. |
| | #123 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
Charts and printed guides will not help. Learn to LISTEN to your car; it pretty much TELLS you how it is feeling. Keep it 'singing' fit! | |
| | #124 (permalink) | |
| BHPian Join Date: Jul 2006 Location: pune
| Quote:
generally with hi powered petrol engines u can pickup the speed quickly with wider throttle opening <still i dont zoom>. once u attain the desired speed u just coast in minimum accelerator which barely maintains the desired speed . it takes lot of power to make one tonner move and reach 80kmph <acceleration>--- then it takes very little power just to maintain the velocity<0 acceleration>as its inertia has stored a lot of energy<mass*velocity> thats why powerful engines with taller gear ratios give fanstatic crusing speed , on demand acceleration and great milage. ![]() | |
| | #125 (permalink) | |
| Senior - BHPian | Quote:
__________________ Goodbye Dada, you made us proud. | |
| | #126 (permalink) | |
| Quote:
hotter air will give lesser mass of air inside the engine , but will be able to extract more out of it . production vehicles have to accept many compromises .more we understand them , more we can use them for our future projects! | |
| | #127 (permalink) | |
| Quote:
per 1000rpmso at 3000 rpm it will attain 33.55*3 =99kmph in fifth gear! thats the way the velocity ratio expressed in automobile engg! ![]() | |
| | #128 (permalink) | |
| BHPian | Quote:
So at what speeds should we change gears on the FIAT 1.6 so as to get maximum mileage?
__________________ "Our world is in its current state because of the choices WE made ...or failed to make" | |
| | #129 (permalink) |
| Senior - BHPian | i am having a verna vgt which gives me 15-16 kml with a/c combined driving cycle .it has done 20000 km and latest tank full to tank full gave me 12 kmpl.the a/c is super cool and i have noticed fumes -like fog comming out of the a/c vents .can this be an issue. ram |
| | #130 (permalink) | ||
| BHPian | Quote:
Now, Quote:
When the a/c compressor gets defrosted, that is when the compressor is turned off for sometime it'll be good again! No worries! cya A
__________________ Ford Ikon 1.6 Nxt ZXi, 2005 I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM. | ||
| | #131 (permalink) | |
| Quote:
if u mean the cooling coil<evaporator in auto lingo>is freezing , then the a/c grill temp should be measured at first speed .at 50-60 kmph to check the a/c cut off function . if its not cutting off much below 0 deg centigrade then the thermo-switch/ice sensor should be checked, resetted as iceing on the evaporator coil hampers the cooling ability of the a/c system. ![]() | |
| | #132 (permalink) |
| BHPian Join Date: May 2007 Location: bangalore
| before any rocket-science techniques are applied, there is a very simple technique to get really great FE. which is to anticipate while you drive remembering that computer cuts-off fuel if you don't press accelerator pedal while in gear and rpm is more than idle rpm. - whenever you have to slow down (speed breaker, signal, corners, etc.) do it gradually in gear by letting off the accelerator instead of accelerating and then hard braking in the last moment. - whenever you are going down a slope, shift into the highest gear that gives adequate speed without pressing the accelerator pedal. - turn off engine if the idle time is more than 60 seconds, remember that coasting in neutral or idling consumes fuel |
| | #133 (permalink) |
| BHPian | hi , im from chennai and drive a 87k kms zen 2003 mpfi . before 1 year the fuel economy was 14kmpl with a/c and 16kmpl without a/c & now around 10kmpl so i dont drive with a/c these days and without a/c i get 13kmpl.can u help me ways to increase the fuel economy. car running with knn air filter,engine decarbonised,fuel injectors cleaned,and regular servicing at 4k kms.. recently had a problem with the car>>engine gets off when changing gear(down shift) but rectified(it was due to loose connection in ignition cables) im feeling vibrations in cabin(since few days only) and got the engine rubber hoses replaced,the vibrations hav decreased a litttle but can still feel it. how to prevent it ? plz help .. ![]()
__________________ Cheeers Yaswanth :) |
| | #134 (permalink) | |
| Quote:
for fiat palio the conditions are-- more than1700rpm+ accelerator pedal released completely+coolent temp above 50 deg c+battery voltage above12 volts+car is an gear<transmission engaged> the fuel injection resumes as soon as the rpm drops below 1100 rpm more u know the ruling and over-rulining parameters of the programming more u can use it for the desired goal. coasting in neutral sure consumes pertol but it keeps the brake booster vaccum maintained. closing the accelerator completely+keeping the car in gear is a great way to control the car in gear but 1>if your car is a carb version and if it doesnot have a fuel cutoff circuit like uno 1000, it will just gulp lots and lots of fuel because carb doesnot have a closed loop system, it works on venturi effect. more the pressure difference between the fuel in the float bowl and the jets in and around venturi more the petrol is sucked<or pushed by the pressure diff>in the engine. 2> when the car is coasting in gear+accelerator off position, the very high vacuum in the engine<i should be saying cylinders and combustion chambers>sucks a lot of oil from the valve guides and around the oil and compression rings. so every thing has pros and cons , use them judiciously and reap the fruits!! Last edited by TURBOSAM : 12th November 2007 at 12:38. | |
| | #135 (permalink) | |
| Quote:
i think the problem of valve timing missalignment is the culprit. get the timing belt replaced if not done already<generally 3 yrs or 50 k kms by belt mfg. quotes> and get the timing set perfectly preferably with the dial guage. get the wet any dry compression checked . then get the valve +tapette clearance adjusted WHEN ENGINE IS COMPLETELY COLD<AT LEAST 6 HRS IN OFF POSITION> then check out the fuel return pipe function. . fit the stock air filter . reset the ecu . assuming all the other things are good u should be getting better milasge than the new one <factory zens come with valve timing wondering +/- 5 deg > NEVER EVER DO ANY chemical DE CARBONIZING AND CHEMICAL FLUSHING TREATMENTS they just screw the engines. ![]() | |
« TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS
Maintenance of Maruti Alto? »
| Thread Tools | |
Similar Threads | ||||
| How to achieve Max FE in an Opel Corsa? | raj_7703 | Technical Stuff | 12 | 2nd November 2008 21:33 |
| 4 kmpl palio 1.6???? HELP!!! | sajeeth | Technical Stuff | 66 | 6th October 2008 21:11 |
| Autocar India & Ford Fiesta achieve 33 kpl? | windsurfer | The Indian Car Scene!! | 52 | 2nd April 2008 05:35 |
| F.E. =150 Kmpl !! | DCEite | Shifting gears | 12 | 30th March 2008 15:53 |
| Is Swift Mileage 8-9 kmpl ?? | shobhit15 | The Indian Car Scene!! | 60 | 6th April 2007 19:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
So sorry. Did not notice that the alignment had gone haywire.
