| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) |
| Senior - BHPian | You read it right but the torque overcomes the stress on the engine as far as I can gather. I have never felt the strain.
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) |
| | #18 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Quote:
Who needs a clutch or a gas pedal in traffic. ![]() | |
| | #20 (permalink) |
| BHPian | thats not bad for engine cos right after the cold start or with AC on the cars operate above the designated Idle RPMs so the engine keeps moving and as u move on the RPMs starts decreasing towards the designated slot and then u need to push the accelerator |
| | #22 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Chennai
| I had to get home once in a VW Golf (about 1988) with a broken accelerator cable. That meant nothing available higher than idling speed (even manual choke was already a thing of the past then). I was only two streets away, about half a mile thankfully on the flat with the worst bit a right turn onto a busy main road. With featherlight clutch control I got the car back in first gear. All sorts of things can be done when you have to! Al |
| | #23 (permalink) | |
| BHPian | Quote:
__________________ I have one dream, Fiat with great A.S.S. | |
| | #24 (permalink) |
| Senior - BHPian | I do not use the gas pedal in bumper to bumper traffic. Not required at all. Just step on the gas a little when you shift to 2nd gear. Most torquey diesels operate like automatics in traffic. And of course, no touching of the pedal while starting. After starting, I do a diagnostic check on the car controls.
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* |
| | #26 (permalink) |
| BHPian | I felt the difference in this over the move from the Carb Esteem to the Ikon. In the Esteem it was impossible to move without pressing the accel. In the Ikon no need to press accel. Jus release clutch and itll move. I wish it had autoclutch though. Btw I agree that its possible to go to fourth by not pressing the accelerator. Just patience required. cya A
__________________ Ford Ikon 1.6 Nxt ZXi, 2005 I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM. Last edited by Absar : 29th August 2007 at 23:11. |
| | #28 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
However, there is no need for wasting fuel and time on a modern engine by idling it in the morning. The ECU does set a higher idling rpm till the engine warms up to get things lubricated. For me, I think, clutch and accelerator works in conjunction, sometimes throttle works before the clutch is even released a milimeter.
__________________ ________________________ Every Ferrari is always a Fiat | |
| | #29 (permalink) |
| BANNED Join Date: Nov 2005 Location: ??
| My Santro manual clearly advises to gradually and smoothly release the clutch while simultaneously applying the throttle. What I think is true about MPFI cars is that it is advisable to release the clutch fully in a given gear (say, first) before either depressing it again or shifting to the next gear. I.e., I do not think it is advisable to release the clutch 50% and then depress it again and change gears or brake. I find that a mild clutch shudder develops after driving in heavy traffic where I often do not get the chance to release the clutch fully in 1st gear; I release a little and then have to brake due the traffic in front. Later when I drive in clear roads with full release of clutch, the shudder disappears after a while. |
| | #30 (permalink) | |
| BHPian | Quote:
Ya right! Haha. Nice one Thad! It looks more likely, 0-40 or 0-50 depending on the 4th/5th gear vehicle speed at 1000 rpm.cya A
__________________ Ford Ikon 1.6 Nxt ZXi, 2005 I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM. | |
| Thread Tools | |
Similar Threads | ||||
| Clarification on Clutch in Ford Ikon | FlairBoy | Technical Stuff | 7 | 19th September 2007 01:27 |
| Maruti 800 5 Gear MPFI problem | anoovis | Technical Stuff | 3 | 28th February 2007 09:07 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
