Old 28th August 2007, 22:39   #16
Thanked: 149 Times
Hmmm... all the previous vehicles I owned - the six wheeled, fourty three seater ones - had indicators to show battery usage. That was quite a few years ago. This seems to be an ammeter, which went to the negative side when discharge was more than the charging from alternator. There were a couple of other indicators on the dash, like oil pressure meter and the air pressure gauge. Together, all these gave the driver / owner a good indication of the engine health. (For example, low oil pressure at high RPM meant the engine was due for overhaul). The last mentioned is of course, is not required in small cars, of course. I do not know about the oil pressure gauge. But battery charge indicator seems to be a must on all vehicles.
I certainly miss it on my present car.
Old 29th August 2007, 00:27   #17
PatienceWins's Avatar
Thanked: 285 Times
First check your car alternator...I learnt it the hard way in my Santro..
My Exide used to hold charge only for 2 to 3 days and a cell became fully dead. Took it to hyundai and they said the problem is not with the electrical system. One of the head lights fused soon..I could not tolerate the battery and changed 1 year old battery to Amaron Maintenance free. When I checked the new battery after a ride, found battery acid over it.
Checked the electrical system in a Car electrical workshop and diagnosed the problem with alternator. Replaced the alternator regulator for around 2000 Rs. Problem solved.
PatienceWins is offline   Reply With Quote
Old 29th August 2007, 10:18   #18
Hi
I understand, that I may have to replace the batteries.
What is the battery spec of Petra 1.6 ELX? In the manual, I could not find it.
Which battery I should go for (Exide, SF, Ameron)? Any suggestions, please.
Subodh
Subodh Kumar is offline   Reply With Quote
Battery getting drained out dkcrpl Technical Stuff 26 13th February 2018 17:59
Battery not charging when the engine is running. Discharges completely tjacob Technical Stuff 17 25th February 2013 13:53
2004 Ikon Flair with corroded dummy cap and drained coolant supertinu Technical Stuff 7 21st October 2012 00:09
this is completely insane - Guy waiting in line for iPhone for 5 days in NYC whatcanthisbe Shifting gears 20 1st July 2007 21:04
At what Temp should the Engine Oil be drained off ? mithun Technical Stuff 3 14th August 2006 16:18
